Using the Data Migration Workbench for PeopleSoft Business Process Weaver
PeopleSoft Business Process Weaver provides a framework for stringing together key jobs. You can use the ADS definitions to migrate the Business Process Definitions, Task Registry, Business Process Run Controls, and Business Process Weaver Application Class registry between databases—and ultimately to your production environments.
The following table lists the delivered ADS definitions (delivered in Data Set Designer) to support the migration of PeopleSoft Business Process Weaver configuration data:
Delivered ADS to Support PeopleSoft Business Process Weaver Application Data Set (ADS) Usage
COMP_BPW_APPCLS_REG
This data set includes the records that store the Application Classes used as task or event handlers in Business Process Weaver. Use this if you have created user-defined Application Classes. Select this data set on the Project Definition page to move the Application Class records.
Note: The application classes must exist in the target database.
COMP_BPW_PROC_DEFN
This data set includes the records that store the Business Process Definitions. Select this data set on the Project Definition page to move the Business Process Definitions.
Note: If the Business Process uses user-defined Application Classes or tasks, these must be migrated before moving the Process Definition.
COMP_BPW_TASK_REG
This data set includes the records that store the Business Process Task Registry. Select this data set on the Data Migration Workbench – Project Definition page to move the Task Registry records.
COMP_BPW_PROC_RUN
This data set includes the records that store the Business Process Run Control definitions. Select this data set on the Data Migration Workbench – Project Definition page to move the Business Process Run Control definitions.
All relevant records are delivered in the Query Access Tree, QUERY_TREE_GL, within the BPW access group (PeopleTools, Security, Query Security, Query Access Manager).
PeopleSoft delivers an ADS Administrator permission list. For access, the BPW access group should be included on the Data Migration page within the Access Group Permissions and the proper access is granted on the Copy Compare Permissions.
See PeopleTools: Security Administration, Permission Lists.
