Processing Kit Issues and Returns Using Electronic Data Collection
You can use electronic data collection to process kit issues and returns.
You can process kit issues and returns for these electronic data collection transactions:
  • 060A - Kit Issue to Production
  • 060R - Kit Return from Production
  • 060S - Kit Issue Substitute to Prdn
Pages Used to Process Kit Issues and Returns Using Electronic Data Collection
Kit Issue/Return Page
BCT_MG_MIS
Enter issue or return transactions for kit components using electronic data collection.
Kit Issue/Return background process Page
BCT_MG_REQMISC
Continuously scan the electronic data collection transaction log as long as there are kit issue or return transactions in the log.
There must be transactions in the electronic data collection transaction log.
Use the Kit Issue/Return page (BCT_MG_MIS) to enter issue or return transactions for kit components using electronic data collection.
Navigation:
SCM Integrations, and then Create Transactions, and then Manufacturing, and then Kit Issues/Returns, and then Kit Issue/Return
Field or Control Description
Component ID
Enter the value of the component to be issued, returned, or substituted.
Sub Item (substitute item)
If you're substituting a component using transaction 060S, enter a value.
Quantity and Yield Loss Qty
Enter values to be issued, returned or substituted. These values must be positive numbers, even if you're returning material.
Container ID or Storage Area
Enter the location from which you issued the material.
Storage Location Search Button
Click the Storage Location Search button to select a different storage location.
If you're issuing consigned kit issue components, including lot and serial-controlled components, you can pick from both owned and non-owned WIP storage locations.
Serial ID or Lot ID
The system displays the values, if applicable.
See Processing Kit Issues and Returns.
Quantity
This value is display-only for serial-controlled items.
The format for several quantity fields on this page may be determined by the item's unit of measure and quantity precision combination that is defined in PeopleSoft Inventory.
Use the Kit Issue/Return background process page (BCT_MG_REQMISC) to continuously scan the electronic data collection transaction log as long as there are kit issue or return transactions in the log.
Navigation:
SCM Integrations, and then Process Transactions, and then Manufacturing, and then Process Kit Transactions
Important:
If no transactions are in the log when a process scans the log, the process terminates. It can be restarted by the Process Scheduler. Use the Process Scheduler with the background process to ensure that it runs continuously.
Process Frequency
Because the background processes for electronic data collection run continuously and you use the Process Scheduler to restart the background processes, this value should be set to Always.
Run
Click to run this request. Process Scheduler runs the Production Misc Issues/Returns process (SFPFMISC) at user-defined intervals.
