11 General Ledger Utilities
Learn about the syntax and parameters for the Oracle Communications Billing and Revenue Management (BRM) general ledger (G/L) utilities and scripts.
Topics in this document:
load_pin_config_export_gl
Use this utility to configure general ledger exporting. See "Configuring Preview and Monthly Report XML Output Files" for more information.
This utility loads configuration data into the BRM database from the BRM_home/sys/data/config/pin_config_export_gl.xml file.
Location
BRM_home/bin
Syntax
load_pin_config_export_gl pin_config_export_gl.xml [-d] [-v] [-h]
Parameters
The file to load.
-d
Creates a log file for debugging.
-v
Displays information as the utility runs.
-h
Displays the utility parameters.
Results
The utility notifies you only if it encounters errors.
load_pin_glchartaccts
Use this utility to load a chart of accounts (COA) into the BRM database.
See "Setting Up Your General Ledger" for information.
Location
BRM_home/bin
Syntax
load_pin_glchartaccts [-d] [-t] [-v] [-h] pin_glchartaccts_file
Parameters
-d
-t
Runs the utility in test mode. The COA is not loaded into the database.
-v
-h
The file to load.
Results
The load_pin_glchartaccts utility notifies you only if it encounters errors.
load_pin_glid
Use this utility to load G/L IDs into the BRM database.
See "About Collecting General Ledger Data".
Location
BRM_home/bin
Syntax
load_pin_glid [-d] [-t] [-v] pin_glid_file |[-h]
Parameters
-d
-t
Runs the load_pin_glid utility in test mode. G/L IDs are not loaded into the database.
-v
-h
pin_glid_file
The name and location of the file that defines the G/L IDs.
Results
The load_pin_glid utility notifies you when it successfully creates the G/L IDs.
If the utility displays an error message, look in the utility log file (default.pinlog) to find any errors. The log file is either in the directory from which the utility was started, or in a directory specified in the configuration file.
You must restart the Connection Manager (CM) for any changes to take effect.
pin_ledger_report
Use this utility to collect BRM general ledger (G/L) information, generate G/L reports, and export the reports to XML files.
Important:
For multischema systems, you must run the utility separately against each database schema in your system.
For more information, see the following:
Location
BRM_home/bin
Syntax Overview
You can use the -mode parameter to run this utility in these modes:
run_report Mode Syntax
Creates an individual report that you can view in Oracle Analytics Publisher or BI Publisher.
See "Creating Individual G/L Reports with pin_ledger_report".
pin_ledger_report -mode run_report
                  [-start start_date]
                  [-end end_date]
                  [-segment gl_segment]
                  [-type billed | unbilled
                        billed_earned | billed_unearned |
                        unbilled_earned | unbilled_unearned |
                        prev_billed_earned]
                  [-report file_name]
                  [-summary | -detail]
                  [-noncurrency | -all_resource]
                  [-test]
                  [-verbose]
                  [-help]
                  [-post]
run_report Mode Parameters
-start mm/dd/yy or mm/dd/yyyy
-end mm/dd/yy or mm/dd/yyyy
The start and end dates for revenue to be included in the report. The value you supply for the start date is inclusive, but the value you supply for the end date is noninclusive and defaults to the current date.
-segment gl_segment
Creates a report for a specific G/L segment. See "Reporting Revenue for Groups of Customers". The default is the root segment.
-type billed | unbilled | billed_earned | billed_unearned | unbilled_earned | unbilled_unearned | prev_billed_earned
Creates a report for the type of revenue you specify. The default is billed. See "About Event-Based Revenue Recognition".
-report file_name
Displays the output of the utility. Use the -report parameter with the -test parameter to display the report without creating the /ledger_report object.
-summary | detail
Creates a detailed report or a summary report. By default, summary customer G/L reports are created.
Reports G/L data for noncurrency balance elements only or for both currency and noncurrency balance elements. If you do not use either of these parameters, the utility reports currency only.
-test
Runs the utility in calculation mode only.
-verbose
-help
-post
Posts the report using the value in the -end_date parameter as the post date. If used, this must be the last parameter in the command line.
post_only Mode Syntax
Posts G/L data to maintain the validity of revenue data.
pin_ledger_report -mode post_only
                  [-verbose]
                  [-help]
                  [-posted posted_date | -unpost]
post_only Mode Parameters
-segment gl_segment
Posts the G/L report for a specific G/L segment. See "Reporting Revenue for Groups of Customers".
-verbose
-help
Posts or unposts the specified ledger report. You specify the report by entering the post date. To display a list of previously run reports, see "list_previous Mode Syntax".
Lists previously generated G/L reports.
pin_ledger_report -mode list_previous
                  -start start_date
                  [-end end_date]
                         prev_billed_earned]
                 [-verbose]
                 [-help]
list_previous Mode Parameters
-start start_date
-end end_date
The start and end times for listing the reports. The default for the end date is the current date.
-segment gl_segment
Shows the report for a specific G/L segment. The default is to list reports for all segments. See "Reporting Revenue for Groups of Customers".
Lists reports for a specified type of revenue. By default, the utility lists all types. See "About Event-Based Revenue Recognition".
-verbose
-help
export Mode Syntax
Generates and exports reports from the /config/export_gl object.
pin_ledger_report  -mode export
                   [-aggregate | -preview]
                   [-resend report_ID]
                   [-regenerate report_ID]
                   [-restart]
                   [-verbose]
                   [-help]
export Mode Parameters
-aggregate
Exports your monthly export report to an XML file. You can then post this XML file to your external financial system. See "About the Monthly Export Report".
Use this report for deliverable-based revenue recognition.
Do not use any other parameters with this option.
-preview
Exports your preview report to an XML file. See "About the Preview G/L Report".
-segment gl_segment
Exports XML reports for the G/L segment specified. The default is to generate and export reports for all segments. See "Reporting Revenue for Groups of Customers".
To process reports for two or more G/L segments at the same time, run multiple instances of the utility.
-resend report_ID
Re-creates the XML files for the specified reports without re-creating the /ledger_report object. See "Correcting Incorrect Data or Replacing Lost XML Output Files".
Re-creates the /ledger_report object and the XML report. See "Using Updated G/L Data After an Export".
-restart
Cleans up a previous abnormal run and finishes processing successfully. See "Restarting a Failed Export".
-verbose
-help
Results
If the utility displays an error message, check the utility log file to determine the source of the error and correct it.
If the utility encounters an error in -export mode, either rerun the pin_ledger_report utility in -export mode or allow the next scheduled run of the utility to continue processing the remaining reports. The pin_ledger_report utility will correctly process the remaining reports.
If the utility encounters an error during -export mode when the -resend or -regenerate parameter was used, run the utility again after correcting the errors based on the log file messages. If some of the reports were successfully re-exported or regenerated, run the utility again for the failed reports.
