Navigating in PeopleSoft IT Asset Management
PeopleSoft IT Asset Management provides custom navigation center pages that contain groupings of folders that support a specific business process, task, or user role.
In addition to the PeopleSoft IT Asset Management custom navigation center pages, PeopleSoft provides menu navigation, and standard navigation pages.
See the product documentation for PeopleTools: Applications User's Guide
Pages Used to Navigate in PeopleSoft IT Asset Management
These tables list the custom navigation pages that are used to navigate in PeopleSoft IT Asset Management.
IT Asset Definitions Center
The IT Asset Definitions Center custom navigation pages are geared to the person in the organization who is focused on setup and configuration.
| Page Name | Navigation | Usage |
IT Asset Definitions Center |
Main Menu, IT Asset Definitions Center |
Access primary Asset Definitions Center menu options and activities. |
Application Settings |
Click Application Settings on the IT Asset Definitions Center page. |
Access the Business Rules, User-Defined Fields, Inventory Age, Rule Attributes and Edit Progress Report Template pages. See Understanding PeopleSoft IT Asset Management Application Settings. |
External Settings |
Click External Settings on the IT Asset Definitions Center page. |
Access the Code Mappings, IP Addresses, IP Locations, Contract Types, IT Subtypes, and Supplier pages. See Understanding PeopleSoft IT Asset Management External Settings. |
Resource Settings |
Click Resource Settings on the IT Asset Definitions Center page. |
Access the Device Groups, Notification Options, IT Role Access, Employee Network IDs, Employee Groups, Define User Preferences, Common Search Configuration, and Related Links Definition pages. See Understanding PeopleSoft IT Asset Management Resource Settings. |
IT Asset Management Center
The IT Asset Management Center custom navigation pages are geared to the person in the organization who is focused on financial and tracking functions.
IT Asset Management Center |
Main Menu, IT Asset Management Center |
Access primary Asset Management Center menu options and activities. |
Asset Discovery and Validation |
Click Asset Discovery and Validation on the IT Asset Management Center page. |
Access the Request Discovery Data, View Request Status, View Integration Data Errors, Integrate Discovery Data, Related Links, Compare Asset Repositories, Manage Exceptions, Manage Assets Not Reporting, Manage Physical Use, View Ignored Exceptions, View Action Log, View Action Errors, and View Asset Log pages. |
Software Attributes |
Click Software Attributes on the IT Asset Management Center page. |
Access the Define Software Titles/Users, Declare Device Licenses, Resolve Device Licenses, Associate SKU/Software Title, Define Software Contract, and Define Software Inventory pages. |
Asset Add, Find and Print |
Click Asset Add, Find and Print on the IT Asset Management Center page. |
Access the Basic Add, Express Add, Print an Asset, and Search for an Asset pages. See PeopleSoft Asset Management: Understanding Adding and Maintaining Assets. See PeopleSoft Asset Management: Defining Asset Operational Information. |
Portal Setup |
Click Portal Setup on the IT Asset Management Center page. |
Access the Generate Metrics, Edit Progress Report Template, and Run Progress Report pages. See PeopleSoft Financials, ESA, ALM, and SCM Portal Packs: Understanding Reporting Metrics |
Inventory Views |
Click Inventory Views on the IT Asset Management Center page. |
Access the Hardware Inventory, Discovered Software Inventory, Software License Inventory, Software Device Inventory, and Progress Report Detail pages. |
Financial and Leases |
Click Financial and Leases on the IT Asset Management Center page. |
Access the Financial List Inquiry, View IT Financial Statistics, Lease Summary by Lessor, Lease Details, and Financial List Archive pages. |
Click IT Asset Definitions Center on the IT Asset Management Center page. |
Access pages to set up and configure IT Asset Management. |
IT Asset Manage Exceptions Trend
The Manage Exceptions Trend Chart provides a graphical representation of Manage Exceptions trends over a rolling twelve-month period. As you resolve the Business Rule exceptions from the Manage Exceptions page, the number of exceptions are recorded for each Business Rule where Trend Analysis is enabled.
Page Name |
Navigation |
Usage |
Manage Exceptions Over Time |
IT Asset Management, Manage Exception Trend Chart, Manage Exceptions Over Time |
Access the Manage Exceptions Over Time page to view a graphical representation of the number of business rule exceptions over time. Select to view as either a two dimensional bar graph or a line graph. Additionally, select to view data as daily, monthly or quarterly totals. Variances from the same period in the prior year appear when placing the cursor on a data point. |
