Staging RMA Receipts Using an Electronic Data Collection System
Pages Used to Manage Returned Material From Third-Party Systems
| Page Name | Definition Name | Usage |
RUN_RMA_LOAD |
Define parameters for the RMA Load process. |
RMA_EIP_MAINT |
View error details about RMA Load EIP transaction and edit the fields for specific segments of the RMA Load EIP data. |
Maintain Data Definitions - RMA Header Page |
RMA_EIP_HEADER |
Correct header-level errors in the RMA Load EIP transaction by clicking the link on the RMA Load EIP Maintenance page. |
Maintain Data Definitions - RMA Header Address Page |
RMA_EIP_ADDR_HDR |
Correct header-level address errors in the RMA Load EIP transaction by clicking the Header Address link on the RMA Load EIP Maintenance page. |
Maintain Data Definitions - RMA Line Page |
RMA_EIP_LINE |
Correct line errors in the RMA Load EIP transaction by clicking the RMA Line Details link on the RMA Load EIP Maintenance page. |
Maintain Data Definitions - RMA Line Address Page |
RMA_EIP_ADDR_LN |
Correct line-level address errors in the RMA Load EIP transaction by clicking the Line Address link on the RMA Load EIP Maintenance page. |
Maintain Data Definitions - RMA Serial/Lot IDs Page |
RMA_EIP_SER_LOT |
Correct serial or lot errors in the RMA Load EIP transaction by clicking the RMA Serial/Lot IDs link on the RMA Load EIP Maintenance page. |
RUN_IN_INBOUND_PRG |
Delete RMA transaction data from the transaction staging tables |
Understanding the RMA Load EIP
The RMA Load EIP is an inbound asynchronous service operation that receives RMA receipts from a third-party system to create RMAs in PeopleSoft Inventory. Once the PeopleSoft system receives the transaction, the RMA Load process validates the data and inserts it into either the RMA table or, if errors are found, into the transaction error table. You can correct errors and resubmit the transaction using the RMA Load EIP Maintenance pages in the Maintain Data Definitions component.
You can run the RMA Load process automatically as part of the subscription process or at scheduled intervals. To launch the RMA Load process automatically upon receipt of the RMA Load EIP, select the Flag1 option on the Data Maint Setup1 page. If you do not select this option, you must establish run control parameters on the Run RMA Load page.
The logic for the RMA Load transaction is similar to that in PeopleSoft Inventory's online RMA Form component, with these exceptions:
The RMA Load transaction does not process projects, ChartFields, or RMA notes and attachments.
You can only change address information for external customers.
PeopleSoft delivers the service operations in PeopleSoft Integration Broker with a default status of Inactive. You must activate each service operation before attempting to send or receive data from a third-party source or another PeopleSoft system, such as CRM.
| Service Operation | Direction and Type | Handlers | Chunking Available? | Integrates With |
RMA_LOAD |
Inbound Asynchronous |
RMALoad |
No |
Third-party system |
Run RMA Load Page
Use the Run RMA Load page (RUN_RMA_LOAD) to define parameters for the RMA Load process.
Navigation:
The RMA Load process validates data that is received through the RMA Load EIP and inserts it into the RMA system tables. You can run this process manually using the Run RMA Load page, or you can set up the system to run it automatically upon receiving the RMA Load EIP.
| Field or Control | Description |
All EIP_CTL_IDs |
Select to load data from all RMA Load EIP messages in the system. |
From and To |
Enter the appropriate IDs to load data from specific EIP control IDs or from a range of IDs. |
RMA Load EIP Maintenance Page
Use the RMA Load EIP Maintenance page (RMA_EIP_MAINT) to view error details about RMA Load EIP transaction and edit the fields for specific segments of the RMA Load EIP data.
Navigation:
Click the Show Detail Entry button next to a transaction on the Data Definition Maintenance page for a message for the RMALOAD transaction type .
If the PeopleSoft system finds errors during validation of the RMA Load EIP, it stages the data to the transaction error tables. You can then use the RMA Load EIP Maintenance pages to correct the errors and resubmit the data for processing. If you elected to run the RMA Load process automatically upon receipt of the RMA Load EIP transaction, you can resubmit the data directly from these maintenance pages by clicking Apply; otherwise, you must initiate the process using the Run RMA Load page.
The scroll area lists each record and field that is in error, along with a message describing the problem.
Click the Show Detail button next to a record to correct the error.
Click the links at the bottom of the page to modify the fields that are included in each segment of the transaction.
RMA Purge (process) Page
Use the RMA Purge (process) page (RUN_IN_INBOUND_PRG) to purge RMA load transaction data.
Navigation:
Run the RMA Purge process (IN_INB_PURGE) to delete RMA transaction data from the transaction staging tables (RMA_EIP and EO_EIP_CTL).
Inbound Data to Purge
Indicate which RMA Load transactions you want to purge.
