13.3.7 Supply and Return Values with Parameters
Just as PL/SQL procedures can define IN,
OUT, and IN/OUT parameters, so can REST Data Sources. Define a
parameter at the operation level if it's specific to that action, or at the data source
level if it's relevant to all operations.
You can configure a default value for each one, mark it as required if relevant, and indicate if the value is static. Any parameter whose value is not static can be set on the page or List of Values where you use the REST Data Source so different usages can pass in appropriate values. In Page Designer, they appear beneath a Parameters node indented inside the region in the rendering tree. The table below describes the most common parameter types.
Table 13-2 Most Common Parameter Types
| Type | Direction | Description |
| URL Pattern | IN |
Use in URL Pattern as :Name or {Name} |
| URL Query String | IN |
Included in URL query string as Name=Val |
| HTTP Header | IN, OUT, IN/OUT |
Set and/or return HTTP header value |
| Request or Response Body | IN, IN/OUT |
Use in Request Body Template as #Name#, #Name!NULL#, or #Name!RAW# |
| Request or Response Body | OUT, IN/OUT |
Return entire response body |
| Data Profile Column | OUT |
Return data profile column from 1-row response |
For example, to send a Content-Type header with the fixed value application/json, use an HTTP Header type parameter with IN direction marked as static.
In contrast, for an HTTP header or query string parameter related to authentication and authorization, define an appropriate Web Credential of the appropriate type instead. Then reference that web credential in your REST Data Source. This ensures security-related values are obfuscated in debug logs and that the credential secret is securely stored and handled.
Parent topic: Using REST APIs as Data Sources
