Examples of PeopleSoft Processes Initiated Using the Generic Process Initiation Service
This section lists some examples of PeopleSoft Financials processes that can be initiated using the generic process initiation service through this integration. Other processes can also be initiated using this web service, as long as the required three parameters are included in the request xml.
| Area | Process Name | Navigation | Required Parameters |
Asset Management |
Execute Final Depreciation Process |
Asset Management, Depreciation, Processing, Calculate |
Process Type: Application Engine Process Name: AM_DEPR_CALC Run Control ID: (predefined value) |
Asset Management |
AM Execute Create Accounting Entries Process |
Asset Management , Accounting Entries, Create Accounting Entries |
Process Type: Application Engine Process Name: AM_AMAEDIST Run Control ID: (predefined value) |
Asset Management |
Execute Depreciation Close Process |
Asset Management, Accounting Entries, Close Depreciation |
Process Type: Application Engine Process Name: AM_DPCLOSE Run Control ID: (predefined value) |
Payables |
Execute Open AP Liability Report |
Accounts Payable, Reports, Voucher Reconciliation, Open Liability Reconciliation |
Process Type: PSJob Process Name: APY1400 Run Control ID: (predefined value) |
Payables |
Execute Period End Accrual Processing |
Accounts Payable, Batch Processes, Vouchers, Period End Accrual, Create Period End Accruals |
Process Type: Application Engine Process Name: FS_PEACCRL Run Control ID: (predefined value) |
Receivables |
Execute Aged AR Trial Balance |
Accounts Receivable, Receivables Analysis, Aging, Aging by ChartField Rpt |
Process Type: SQR Report Process Name: AR30006 Run Control ID: (predefined value) |
Billing |
Execute Pre- Load/Load to AR Process |
Billing, Generate Invoices, Non-Consolidated, Load Invoices to AR |
Process Type: PSJob Process Name: BIJOB05 Run Control ID: (predefined value) |
Billing |
BI Execute Create Accounting Entries |
Billing, Generate Invoices, Non-Consolidated, Create Accounting Entries |
Process Type: PSJob Process Name: BIJOB06 Run Control ID: (predefined value) |
General Ledger |
Execute Journal Edit and Post Process |
General Ledger, Journals, Process Journals, Edit Journals |
Process Type: Application Engine Process Name: GL_JEDIT Run Control ID: (predefined value) |
General Ledger |
Execute Trial Balance |
General Ledger, General Reports, Trial Balance |
Process Type: SQR Report Process Name: GLS7012 Run Control ID: (predefined value) |
General Ledger |
Execute Allocations Process |
Allocations, Define and Perform Allocations, Request Allocation |
Process Type: Application Engine Process Name: FS_ALLC Run Control ID: (predefined value) |
General Ledger |
Execute Consolidations Process |
General Ledger, Consolidate Financial Data, Consolidation, Request Consolidation |
Process Type: COBOL SQL Process Name: GLPOCONS Run Control ID: (predefined value) |
General Ledger |
Execute Load Reconciliation Data |
General Ledger, General Reports, GL Subsystem Reconciliation, Load Reconciliation Data |
Process Type: Application Engine Process Name: GL_RECN Run Control ID: (predefined value) |
General Ledger |
Execute Process all GL Journals |
General Ledger, Journals, Subsystem Journals, Generate Journals |
Process Type: Application Engine Process Name: FS_JGEN Run Control ID: (predefined value) |
The aforementioned PeopleSoft Financials processes were successfully tested for the delivered web service.
