Labor Assignment Workbench Page
Use the Labor Assignment Workbench page (WM_LABOR_ASSIGN_WB) to review crew member and non-crew member availability in order to make labor assignments to schedule rows.
Navigation:
Maintenance Management, and then Workbenches, and then Labor Assignment Workbench, and then Labor Assignment Workbench
Field or Control Description
Action
Select the labor schedule rows to which you want to apply this action and select one of these available actions:
  • Assign Resource
    The to Employee ID field will appear.
    Select an employee ID to assign to the selected rows. This action updates the Employee ID field on the Assignments tab of the workbench for each selected row.
  • Cancel Assignment
    Selecting this action cancels previously saved assignments to selected rows. It also clears unsaved assignments to selected rows.
  • Change Schedule End Dt/Tm (change schedule end date/time)
    The to (date) and (time) fields appear.
    Select the date and time to update the Scheduled End Date and End Time fields for each selected row on the Schedules tab of the workbench.
  • Change Schedule StartDt/Tm (change schedule end date/time)
    Select the date and time to update the Scheduled Start Date and Start Time fields for each selected row on the Schedules tab of the workbench.
  • Change Status
    A field appears in which you can select a user-defined task status that is set up to match an internal task status. When you select a task status from the list to change the task status for selected rows, the system verifies whether the change is valid. Values are:
    • Open
    • Awaiting Schedule
    • Hold
    • Scheduled
    • Work in Progress
    • Canceled
    • Complete
    • Closed
    Use the Change Status page to notify the scheduler of the status change.
    Note: Selecting a task status displays the Change Status page for the selected rows. If you selected multiple rows for the same task, only one row representing all of these rows will appear on the Change Status page. When you change the status of this row, the system changes the status of all of the rows associated with the task, whether you selected them or not. When you select OK, you are returned to the Labor Assignment Workbench.
Go
Click this button to apply the action to the selected rows.
Note: The Availability grid is updated based on the action you perform. If you enter data outside the date range of the Availability grid, then the grid does not show the change. If you change the schedule date or hours for which an assignment is not yet made, then the grid does not show the change.
Save
Click this button to save the Labor Assignments Workbench page, which updates the Labor Schedules rows in the work order. It also updates the resource calendar with the new assignments.
Refresh
Click this button to refresh changes made in the Assignments grid and update the Availability grid. This action causes deferred processing on field changes to proceed.
