Setting Up Rate Sets and Asset Integration Rules
You use pages in PeopleSoft Maintenance Management and PeopleSoft Project Costing to set up the integration. This topic discusses the setup pages that are in PeopleSoft Project Costing only.
Pages Used to Set Up Rate Sets and Asset Integration Rules
| Page Name | Definition Name | Usage |
PC_RATE_DTL |
Enter a row with an analysis type that is specified in the Mobile Time / Expense field on the Installation Options - Project Costing Integration page, which enables you to select the WBI and WCO rate options for work order-managed projects on the Rate Sets - Target page. |
PC_RATE_DTL_LN |
Select the WCO and WBI rate options to price transactions by using the cost and bill rates that are defined on the work order task. Select the TCO and TBI rate options to price transactions by using the cost and bill rates that appear on the Technician Workbench - Tools Usage page for actual tools usage. |
PC_AM_RULE_BU |
Select the Derive from Work Order Task asset identification rule option to enable the Express Capitalization process at the business unit level. |
Project Definitions - Asset Integration Rules Page |
PC_AM_RULE_PRJ |
Select the Derive from Work Order Task asset identification rule option to enable the Express Capitalization process at the project level. |
Activity Definitions - Asset Integration Rules Page |
PC_AM_RULE_ACT |
Select the Derive from Work Order Task asset identification rule option to enable the Express Capitalization process at the activity level. |
