Running Depreciation Reports
This topic provides an overview of depreciation reports and discusses how to load the depreciation reporting table.
Pages Used to Run Depreciation Reports
Depreciation Reporting Table Page (Depr Reporting Table Page)
AMDPREPT_RQST
Load the Depreciation Reporting table (PS_DEPR_RPT). Use this table for all depreciation reports.
Depreciation by Period
RUN_AMDP2200
Run the Depreciation by Period report.
Depreciation by Fiscal Year
RUN_AMDP2300
Run the Depreciation by Fiscal Year report.
Depreciation Activity
RUN_AMDP2000
Run the Depreciation by Activity report.
Understanding Depreciation Reports
PeopleSoft Asset Management provides a full complement of depreciation-related reports. Before you can run depreciation reports, you must load the Depreciation Reporting table (PS_DEPR_RPT). The table stores life-to-date and year-to-date depreciation amounts. You should run the process once at the beginning of the year for all assets in your system, and on a monthly or other regular basis thereafter for new open transactions.
To run depreciation reports:
  1. Load the Depreciation Reporting table.
  2. Run the Depreciation by Period report.
  3. Run the Depreciation by Fiscal Year report.
  4. Run the Depreciation Activity report.
Use the Depreciation Reporting Table (Depr Reporting Table) page (AMDPREPT_RQST) to load the Depreciation Reporting table (PS_DEPR_RPT).
Navigation:
Asset Management, and then Financial Reports, and then Load Reporting Tables, and then Load Depr Reporting Table, and then Depr Reporting Table
This example illustrates the fields and controls on the Depr Reporting Table page. You can find definitions for the fields and controls later on this page.
Run Options
Field or Control Description
Use Open Trans (use open transactions)
Select to pick up only new open transactions since you last ran the process.
Keep Other Fiscal Years
Select to process a new year but retain other years in the table.
Forecast Load
Select Forecast Load field to run a seven year depreciation forecast report. Enter the business unit and From Year and To Year are auto populated.
Forecast Load will initiate three reporting processes simultaneously for each year. When one process completes, it sequentially triggers the next until all years are processed.
The Depreciation Reporting table should be loaded only for the current fiscal year, or at most two fiscal years (depending on your reporting requirements). Use the Forecast Load option if the data for more than two fiscal years is required.
You should run the AMDPREPT_RQST process throughout the year to account for new transactions that were created during the year by selecting the Use Open Trans check box.
When the Asset Management Insights search indices are deployed, the AMDPREPT process will automatically trigger the incremental index process (PTSF_GENFEED) each time it runs. This synchronises any changes in Depreciation Reporting data with Open Search, ensuring that Insights analytics have the recent information. The process runs asynchronously, sending only the latest data changes to Open Search.
