Viewing Issue Priority by Project
This topic discusses how to view issues by priority by project and personalize the Issue Priority by Project pagelet.
Pages Used to View Issue Priority by Project
Issue Priority by Project Pagelet
PC_PE_PRIO_BY_PROJ
View a maximum of the top five projects that have the greatest number of open issues.
Personalize Issue Priority by Project Page
PC_PE_PRIO_PRS
Define default display information for the Issue Priority by Project pagelet.
Use the Issue Priority by Project pagelet (PC_PE_PRIO_BY_PROJ) to view a maximum of the top five projects that have the greatest number of open issues.
Navigation:
Click the Personalize Content link on the PeopleSoft Home page.
Select Issue Priority by Project.
This pagelet displays the top five projects that have the greatest number of issues and sorts the issues by priority. Each project ID appears as a link that accesses the Flexible Analysis page.
Click one of the visual indicators that represents a high, medium, or low priority to access the Issue Management component (PC_IM_ISSUE) for the selected project and issue priority. If there is only one issue at that priority level, the Issue Management component appears. When there is more than one issue, a list of links appears for you to select a particular issue.
Use the Personalize Issue Priority by Project page (PC_PE_PRIO_PRS) to define default display information for the Issue Priority by Project pagelet.
Navigation:
  • Set Up Financials/Supply Chain, and then Pagelets, and then Enterprise Service Automation, and then Portal Pack Defaults, and then ESA Portal Pack Pagelet Default Administration
    Click the Issue Priority by Project link on the ESA Portal Pack Pagelet Default Administration page.
  • Click the Customize Issue Priority by Project icon on the Issue Priority by Project pagelet.
This example illustrates the fields and controls on the Personalize Issue Priority by Project page. You can find definitions for the fields and controls later on this page.
Specify parameters to filter the projects that you want to appear on the Issue Priority by Project pagelet.
Click Restore Defaults to restore the default selection criteria that the pagelet administrator establishes on the ESA Portal Pack Pagelet Default Administration page. The Restore Defaults button appears if you access this page by clicking the Customize Issue Priority by Project link on the Issue Priority by Project pagelet.
