Understanding the PeopleSoft Project Costing Pages Used in Work Order Business Processes
This table summarizes the PeopleSoft Project Costing application pages that work order business processes use:
| Project Costing Application Pages and Processes | How the Page or Process Is Used in Work Order Business Processes |
Asset Integration Rules page |
Use this page to select the Derive from Work Order Task asset identification rule option to enable the Express Capitalization process to identify the transaction rows in activities that belong to assets. Additionally, the system automatically updates certain fields on this page during the life of a work order-managed project, such as:
Define Assets page |
Use this page to view the details of asset definitions that are associated with work order-managed projects. |
Relate by Project page |
Use this page to view the details of the relationship of assets to projects for assets that are associated with work order-managed projects. |
Project Definitions - General Information page |
Use this page to designate the project as a work order-managed project, which indicates that the project is managed with work orders in PeopleSoft Maintenance Management, instead of by a project manager in PeopleSoft Project Costing. Additionally, you can click links in the More drop-down list box on the Project Definitions - General Information page to access:
Project Costing Activity Definitions - Team page or Program Management Resources by Activity page |
On this page you can click a button to access the Create Work Order page to create a work order in PeopleSoft Maintenance Management for this project activity. |
Create Work Order page |
Use this page to create a work order from a Project Costing-managed project activity. See Creating Work Orders and Work Order-Managed Projects in PeopleSoft Project Costing. |
Work Orders page |
View a list of all work orders that are associated with a Project Costing-managed activity and drill into each individual work order. |
Show All Transaction Details page |
View the work order business unit, work order number, task number, resource type, and resource line number for a transaction. |
Express Retirement Process page |
Use this page to run the Express Retirement Application Engine process (PC_EXPRET_AM) to send assets that are associated with work order-managed projects to the PeopleSoft Asset Management Loader table and (optionally) to the PeopleSoft Asset Management production tables. |
Maintenance Management Tools Usage page |
Use this page to run the Maintenance Management Tools Usage process to price eligible tools usage transactions for costing or billing. |
Pricing process |
This Application Engine process calculates labor and tools usage cost and billing amounts by using the work order labor and tools usage cost rates and bill rates. Additionally, the process holds transactions that are associated with work order-managed projects so that the Process Project Accounting process does not process them until the work order task closes. |
