Viewing Work Center Where-Used Data
Using the Review Work Center Where Used component, you can view the tasks, routings, and production that are associated with a selected work center. On all pages in this component, you can control the data and pages that you see by changing the Search field selection. Initially, the page automatically displays the choice that mirrors the page; for example, the value is initially Only Tasks for the Work Centers Used on Tasks page. You can change this to Search All or to search for Only Tasks, Only Routings, or Only Production.
If you select Select All after entering the business unit and work center, the system populates all pages in this group with data. If you select only the default, the system populates only the current page with data, after you click the Search button.
If you select something other than the default or Search All, you access the page that corresponds with your choice. For example, if you are on the Work Centers Used on Tasks page and you select Only Routings, you access the Work Centers Used on Routings page. Then, click the Search button to view the routings that are associated with a specific work center. You can change the selected options, which appear by default from the previous page, before you click Search.
  • View work centers used on tasks.
  • View work centers used on routings.
  • View work centers used in production.
Pages Used to View Work Center Where-Used Data
Used on Tasks inquiry Page
EN_WC_WHERE_TASK
View tasks associated with a specific work center.
Work Center Where Used - Used on Routings (inquiry) Page
EN_WC_WHERE_RTG
View routings whose operations use a specific work center.
Work Center Where Used - Used in Production Page
EN_WC_WHERE_PRD
View production IDs or production schedules that use a specific work center.
Work Centers Where Used Report Page
RUN_ENS1006
Generate the Work Centers Where Used report (ENS1006).
Use the Used on Tasks inquiry page (EN_WC_WHERE_TASK) to view tasks associated with a specific work center.
Navigation:
Manufacturing Definitions, and then Resources and Routings, and then Tasks and Work Centers, and then Review Work Center Where Used, and then Used on Tasks
Select the Subcontracted check box if the task is a subcontracted operation.
Select the Count Point check box if the operation step is a count point. Count points enable you to record assembly completion information at preset operations. The default for this field comes from the Define Task - Definition page or the Routing Definition - Summary page.
Used on Routings inquiry Page
Use the Used on Routings inquiry page (EN_WC_WHERE_RTG) to view routings whose operations use a specific work center.
Navigation:
Manufacturing Definitions, and then Resources and Routings, and then Tasks and Work Centers, and then Review Work Center Where Used, and then Used on Routings
Field or Control Description
Rtg State (routing state)
Values are:
  • PR (production)
  • EN (engineering)
Routing Types
Values are:
  • PR (production
  • TR (teardown)
  • RW (rework)
Routing
Indicates whether this routing is the primary (routing code 1) or an alternate routing (routing codes 2-99) for the routing type
Op Seq (operation sequence)
Indicates the operation step that uses the work center.
Use the Work Center Where Used - Used in Production page (EN_WC_WHERE_PRD) to view production IDs or production schedules that use a specific work center.
Navigation:
Manufacturing Definitions, and then Resources and Routings, and then Tasks and Work Centers, and then Review Work Center Where Used, and then Used in Production
The system displays all production that uses the work center. It segregates production information by those items in a production area—using production IDs and the items that are managed by production schedules. In the case of production IDs, it displays the production IDs that have an operation that uses the work center. For all other production, the system displays the production area and the item ID in which it is produced. In both cases, it displays the operation sequence along with the operation's status, start date, start time, due date, and due time.
