Approving Sourcing Plans Using PeopleSoft Fluid User Interface
This topic provides an overview of the self-service approval pages for sourcing plans, and how to access these pages using the PeopleSoft Fluid User Interface. PeopleSoft builds the mobile approval pages on the Enterprise Component Fluid Approvals framework.
Pages Used to Approve Sourcing Plans Using PeopleSoft Fluid User Interface
Pending Approvals - Sourcing Plans Page (List)
EOAWMA_MAIN_FL
View a list of pending sourcing plans.
For more information, see the overview of approvals on the PeopleSoft Fluid User Interface: Application Fundamentals: Pending Approvals Page.
Sourcing Plans Page
EOAWMA_TXNHDTL_FL
Review header details for a single sourcing plan, and approve or deny an plan depending on role criteria.
For more information, see the Application Fundamentals: Approval Header Detail Page.
Understanding Sourcing Plans Using the PeopleSoft Fluid User Interface
PeopleSoft provides mobile approvals using the Enterprise Component Fluid Approvals framework. Approvers can take Application Workflow Engine (AWE) actions on select PeopleSoft transactions pending their approval using a smart phone. The tablet version is also available for desktop use.
Sourcing plan workflow enables users to approve plans, if approval is required for a sourcing plan. Once the sourcing plan has been submitted for approval, the Application Workflow Engine runs the sourcing plan through the defined approval process. For information about the approval process for sourcing plans, see Approving Strategic Sourcing Project Plans.
Using the PeopleSoft Fluid User Interface, approvers can view a list of pending approvals for various types of transactions, and add comments on the centralized Pending Approvals page. Each approver in the workflow selects an appropriate action, such as Approve, Deny within the approval pages.
Sourcing plan approvals also support push notifications, a framework delivered in PeopleTools. The flag icon in the Oracle banner shows a counter for new push notifications. Note that the counter disappears once you view the push notification list. The notification link takes you directly to the header approval page for items awaiting your approval.
Use the Pending Approvals - Sourcing Plans list page (EOAWMA_MAIN_FL) to view a list of pending sourcing plans.
Navigation:
Employee Self Service, and then Approvals
On the Pending Approvals page, select Sourcing Plans in the View By - Type pane to view the sourcing plans available for approval in the right pane.
Smartphone: On the Pending Approvals - View By Type page, select Sourcing Plans to open a new page that lists the sourcing plans available for approval.
This example illustrates the fields and controls on the Pending Approvals - Sourcing Plans Page (List) page. You can find definitions for the fields and controls later on this page.
This example illustrates the fields and controls on the Pending Approvals - Sourcing Plans list page as displayed on a smartphone. You can find definitions for the fields and controls later on this page.
Field or Control Description
Show or Hide Filters tab
Select this button to expand or collapse the View By Type page.
From this list page, you can do the following:
  • Review basic information for the sourcing plans currently routed for approval. To access header details for a particular plan, select an plan row.
  • Use the filter to narrow results on the page. For more information about using the filter, see the Application Fundamentals: Filters Page.
Oracle PeopleSoft delivers Notification Composer Framework to manage the setup and administration of notifications in one central location. Once you have adopted the Notification Composer feature, you must use it to create new notifications and manage your existing notifications.
For more information about Notification Composer Framework, see Enterprise Components: Understanding Notification Composer.
Sourcing Plans Page
Use the Sourcing Plans page (EOAWMA_TXNHDTL_FL) to review header details for an plan, and approve or deny an plan, depending on role criteria.
Navigation:
Select an sourcing plan in the list on the Pending Approvals - Sourcing Plans list page.
This example illustrates the fields and controls on the Sourcing Plans page. You can find definitions for the fields and controls later on this page.
Sourcing Plans page
This example illustrates the fields and controls on the Sourcing Plans (Line Detail) page. You can find definitions for the fields and controls later on this page.
Sourcing Plans page as displayed on a smartphone
Sourcing Plan Details
Select this link to open the Define Sourcing Plan Basics page in the classic interface.
See Define Sourcing Plan Basics Page in the classic interface.
Approver Comments
Enter comments in the text entry field.
Approval Chain
Review approval chain information. You can expand or collapse approver information for each line by selecting the Expand/Collapse icon.
You can also select the approver name to view approver details.
Approve or Deny
Select an action button.
When you select an action button, you have the option to select Submit to continue the action or Cancel to back out of the action. Upon submitting the action, the system generates a message that the action is successful.
