Prerequisites for Running the Aging Process
Before you run the Aging process:
Set up aging IDs.
Assign an aging ID to a business unit.
Assign an aging ID at the customer level.
Set up system-defined history IDs to be used by the aging process.
Set up parallel processing.
You should also apply all of your payments to items and run the Receivables Update Application Engine process (ARUPDATE).
