Setting Up PeopleSoft Purchasing Entry Events
This section discusses how to Set Up PeopleSoft Purchasing Entry Events.
Pages Used to Set Up PeopleSoft Purchasing Entry Events
Ledgers for a Unit - Definition Page
BUSINESS_UNIT_LED1
Select the general ledger detail ledger group for which you want to enable commitment control.
Ledgers for a Unit - Commitment Control Options Page
BUSINESS_UNIT_LED5
Enable commitment control for a business unit and general ledger detail ledger group.
Entry Event Page
INSTALLATION_EE
Select purchasing entry events for purchase orders, requisitions, and procurement cards.
Entry Event Defaults Page
BUS_UNIT_PM_EE
Select default entry events at the business unit level.
The link does not appear unless entry events are enabled.
Entry Event Page
Use the Entry Event page (INSTALLATION_EE) to select purchasing entry events for purchase orders, requisitions, and procurement cards.
Navigation:
Set Up Financials/Supply Chain, and then Install, and then Installation Options
Click the Entry Event link in the General Options group box.
Field or Control Description
Purchasing
Select the entry event option for PeopleSoft Purchasing. Values are:
  • No EE (no entry event): Entry events cannot be used. Entry event fields will be hidden.
  • Optional: Entry events can be used but are not required. Entry event fields appear. Default entry event codes appear.
  • Required: You must use entry events. If the Entry Event field appears on a page, you must select a value or an error appears when you save the page.
Use the Entry Event Defaults page (BUS_UNIT_PM_EE) to select default entry events at the business unit level.
Navigation:
Setup Financials/Supply Chain, and then Business Unit Related, and then Purchasing, and then Purchasing Definition
Click the Entry Event Defaults link on the Purchasing Definition - Business Unit Definition page.
Select from the available options to choose default entry event codes for purchase orders, requisitions, and procurement cards. Before selecting a default, you may need to review the defined codes.
