Viewing Issues by Priority
This topic discusses how to view issues by priority.
Page Used to View Issues by Priority
| Page Name | Definition Name | Usage |
PC_PE_ISU_CNT_PRIO |
View a chart that displays all the high, medium, and low issues that are assigned to the user. |
Issues by Priority Pagelet
Use the Issues by Priority pagelet (PC_PE_ISU_CNT_PRIO) to view a chart that displays all the high, medium, and low issues that are assigned to the user.
Navigation:
Click the Personalize Content link on the PeopleSoft Home page.
Select Issues by Priority.
A bar chart appears that depicts the number of open issues assigned to the user ID. Each issue priority is represented by a colored bar that functions in two ways:
Move the mouse pointer to a bar to view the alternate text about the number of issues for that priority level.
Click a bar to access the Resource Workbench page, from which you can view and update any issues.
