Maintaining Project Budgets
To maintain project budgets, use the Detail Project Maintenance component (PROJ_ENTRY).
Pages Used to Maintain Project Budgets
Detail Project Maintenance Page
BD_P_ENTRY2
Select the fiscal year and the ChartField values to appear on the Data by Year page.
Data by Year
BD_P_ENTRY3A
View the budget data for all projects that exist in the selected budget ledger for the selected fiscal year.
To access this page, click the Query link on the Detail Project Maintenance page.
Data by Period
BD_P_ENTRY4
View the project budget data for selected projects for each period within the selected fiscal year.
To access this page, click the account number link on the Data by Year page.
Use the Detail Project Maintenance page (BD_P_ENTRY2) to select the fiscal year and the ChartField values to appear on the Data by Year page.
Navigation:
General Ledger, and then Maintain Standard Budgets, and then Review Detail Project Maint
You maintain project budgets in the same way that you maintain standard budgets. Project budgets normally include project detail information, which you can modify.
