PeopleTools 8.62 Prerequisites, Entitled Products, and Restricted Use Licenses
| Product | Subproduct or Functional Area | Licensing Information |
Oracle JDK |
Application Server, Batch Server and Life Cycle Management (LCM) |
Entitled Products and Restricted Use Licenses A license to Oracle PeopleSoft PeopleTools includes a restricted use license for Oracle Java SE, solely for running Oracle PeopleSoft PeopleTools. Support of Oracle Java SE is limited to support of Oracle PeopleSoft PeopleTools. In the above case: (a) Use of the applicable Oracle Java SE edition in the manner or order listed above in this section, shall be pursuant to the terms and conditions applying to your use of the corresponding Oracle PeopleSoft PeopleTools. (b) If you use an Oracle Java SE edition in any other way than as set forth above in this section, your use of Oracle Java SE shall be subject to the terms set forth at: https://java.com/otnlicense. Also see Java SE 21 JDK Third-Party Notices and/or Licenses. |
Oracle JavaScript Extension Toolkit (JET) |
Charting |
Entitled Products and Restricted Use Licenses For a copy of the license, see Oracle JET License. |
PeopleSoft Application Products |
PeopleSoft Update Images (PIs) |
PeopleSoft Update Images (PIs) are comprised of Deployment Packages (DPKs) and are available as VirtualBox and Native OS downloads. The PI deployment includes a pre-configured PeopleSoft application database on an Oracle database platform. PeopleSoft customers are not required to obtain an additional Oracle database license for the PIs used for non-production activities such as maintenance, new feature delivery, and demonstration purposes. The VirtualBox PI uses Oracle cross-platform virtualization software called Oracle VM VirtualBox. The PI is offered with Oracle Enterprise Linux as the guest operating system and with Oracle Database as the RDBMS. The Oracle VM VirtualBox is a fully supported software product from Oracle for which professional support licenses are available. However, Oracle does support all VirtualBox usage with PUM without a professional support license. |
PeopleSoft PeopleTools |
Application Server |
Entitled Products and Restricted Use Licenses The Oracle Tuxedo license included with PeopleTools is a restricted use license that may only be used to run PeopleSoft applications. The use of this Tuxedo license outside of the scope of PeopleSoft applications is not permitted. |
Cloud Manager |
Prerequisite Products PeopleSoft Cloud Manager creates and maintains PeopleSoft environments on Oracle Cloud. For a customer to deploy and use PeopleSoft Cloud Manager, an Oracle Cloud Infrastructure as a Service (Oracle Cloud IaaS) subscription with sufficient capacity is required. A customer using PeopleSoft Cloud Manager is required to have separately purchased licenses for all of the PeopleSoft application products that will be installed/managed by PeopleSoft Cloud Manager for Oracle Cloud. To run PeopleSoft COBOL modules on Oracle Cloud, the customer is required to separately purchase a license for the Rocket Software Visual COBOL for Linux and UNIX for PeopleSoft Compiler product. All PeopleSoft environments provisioned by the PeopleSoft Cloud Manager for Oracle Cloud will require the Oracle Database. Customers may choose a subscription to Oracle Database Cloud Service (DBCS) or Oracle Database Exadata Cloud Service (Exadata Service) to obtain a database license to run their PeopleSoft applications. For development and test environments, a database license may be purchased to use with a PeopleSoft database running on Oracle Cloud IaaS. Customers using PeopleSoft Cloud Manager to deploy PeopleSoft production environments are required to use either a DBCS or Exadata Service subscription for the provisioned database(s). PeopleSoft Cloud Manager can enable the monitoring of PeopleSoft environments on Oracle Cloud through Oracle Enterprise Manager, hosted on-premises. Customers using this monitoring feature must separately purchase licenses for the following products:
This Oracle software product includes the Oracle Database Cloud Backup Module (“ODCBM”). A license to Oracle Database Backup Cloud Service is a prerequisite to use ODCBM. Entitled Products and Restricted Use Licenses As a licensee of PeopleTools, you are entitled to install and configure the PeopleSoft Cloud Manager within Oracle Cloud. The Cloud Manager is an application that can be obtained from Oracle Cloud Marketplace. Cloud Manager ships on top of a PeopleSoft Interaction Hub database; however only Cloud Manager functionality is supported from the PeopleSoft Cloud Manager installation from Oracle Cloud Marketplace. PeopleSoft Interaction Hub functionality is not supported from the Cloud Manager installation. For PeopleSoft Interaction Hub functionality, please separately download and install the PeopleSoft Interaction Hub product. PeopleSoft Cloud Manager requires the use of Oracle Database 19c. As a licensee of PeopleTools, you are granted a restricted use license of Oracle Database Standard Edition 2 for the sole purpose of running PeopleSoft Cloud Manager on Oracle Cloud Infrastructure as a Service (Oracle Cloud IaaS). |
Database Server |
Prerequisite Products PeopleTools supports and provides integration with Oracle Transparent Database Encryption (TDE) technology. TDE is a separately licensed product. TDE is bundled with Oracle Advanced Security Options (ASO). |
Mobile Archive |
Entitled Products and Restricted Use Licenses PeopleSoft application programs include a mobile application archive or library (“Mobile Archive”) based on Oracle Mobile Application Framework Foundation. Your use of the Mobile Archive is limited to the following activities:
With respect to creating a Mobile Application, you acknowledge that you must separately agree to and abide by license terms with the applicable mobile operating system provider and possibly other third parties. For example, for iOS applications, you agree that the Mobile Application, in whole or in part, may not be installed on a mobile device or executed except as incorporated into an iOS application that has been signed using an appropriate Apple-issued certificate that you obtained directly from Apple and that is deployed in full compliance with your agreement with Oracle (including these terms) and license terms set forth in a separate agreement between you and Apple. Any Mobile Application distribution to End Users must be subject to a legally binding end user license agreement (the “EULA”) between you and each End User pertaining to the Mobile Application that must, at a minimum, contain the following terms: a) Include acknowledgements by you and the End User that the EULA is concluded between you and the End User only and that the following apply: i. You are solely responsible for each Mobile Application’s content, maintenance, and support. ii. You are solely responsible for addressing, settling, and discharging any claims of the End User or any third party relating to the Mobile Application or the End User’s possession and/or use of that Mobile Application, including, but not limited to product liability claims; any claim that the Mobile Application fails to conform to any applicable legal or regulatory requirement; any claims arising under consumer protection or similar legislation; and any claims that the End User’s possession and use of that Mobile Application infringes a third party’s intellectual property rights. b) Provide only a non-transferable, terminable license to the End User that prohibits (i) modifying or creating derivative works or (ii) decrypting, decompiling, reverse engineering, disassembling or attempting to derive the Mobile Application source code (unless such actions are expressly permitted by applicable law). c) Notify the End User that the Mobile Application is subject to a restricted license and can be used only in conjunction with the specific Oracle-based solution(s) for which it is designed. d) Provide no limitation of your liability to the End User beyond what is permitted by applicable law. e) Require the End User to comply fully with all relevant export laws and regulations of the U.S. and other applicable export and import laws to assure that the Mobile Application, nor any direct products thereof, is exported, directly or indirectly, in violation of applicable laws. f) State in the EULA your name and address to which any End User questions, complaints or claims with respect to the Mobile Application can be directed. g) State in the EULA that the End User must comply with applicable third-party terms when using the Mobile Application and that third-party components that may be appropriate or necessary for use with the Mobile Application are specified in the documentation for that program (or as otherwise notified by you) and that those third party components are licensed to the End User only for use with the Mobile Application under the terms of the third party license agreement specified in the documentation for that program (or as otherwise notified by you) and not under the terms of the EULA. h) State that the licenses provided in the EULA automatically terminate upon breach of the EULA terms and in addition that the licenses provided in the EULA may be terminated upon notice. i) State that upon termination of the EULA the End User must discontinue all use of the Mobile Application and to delete all copies of the Mobile Application. j) Disclaim in the EULA, to the extent permitted by applicable law, a third party’s liability for (a) any damages, whether direct, indirect, incidental, special, punitive or consequential, and (b) any loss of profits, revenue, data or data use, arising from use of the Mobile Application. k) Designate Oracle as a third party beneficiary. Oracle will have the right to enforce the EULA against the End Users. l) State that your licensors retain all ownership and intellectual property rights in the Mobile Application. You agree to inform Oracle promptly if you are aware of any breach of the EULA. You agree to be financially responsible to Oracle for all damages or losses caused by your failure to include the required contractual terms set forth above in each EULA between you and an End User. |
Oracle Mobile Application Framework Foundation |
Entitled Products and Restricted Use Licenses Oracle Mobile Application Framework Foundation (“MAF Foundation”) is included as a restricted use component. The following sections describe the applicable MAF Foundation usage rights and restrictions. The section titled “MAF Foundation Capabilities That May Be Used” below lists the MAF Foundation capabilities that may be used and what, if any, restrictions apply. The section titled “MAF Foundation Capabilities That May Not Be Used” below lists the MAF Foundation capabilities that may be not used. Any use of the capabilities described in the latter section requires an appropriate quantity of full use licenses for (a) Oracle Mobile Application Framework, or (b) Oracle Mobile Suite and Oracle Mobile Suite Client Runtime. MAF Foundation is the version of Oracle Mobile Application Framework that is restricted for use as described in this document. When MAF Foundation is included as a component within another Oracle product (the “Primary Product”) then, depending on the particular Primary Product, MAF Foundation may be included in the Primary Product, may be separately downloaded from Oracle Software Delivery Cloud, or may be downloaded as an extension to Oracle JDeveloper. JDeveloper is a prerequisite to using MAF Foundation and must be downloaded from Oracle Technology Network (“OTN”); see http://www.oracle.com/technetwork/developer-tools/jdev/downloads/index.html). Notwithstanding any other terms, use of JDeveloper is subject to the OTN license agreement associated with JDeveloper; view the license agreement at http://www.oracle.com/technetwork/licenses/jdev-license-152012.html. Definitions “Application Archive” refers to the MAF Foundation mobile application archive, which is an Oracle proprietary mobile application deployment format that can only be used with Oracle supported development tools. It is not related to or based on any non-Oracle application archive format, including iOS application archives. “Application Executable” refers to a mobile application executable installation file, such as an apk or ipa file. “Application Workspace” refers to a series of files making up the source code of a mobile application developed using MAF Foundation. “Data Control” refers to MAF Foundation mobile application artifacts that provides standard metadata interfaces to business services (such as web services) accessed by the mobile application. “Feature” refers to specific MAF Foundation mobile application artifacts that are the building blocks of a mobile application, where each Feature integrated into the mobile application performs a specific set of tasks. MAF Foundation Capabilities That May Be Used
Any use of these capabilities requires an appropriate quantity of full use licenses for (a) Oracle Mobile Application Framework, or (b) Oracle Mobile Suite and Oracle Mobile Suite Client Runtime. |
MultiChannel Framework |
Prerequisite Products If you are using a Cisco Computer Telephony Integration (CTI) system with the PeopleSoft CTI Java applet console, the assumption is that you already have a functioning and appropriately licensed Cisco system configured at your site. The Cisco Java API is shipped as part of the CTI applet; however, no other Cisco products are shipped with the PeopleSoft system. If you use Cisco CTI, you need a Cisco ICM Central Controller Server installed and configured before you begin installing your PeopleSoft CTI system. Your PeopleSoft application may require an IVR supported by Cisco and capable of passing call data to Cisco. This enables CTI components to attach data to incoming calls. For detailed information about specific PeopleSoft-supported versions, refer to My Oracle Support in the certifications area. |
PeopleSoft Interaction Hub |
Entitled Products and Restricted Use Licenses As a licensee of PeopleTools, you are entitled to install and configure a PeopleSoft Interaction Hub database and use the following restricted set of PeopleSoft Interaction Hub capabilities:
The use of any PeopleSoft Interaction Hub capabilities not listed above requires the purchase of an unrestricted license. As a licensee of PeopleTools, you are authorized to use the following basic “portal” functions included within the base PeopleTools product:
You can easily extend an Application Portal Pack by creating additional pagelets and navigation pages using the portal capabilities included in PeopleTools. |
PeopleSoft Interaction Hub—Demo Database |
Entitled Products and Restricted Use Licenses Third Party Images Provided with Sample Data Restricted Use: This Oracle software product includes sample images from Corbis Corporation (Corbis) and Getty Images (Getty) that are provided for Oracle's demonstration purposes only. The images and their respective owners are listed in the PeopleSoft Portal Solutions 9.1 documentation for PeopleSoft Interaction Hub: Portal and Site Administration. You do NOT receive a license to use the images under your agreement with Oracle. If you wish to use the images you must separately license them from Corbis or Getty, pursuant to the contact information listed below. To access the documentation, navigate to the Oracle Help Center at https://docs.oracle.com/en/applications/peoplesoft/interaction-hub/index.html. Select:
Corbis and Getty Contact Information Corbis website: Corbis.com Customer Service, Support, and Purchasing phone: +1.800.260.0444 e-mail: sales@corbis.com Getty Getty website: Gettyimages.com Customer Service, Support, and Purchasing phone: +1.323.202.4070 |
Reporting |
Security |
Prerequisite Products The PGP® secure messaging algorithms are available when you license the PGP encryption library from Symantec Corporation, compile the sample glue code, and load the library into the PET database. Use of the PGP® encryption functionality accessible through the Encryption Technology requires a specific license grant from Symantec Corporation. See http://www.symantec.com/products-solutions/families/?fid=encryption to inquire about purchasing the required license. |
Web Server |
Entitled Products and Restricted Use Licenses Oracle WebLogic Server Enterprise Edition is supplied with Oracle PeopleSoft PeopleTools and some Oracle PeopleSoft applications for use in the PeopleSoft products. As an Oracle PeopleSoft customer, you are granted a restricted use license of Oracle WebLogic Server Enterprise Edition to run PeopleTools or the applicable applications at no additional cost. Note: The provided license does not grant rights to use Oracle WebLogic Server for development of, or execution of, applications not delivered as part of PeopleSoft applications. Also see Oracle WebLogic Server Enterprise Edition Third-Party Notices and/or Licenses. |
