14.4 Using SQL Developer Web REST Designer
Use SQL Developer Web REST Designer to create and navigate ORDS service definitions.
Access SQL Developer Web directly from App Builder to define your ORDS modules, templates, and handlers.
- Accessing SQL Developer Web REST Designer
Open SQL Developer Web from App Builder to use its REST API designer. - Navigating ORDS Service Definitions
Navigate from modules to templates to handlers in SQL Developer Web REST Designer.
Parent topic: Exposing APIs for Integration
