Enabling Log Analyzer for Application Engine
By default, the Log Analyzer for application engine feature is turned off. To see logs for an application engine program, you must set trace options before you run the program.
  • Set options in Configuration Manager (two-tier mode)
  • Set options in domain configuration files (three-tier mode)
  • Set options to trace a specific application engine program
