Using Spending Regions
This section discusses how to use spending regions.
Pages Used to Use Spending Regions
| Page Name | Definition Name | Usage |
SPNDNG_REG_DEF |
Capture spending by region for PeopleSoft Payables transactions. |
Spending Region Definition Page
Use the Spending Region Definition page (SPNDNG_REG_DEF) to capture spending by region for PeopleSoft Payables transactions.
Navigation:
| Field or Control | Description |
SetID |
Select one SetID or multiple SetIDs to establish a ChartField relationship for the given state. |
ChartField Value |
Select a ChartField value that was previously defined on the Spending Region Install Option page. |
