Using Work Management in the Projects WorkCenter
The PeopleSoft Fluid Projects WorkCenter can optionally use the Work Management Framework, which is an Enterprise Components feature.
This topic discusses how to setup up Work Management for the Projects WorkCenter and provides an example for one delivered Setup and Maintenance Exception: Missing Project Fields.
Understanding Work Management in the Projects WorkCenter
The purpose of the Work Management Framework is to view and manage exception transactions when they appear in the My Work section of the WorkCenter.
It is important to understand the Work Management Framework from a high-level perspective before applying it to PeopleSoft Project Costing. Please review Enterprise Components: Understanding the Work Management Framework prior to reading the following information.
The Work Management Framework provides actions and filters to My Work pagelets to assist users with managing a large list of transactions. Users may assign a specific transaction to themselves, defer the transaction for follow-up to a later date, or mark a transaction as not an exception (inactive). Filters allow the user to view transactions not yet assigned to anyone, transactions assigned to themselves, inactive transactions, or a full list of all transactions. You can also view a history of actions taken on the transaction.
Setting Up Work Management for the Projects WorkCenter
This list provides the steps to setup the optional Work Management feature for the Projects WorkCenter:
  1. Use the EOXC_USER role access the Work Management setup pages.
  2. Access the Enterprise Components: Work Management Link ID's Page.
  3. Search for Link ID corresponding to the My Work section for Projects WorkCenter where you want to use the Work Management feature.
    Link IDs corresponding Projects WorkCenter - My Work, Setup and Maintenance Exceptions are:
    Link ID Description
    PC_ACTIVE_PAST_PROJECT
    Expired Projects with Active Status
    PC_MISSING_PRJ_FLDS
    PC_MISSING_PRJ_USRFLD
    Missing Project User Fields
    PC_MISSING_PRJ_MGRS
    Missing and Inactive Project Managers
    PC_INACTIVE_PRJ_EMPL
    Inactive Project Team Members
    Link IDs corresponding Projects WorkCenter - My Work, Recurring Tasks are:
    Link ID Description
    PC_WC_MASS_BP_FINALIZE
    Budgets to Finalize
    PC_WC_DEF_ROWS
    Deferred Billing
    PC_PRJ_COMPRESS
    Project Data Compression
  4. Select the View button to access the Enterprise Components: Enable Work Mgmt Exception Page.
  5. Select the Enable option to activate the Work Management feature for that Link ID.
  6. Follow instructions in the Enterprise Components documentation for the Enterprise Components: Enable Work Mgmt Exception Page to complete your setup.
Pages Used to Manage Work in the Projects WorkCenter
Projects WorkCenter Page - Missing Project Fields (Work Management Enabled)
PC_WC_PRJ_FL
Access and manage projects with missing location and type.
Use the Projects WorkCenter page when Work Management is enabled to access and manage a list of projects with blank location or project type.
Navigation: Project Management, and then Projects WorkCenter (Tile).
This example illustrates the fields and controls on the Projects WorkCenter - Missing Project Fields page when using Work Management.
Projects WorkCenter - Missing Project Fields (Work Management)
When Work Management is enabled for an exception, there are two changes on the WorkCenter page:
  • The View drop-down box appears above the grid.
  • Additional action options are added to the Actions button.
The actions for Missing project Fields are Update project Type and Open Project. When Work Management is enabled, additional actions are available depending on the option selected in the View field: See Enterprise Components: Understanding the Work Management Framework, Actions by View section.
