Approving Work Orders Using PeopleSoft Fluid User Interface
This section discusses approving work orders using the PeopleSoft Fluid User Interface.
Pages Used to Approve Work Orders Using PeopleSoft Fluid User Interface
Pending Approvals - Work Order Page (List)
EOAWMA_MAIN_FL
Review and approve multiple work orders.
Work Order Page
EOAWMA_TXNHDTL_FL
Review and approve a single work order.
Use the Pending Approvals - Work Order page (EOAWMA_MAIN_FL) to review and approve multiple work orders.
Navigation:
Employee Self Service, and then Approvals
On the Pending Approvals page, select Work Order in the left pane.
This example illustrates the fields and controls on the Pending Approvals - Work Order list page. You can find definitions for the fields and controls later on this page.
List of Work Orders Pending Approvals
This example illustrates the fields and controls on the Pending Approvals – Work Order list page as displayed on a smartphone. You can find definitions for the fields and controls later on this page.
List of Work Orders on a smartphone
The number in the left pane indicates the total number of work orders pending for approval. You can review the header information for the work orders currently routed for approval. A work order displays the total estimated cost, currency code, business unit, work order ID, requester’s name, and routed date.
You can select one or multiple work orders on this page and perform a mass action (approve or deny) on the selected work orders. To access a work order’s details, select the particular row.
Field or Control Description
Approve or Deny
Select to approve or deny work orders. These buttons are enabled only if you select one or more work orders.
Approver Comments
Enter comments in the text entry field.
Oracle PeopleSoft delivers Notification Composer Framework to manage the setup and administration of notifications in one central location. Once you have adopted the Notification Composer feature, you must use it to create new notifications and manage your existing notifications.
For more information about Notification Composer Framework, see Enterprise Components: Understanding Notification Composer.
Work Order Page
Use the Work Order page (EOAWMA_TXNHDTL_FL) to review and approve a single work order.
Navigation:
Select a work order from the list of pending work orders on the Work Order list page.
This example illustrates the fields and controls on the Work Order page. You can find definitions for the fields and controls later on this page.
Work Order Details Page
Work Order Page on a Smartphone
Approve or Deny
Perform an action on the work order by selecting an approval action button. Upon selecting an action, you have the option to select Submit to continue the action, or Cancel to back out of the action. Upon submitting the action, the system generates a message that the action is successful.
Select Deny to reject the work order and send it back to the requester.
Approver Comments
Approval Chain
Select to review approval chain information. You can expand or collapse approver information for each line by selecting the Expand/Collapse icon. You can also select the approver name to view approver details.
The approval chain reflects approval status generated by the Approval Framework. For more information, see the product documentation for the PeopleSoft Approval Framework. See also Approval Framework: Understanding Transaction Approval Flows.
