Configuring Journal Generator for the Fusion Accounting Hub Integration
PeopleSoft delivers the following new Accounting Entry Definition and Journal Generator Template to accommodate the Fusion Accounting Hub integration to PeopleSoft General Ledger:
FAIJRNL – Accounting Entry Definition (delivered sample)
FAH_PSFT – Journal Generator Template (delivered sample)
