Setting Up and Using Multibook Ledgers
To set up multibook ledgers, use the following components:
Installation Options (INSTALLATION)
Ledger Template (LEDGER_TEMPLATE)
Detail Ledger (DETAIL_LEDGER)
Detail Ledger Group (DETAIL_LEDGER_GROU)
Pages Used to Set Up and Use Multibook Ledgers
| Page Name | Definition Name | Usage |
INSTALLATION_FS1 |
Select the Create Multibook Accounting Entries in Subsystems option. |
LEDGER_TEMPLATE1 |
You can create or modify the record names for a ledger template; however, do this only if you are adding a new template or modifying the default records of the templates delivered with the system. |
LEDGER_TEMPLATE2 |
You can create or modify the field names for a ledger template; however, do this only if you are modifying the default fields or if you are adding the fields to store debit amounts separate from credit amounts (separate debit and credit configuration). |
LEDGER_DETAIL1 |
Define a detail ledger ID and name, and link the detail ledger to a ledger template. |
LEDGER_GROUP |
Define a ledger group, link it to a ledger template, assign ledger details to the group, and identify the unique attributes of each ledger within the group. |
LEDGER_GROUP2 |
Define default ChartFields for this ledger group. The system generates a set of default values, which you can modify. |
LEDGER_GROUP3 |
Specify the ChartField balancing options for the journals generated to the detail ledger. |
JOURNAL_ENTRY1 |
Select the multibook transaction ledger group. |
JOURNAL_ENTRY2_IE |
Enter transaction amounts and currency codes for one or more ledgers included in the multibook ledger group. |
Overall Page
Use the Overall (INSTALLATION_FS1) page to select the create Multibook Accounting Entries in Subsystems option.
Navigation:
. Click the Overall link
To set up your system for multibook processing:
Select the Multibook Accounting Entries in Subsystems check box only if you want other PeopleSoft applications to create in-sync accounting entries.
Review ledger templates and define detail ledgers.
Link multiple detail ledgers to a ledger group using the Ledger Group - Definition page.
Create/Update Journal Entries - Header Page
Use the Create/Update Journal Entries - Header page (JOURNAL_ENTRY1) to select the ledger group that you set up for multibook transactions, or select the ledger group and a specific ledger within that group.
Navigation:
General LedgerJournalsJournal EntryCreate/Update Journal EntriesHeader
When you select Keep Ledgers in Sync on the Ledger Group - Definition page, the system automatically selects the AutoGenerate Lines option.
When you enter a transaction for the entire group, the system converts the transaction amount to the base currency of each ledger in the group and posts it to each ledger within the group. The conversion rate is determined at the transaction level. If the transaction is for one specific ledger in the group, the system posts the transaction only to that ledger.
Create/Update Journal Entries - Lines Page
Use the Create/Update Journal Entries - Lines page to enter transaction amounts and currency codes for one or more ledgers included in the multibook ledger group.
Navigation:
The Ledger field in the journal line record is an addition to the existing key fields: Business Unit, Journal ID, Journal Date, and Unpost Sequence. Based on the ledger group that you enter, the system determines how many secondary ledgers are in the ledger group; it creates one journal line for each ledger. The ChartField values and transaction amounts are the same on each of these lines, with the exception of the translation ledger. The translation ledger has different amounts that populate the Monetary (Base Currency) Amount, Currency Code, Exchange Rate Type, and Exchange Rate fields; the base currency in the ledger determines these values.
After you enter all of the transaction lines, select the Journal Edit process, which automatically generates journal lines as supporting transaction details for each ledger.
Example 1: Multibook Transaction
Assume that you have a Local ledger with NOK as the base currency and a Reports ledger with EUR as the base currency. Both are part of the ledger group Actuals. You enter the transaction in CHF with a CHF 100 debit to rent expense (account 1000) and a CHF 100 credit to accounts payable (account 2000). You enter the local lines, and the system automatically generates the reports lines. The four journal lines appear as follows:
| Jrnl Ln | Ledger Group | Ledger | Acct | Frgn Amt | Frgn CC | Mntry Amt | CC | Rate Type | Excg Rate |
1 |
ACTUALS |
LOCAL |
1000 |
100 |
CHF |
50 |
NOK |
CURR |
0.5 |
1 |
ACTUALS |
REPORTS |
1000 |
100 |
CHF |
25 |
EUR |
CURR |
0.25 |
2 |
ACTUALS |
LOCAL |
2000 |
<100> |
CHF |
<50> |
NOK |
CURR |
0.5 |
2 |
ACTUALS |
REPORTS |
2000 |
<100> |
CHF |
<25> |
EUR |
CURR |
0.25 |
Example 2: Translation Ledger
In this example, Reports is defined as a translation ledger. Both Local and Reports are part of the ledger group Actuals. The transaction was entered in CHF with the same amount as above. The four journal lines appear as follows:
| Jrnl Ln | Ledger Group | Ledger | Acct | Frgn Amt | Frgn CC | Mntry Amt | CC | Rate Type | Exchg Rate |
1 |
ACTUALS |
LOCAL |
1000 |
100 |
CHF |
50 |
NOK |
CURR |
0.5 |
1 |
ACTUALS |
REPORTS |
1000 |
50 |
NOK |
25 |
EUR |
CURR |
0.5 |
2 |
ACTUALS |
LOCAL |
2000 |
<100> |
CHF |
<50> |
NOK |
CURR |
0.5 |
2 |
ACTUALS |
REPORTS |
2000 |
<50> |
NOK |
<25> |
EUR |
CURR |
0.5 |
When you enter the Local lines, the system automatically generates the Report lines. For a translation ledger, the foreign amount and transaction currency of Reports are the monetary (base currency) amount and currency code of the primary ledger, Local.
The header record for the journal lines contains summary information including ledger, total debits, total credits, edit status, and posted status. The amounts carried on the header are in the denomination of the base currency for the business unit.
