Enabling the Search Framework Search Engine
This topic discusses how to enable the Search Framework search engine for use with PeopleSoft Order Management.
Page Used to Enable the Search Framework Search Engine
Order Management Installation Options Page
INSTALLATION_OM
Enable Search Framework Search Engine for the sales order.
Use the Order Management Installation Options page (INSTALLATION_OM) to enable Search Framework Search Engine for the sales order.
Navigation:
Setup Financials/Supply Chain, and then Install, and then Installation Options
Click the Order Management link.
Field or Control Description
PTSF
Select to enable Search Framework for Order Management.
Note: When this option in selected, Search Framework is enabled in addition to the PeopleTools standard search. If PTSF is not selected, only the PeopleTools standard search is available.
