Performing Picking Feedback Using the PeopleSoft Fluid User Interface in Mobile Inventory Management
This topic discusses how to perform a mobile picking feedback search, retrieve pick batch line details, and add or update pick lines.
Pages Used to Perform Picking Feedback in Mobile Inventory Management
Use these pages to perform picking feedback.
Page Name Usage
Picking Feedback - Fluid Search Page
Perform a picking feedback search.
Picking Feedback - Fluid Single or Multi Item Page
View, update or add, pick lines associated with a pick batch ID.
Picking Feedback - Fluid Add Item Page
Pick items from a different storage location for the current item order line.
Use the Picking Feedback - Fluid Search page to perform a search.
Navigation:
Mobile Inventory, and then Picking Feedback and click the Search button.
This example illustrates the fields and controls on the Picking Feedback - Fluid Search page. You can find definitions for the fields and controls later on this page.
Field or Control Description
Business Unit
Displays the default business unit established for the user. You can select another business unit in which to search for picking feedback.
Pick Batch ID
Enter a pick batch ID.
Demand Source
Select a source from the drop-down list.
Source Business Unit
Enter a source business unit.
Order No
Enter the order number.
Order Line
Enter line information.
Ship To Customer
Enter the ship-to customer location associated with picking feedback.
Location Code
Enter location information.
Load ID
Enter the load ID.
Carrier ID
Enter carrier information.
Route Code
Enter route information.
Route Group
Enter route group information.
Use the Picking Feedback - Fluid Single or Multi Item page to view, update or add pick lines associated with a pick batch ID.
Navigation:
Mobile Inventory, and then Picking Feedback and select a Pick Batch ID.
This example illustrates the fields and controls on the Picking Feedback - Fluid Grid Mode Page . You can find definitions for the fields and controls later on this page.
Picking Feedback - Fluid Grid View Page
Item ID
Displays the PeopleSoft Inventory item ID, Description and Serial or Lot ID information.
Order Quantity
Displays the requested quantity and order UOM as on order.
Location Quantity
Displays the quantity picked and storage UOM for the given storage location. This is an editable field.
Confirm
Select to confirm the item on row.
Confirm All
Select to confirm items on all rows of the page.
Note: This option is displayed only when group by location is selected.
Mark a Location Quantity lesser than the Order Quantity and select Confirm to access the Picking Feedback — Fluid Add Item Page.
This example illustrates the fields and controls on the Picking Feedback - Fluid Single Item Mode page. You can find definitions for the fields and controls later on this page.
Picking Feedback - Fluid Single Item View Page
Click an Item ID link in grid view mode to display the item in Single Item mode. Click the Pick and Modify buttons to display prior entered data and modify such data respectively.
This example illustrates the fields and controls on the Picking Feedback - Fluid List Mode page . You can find definitions for the fields and controls later on this page.
Picking Feedback - Fluid List View Page
Use the Picking Feedback - Fluid Add Item page to pick items from a different storage location for the current item order line.
Navigation:
Mobile Inventory, and then Picking Feedback and select the Confirm check box on the grid and list view pages or click the Pick button on the single item page.
You must assign a lower value in the Location Quantity field as against that in Order Quantity.
This example illustrates the fields and controls on the Picking Feedback - Fluid Add Item page. You can find definitions for the fields and controls later on this page.
Remaining Quantity
Displays the Order Quantity that remains to be fulfilled.
UOM Conversion
Displays the Order UOM equivalent in Storage Location conversion type.
