Delivery Management Workbench-Demand / Container Activities Page
Use the Delivery Management Workbench-Demand / Container Activities page (IN_DLV_DEMAND) to search for unassigned demand lines or shipping containers to assign to existing deliveries or to create a new delivery using the demand information to create the delivery.
Navigation:
  • Inventory, and then Fulfill Stock Orders, and then Delivery Management Workbench, and then Demand / Container Activities -Basic Search
  • Inventory, and then Fulfill Stock Orders, and then Delivery Management Workbench, and then Demand / Container Activities -Advanced Search
  • Click the Demand / Container Activities link at the top of any page in the Delivery Management Workbench.
  • Inventory, and then Fulfill Stock Orders, and then Shipping, and then Shipping/Issues, and then Order Summary. Select the Delivery Workbench link after a Ship ID has been assigned.
  • Inventory, and then Fulfill Stock Orders, and then Shipping, and then Shipping/Issues, and then Order Summary. Select the Delivery Workbench freight option and do not validate the delivery, then save the page.
This example illustrates the fields and controls on the The Delivery Management Workbench-Demand / Container Activities page . You can find definitions for the fields and controls later on this page.
The Demand / Container Activities page of the Delivery Management Workbench is where you can search for demand lines and shipping containers. Use this page to:
  • Add unassigned demand lines and unassigned shipping containers to an existing delivery.
  • Create a new deliver to hold the demand lines and shipping containers that you have selected on this page.
  • Remove demand lines or shipping containers from an existing delivery.
  • Consolidate deliveries.
Field or Control Description
Manage Delivery
Select this link to access the Delivery Management Workbench-Manage Delivery page where you can work with one individual delivery or create a new delivery.
Deliveries
Select this link to access the Delivery Management Workbench-Deliveries page where you can work with one or more deliveries.
Return to Menu
Select this link to access the Delivery Management Workbench- Workbench Navigation Menu page where you can change the PeopleSoft Inventory business unit field for the workbench and access the three main pages of the workbench.
Advanced Search
Click this link to display the extended list of search criteria fields for this page. These search criteria help you find the demand lines and shipping containers to be displayed in the Select for Processing group box.
For a complete list of the search criteria field definitions, see the Common Elements Used in This Section within the Using the Delivery Management Workbench section.
See Common Elements Used in This Section.
Basic Search
Click this link to display the basic search criteria fields for this page. These search criteria help you find the demand lines and shipping containers to be displayed in the Select for Processing group box.
Search
Click this button to initiate a search for demand lines and shipping containers. The system retrieves the shipping containers that are associated to demand lines that match your search criteria. To re-display the search dialog after your initial search, expand the Demand/Container Search Criteria group box.
Clear
Click this button to erase all values in the search criteria fields so that you can create enter new criteria.
The Select for Processing group box displays the demand lines and shipping containers that meet your selection criteria based on either the basic search or the advanced search. The demand lines and shipping containers are displayed in two separate grids on this page.
Demand Action
Perform a delivery action by selecting one or more demand lines or shipping containers, entering a value in this field, and clicking the Save button. Once you have saved the page, you are transferred to the Delivery Management Workbench- Deliveries page where you can view the new or altered deliveries. The demand actions are:
  • Assign and Consolidate: The system assigns the selected demand lines and shipping containers to existing deliveries or to new deliveries as necessary and consolidates deliveries according to the delivery key configuration defined for the PeopleSoft Inventory business unit.
  • Assign to Existing Delivery: The system assigns the selected demand lines and shipping containers to existing delivery IDs matching the demand values to the delivery according the delivery key configuration defined for the PeopleSoft Inventory business unit.
  • Create Deliveries: The system creates new deliveries for the selected demand lines and shipping containers according to the delivery key configuration for the PeopleSoft Inventory business unit.
  • Remove from Delivery: The system removes the selected demand lines and shipping containers from their assigned deliveries.
Message Log
Click to access the Delivery Management Workbench- Message / Error Log page where you can view errors from delivery creation routines generated when this page is saved. This link displays only if there are errors to be viewed.
Clear icon
Select the Clear icon to erase any errors on the Delivery Management Workbench- Message / Error Log page.
Demand Lines
The Demand Lines group box displays independent demand lines that match the search criteria. The Demand Data tab shows relevant information about the demand line, including; Ship To customer ID, item ID, and item description. If a demand line is already assigned to a delivery, then the Delivery ID is displayed; click the Delivery ID link to access the Delivery Management Workbench- Manage Delivery page where you can view the details of this delivery. Click the Order Key link to access the Stock Request inquiry page where you can view the details for this demand line and each demand line in the order. The Shipping Info tab shows the carrier ID, ship via code, scheduled ship date, and the current fulfillment state for the demand line.
Shipping Containers
The Shipping Containers group box displays shipping containers that contain demand lines matching your search criteria. The Container Data tab displays relevant container information like container dimensions, Ship To customer ID, and Ship To location. If a shipping container is already assigned to a delivery, then the Delivery ID is displayed; click the Delivery ID link to access the Delivery Management Workbench- Manage Delivery page where you can view the details of this delivery. On the Shipping Info tab, the system displays general shipping and freight information for the container such as carrier ID, ship via code, scheduled ship date, freight amount, and tracking number.
