Viewing Alarms Using PeopleSoft Workflow
This topic discusses how to view Alarms using PeopleSoft workflow.
Pages Used to View Alarms Using Workflow
| Page Name | Definition Name | Usage |
QS_START_WF |
Initiate the Start Alarm Workflow Application Engine process (QS_ALM_WF) that takes generated alarms and posts alarm entries to the worklist or generates emails to notify appropriate individuals of the alarms. |
QS_ALM_WF_DET |
View alarms that were generated from the Start Alarm Workflow process. |
Related Topics
Start Alarm WorkFlow Page
Use the Start Alarm Workflow page (QS_START_WF) to initiate the Start Alarm Workflow Application Engine process (QS_ALM_WF) that takes generated alarms and posts alarm entries to the worklist or generates emails to notify appropriate individuals of the alarms.
Navigation:
You must have previously entered data against a subgroup and generated alarms before starting the process. The process takes previously generated alarms and posts them to appropriate individual worklists or notifies them using email.
You should schedule this process as a recurring process to ensure uninterrupted dispatch of alarms to the worklists.
Alarm Detail Page
Use the Alarm Detail WF page (QS_ALM_WF_DET) to view alarms that were generated from the Start Alarm Workflow process.
Navigation:
You must have previously entered data against a subgroup and generated alarms. You can use this page only if you incorporated Workflow into Quality. To review a session, click an alarm entry on the worklist.
This page is similar to the Review Alarms - Alarm Detail page.
Access this page only through worklist.
Related Topics
