Parts for InfiniBand Switches
Table 26-7 lists the replaceable parts for the InfiniBand switches used in Recovery Appliance. See “Cables and Cable Accessories for Recovery Appliance” for information about InfiniBand cables.
Note: All replacement parts listed in the following table are FRUs when covered under Premier Support of Systems warranty.
Table 26-7 Replacement Parts for InfiniBand Switches
| Part Number | Description | Repair Category | Repair |
| 300-2143 | 760 watt power supply, RoHS:Y | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at http://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html |
| 300-2299 | 760 watt AC input power supply | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at http://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html |
| 350-1312 | Fan module for Sun Datacenter InfiniBand Switch 36, RoHS:Y | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at http://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html |
| 350-1566 | Fan module, 1 RU, Sanace, reverse | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at http://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html |
| 371-2210 | CR2032 3 v battery, RoHS:Y | IR | See Sun Datacenter InfiniBand Switch 36 User's Guide at http://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html |
| 541-3495 | Sun Datacenter InfiniBand Switch 36, RoHS:YL | IR | See Sun Datacenter InfiniBand Switch 36 User's Guide at http://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html |
| 7052970 | Sun Datacenter InfiniBand Switch 36, RoHS:YL | IR | See Sun Datacenter InfiniBand Switch 36 User's Guide at http://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html |
| 7061031 | Fan module, 1 RU, Sanace, reverse | HS | See Sun Datacenter InfiniBand Switch 36 User's Guide at http://docs.oracle.com/cd/E19197-01/835-0784-05/gentextid-226.html |
