1 Prerequisites to Using SQL Developer
Before you use SQL Developer with TimesTen or TimesTen In-Memory Database, you must perform the tasks:
For information about installing and starting SQL Developer, see Oracle SQL Developer User's Guide.
Setting environment variables for TimesTen and SQL Developer
To access a TimesTen database from SQL Developer, install SQL Developer on the same system as the TimesTen Data Manager or Client. If you want to use SQL Developer to access local databases, install SQL Developer on the same system as the TimesTen Data Manager. If you want to use SQL Developer to access remote databases, install SQL Developer and the TimesTen Client on the same system.
Before you start SQL Developer, execute the timesten_home/bin/ttenv.sh or timesten_home/bin/ttenv.csh shell script on Linux and UNIX systems, the timesten_home\bin\ttenv.bat batch file on Microsoft Windows systems, or the timesten_home/bin/ttenv.sh on macOS. The shell script or batch file adds or modifies the environment variables:
CLASSPATH includes the TimesTen
timesten_home/install/lib/ttjdbc8.jarfile on Linux and macOS systems or the TimesTentimesten_home\install\lib\ttjdbc8.jarfile on Microsoft Windows systems. SQL Developer Release 20.2 requires that you have installed Java Development Kit (JDK) 8.To determine the third party JDBC drivers SQL Developer is using, from the Tools menu, select Preferences. In the Preferences dialog, click the + to the left of the Database node. Select Third Party JDBC Drivers. View the path name of all third party JDBC drivers including the TimesTen JDBC drivers.
LD_LIBRARY_PATH includes the TimesTen
timesten_home/install/libdirectory on Linux systems. -
timesten_home/bindirectory on Linux and macOS systems or the TimesTentimesten_home\bindirectory on Microsoft Windows systems.
Additional prerequisites for specific platforms:
Additional prerequisites for Microsoft Windows
If you are using a TimesTen client version earlier than 18.1, you need to enable TimesTen Scaleout for SQL Developer:
