Data Security for Manufacturers and Manufacturer Parts
The privileges for manufacturer parts are managed through the Manufacturer Security tab in the Product Development work area or through the Manage Trading Partner and Trading Partner Item task available in the Product Information Management work area.
Data security that's applied at the manufacturer level applies to all manufacturer parts for that manufacturer. If data security is enabled for a given manufacturer, all manufacturer parts associated with that manufacturer inherit the data grants from the manufacturer.
Note: This is available only if you opt in to the feature - Upgrade Manufacturer Management.
You must create data security policies for the following:
  • HZ_PARTIES (Trading Community Party)
  • EGP_TRADING_PARTNER_ITEMS
  • EGP_PRIVATE_TRADING_PARTNERS
Here are the data security policies that enable access to a manufacturer along with associated manufacturer parts.
  1. Sign in to Security Console.
  2. Search for the role. Click Actions > Edit Role.
  3. On the Edit Role page, click Data Security Policies.
  4. Click Create Data Security Policy. In the Create Data Security Policy page, enter the following values:
    For HZ_Parties
    1. Policy Name: Enter a unique name for the policy.
    2. Data Resource: Search for and add the resource named HZ_PARTIES (Trading Community Party).
    3. Data Set: Select All values.
    4. Actions: Select all the actions.
    5. Click OK and click Next.
    EGP_TRADING_PARTNER_ITEMS:
    2. Data Resource: Search for and add the resource named Application Object (FND_OBJECTS).
    3. Data Set: Select by instance set.
    4. Condition Name: Select For Business Object Application Object specified by the Grant parameter PARAMETER1 for a specific grant for Table FND_OBJECTS.
    5. Parameter1: EGP_TRADING_PARTNER_ITEMS.
    6. Actions: Select all the actions.
    7. Click OK and click Next.
    EGP_PRIVATE_TRADING_PARTNERS:
    4. Condition Name: Select - For Business Object Application Object specified by the Grant parameter PARAMETER1for a specific grant for Table FND_OBJECTS.
    5. Parameter1: EGP_PRIVATE_TRADING_PARTNERS.
  5. Save your changes.
