2 Setting Up Your General Ledger
You set up your general ledger (G/L) in Oracle Communications Billing and Revenue Management (BRM) by creating a chart of accounts (CoA) and G/L IDs.
Topics in this document:
When you set up the general ledger, you do this:
Create a list of general ledger (G/L) accounts in the chart of accounts (CoA). See "Creating a Chart of Accounts".
Create G/L IDs. See "Creating G/L IDs".
Specify the G/L IDs to use for recording financial transactions when a charge or an accounts receivable (A/R) action occurs, such as a write-off. To do so, assign G/L IDs to the following:
A/R actions, such as payments and refunds. See "Assigning G/L IDs to A/R Actions".
Prerated events. See "Assigning G/L IDs to Prerated Events".
Early termination fees, which customers can be charged when they cancel their contract early. See "Creating Subscription Terms" in PDC Creating Product Offerings.
Tax codes. See "Creating Tax Codes" in BRM Calculating Taxes.
Charges. See "Configuring Charge Offers" in PDC Creating Product Offerings.
Discounts. See "Creating Discount Offers" in PDC Creating Product Offerings.
Deliverables, if you are using deliverable-based revenue recognition. See "Configuring Deliverables" in PDC Creating Product Offerings.
(For event-based revenue recognition only) Create segments for reporting revenue for groups of customers, such as customers in a geographic region. See "Reporting Revenue for Groups of Customers".
Configure various options that specify how G/L data is reported. For example, how G/L reporting recognizes billing dates. See "General Ledger Configuration Options".
Configure how G/L amounts are rounded. See "Rounding General Ledger Data".
The chart of accounts (CoA) is a list of general ledger accounts that your company uses. In BRM, you create a CoA that lists the general ledger accounts that are in your company's general ledger on your external financial system.
If you use multiple G/L segments, you can load multiple CoAs and assign a different CoA to each segment. See "Reporting Revenue for Groups of Customers".
To create your general ledger accounts in BRM:
Go to the BRM_home/sys/data/pricing/example directory.
Open the pin_glchartaccts file in text editor. The pin_glchartaccts file includes instructions and examples.
- Add the following information to the file:
coa_id: The identification number for the CoA. You use this ID when configuring G/L IDs.
coa_name: A description of the CoA.
For each general ledger account, add a gl_coa_acct line that includes the following information, separated by tabs:
The general ledger account code or number used in your external financial system.
A description of the general ledger account.
The type of account: asset, equity, expense, liability, or revenue.
The status of the account: active or inactive. Inactive accounts cannot be associated with a G/L ID.
For example:
gl_coa_acct 40500 prepaid.A/R asset active
Run the following command to load the CoA into a /config/glid object in the database:
load_pin_glchartaccts pin_glchartaccts_file
See "load_pin_glchartaccts".
Sample pin_glchartaccts Entries
The following shows sample entries in a pin_glchartaccts file for one CoA with thirteen general ledger accounts.
To create multiple CoAs, use multiple sets of the coa_id, coa_name, and gl_coa_accts fields.
gl_chartaccts ( coa_id 1000 coa_name Primary COA gl_coa_acct 0 undefined revenue active gl_coa_acct 1 undefined asset active gl_coa_acct 49400 prepaid.off revenue active gl_coa_acct 49300 monthly.A/R asset active gl_coa_acct 49200 uncollect.A/R asset active gl_coa_acct 40800 uncollect.off revenue active gl_coa_acct 40700 cancel.A/R asset active gl_coa_acct 40500 prepaid.A/R asset active gl_coa_acct 40000 purchase.off revenue active gl_coa_acct 20160 monthly.off revenue active gl_coa_acct 20150 cancel.off revenue active gl_coa_acct 11000 purchase.A/R asset active gl_coa_acct 10600 daily.A/R asset active )
Creating G/L IDs
To create G/L IDs, you define each G/L ID in the BRM_home/sys/data/pricing/example/pin_glid file and then use the load_pin_glid utility to load the G/L IDs into the BRM database.
In a production system, do not remove or modify any existing G/L IDs. Doing so could generate inaccurate G/L reports.
To create G/L IDs:
Open the pin_glid file in a text editor. The pin_glid file includes instructions and examples.
(Optional) Enter the CoA to use for this pin_glid file. The default is to not use a CoA.
(Optional) To create a separate set of G/L IDs for a segment, enter a G/L segment to use for this pin_glid file by using the following syntax:
gl_segment root segment.child_segment [no_rollup]
where child_segment is a nested segment and [no_rollup] includes the segment in your reports.
Segment names are case sensitive and cannot have spaces.
For each G/L ID, add the following information:
id: The identification number for the group of G/L IDs.
taxcode: (Optional) The tax code used by your tax calculation software.
descr: A description, such as Monthly fees.
type: The type of G/L ID: standard (0), A/R (1), Revenue (2), or Contract (3). See "About G/L IDs" for more information.
For each supported revenue type in a G/L ID, add a gl_acct line that includes the following information, separated by tabs:
The revenue type such as billed, unbilled, and unearned.
What the amount represents:
gross: Reports the total revenue.
disc: Reports the balance impacts of discounted revenue.
net: Reports the amount of revenue that remains after applying discounts.
tax: Reports the amount of taxes calculated. This data is used for collecting G/L data based on tax codes.
For example, if you provide a $5 discount on a $30 cycle forward fee: the gross amount is $30, the discounted amount is $5, and the net amount is $25.
The G/L accounts to use for tracking debits and credits.
For example:
gl_acct billed gross purchase.debit purchase.credit
Save the pin_glid file.
Run the following command to load the G/L IDs into the BRM database:
load_pin_glid pin_glid_file
See "load_pin_glid" for more information.
Sample pin_glid Entries
The following shows sample entries in a pin_glid file for defining the G/L ID for a purchase fee:
#================================================================================= # G/L ID for purchase fee #================================================================================= glid id 10123222 taxcode PURCHASE_TAXCODE descr Purchase Fees type 2 gl_acct billed gross purchase.debit purchase.credit gl_acct billed net purchase.debit purchase.credit gl_acct billed disc purchase.credit purchase.debit gl_acct unbilled gross purchase.debit purchase.credit gl_acct unbilled net purchase.debit purchase.credit gl_acct unbilled disc purchase.credit purchase.debit
Some balance impacts are generated by A/R actions, such as payments and refunds, rather than by charges. To have these actions recorded in your general ledger, map each A/R action to a G/L ID.
To map A/R actions to G/L IDs:
Go to the BRM_home/sys/msgs/reasoncodes directory.
Open the reasons.en_US sample file in a text editor.
Add your G/L IDs, making sure that they match the G/L IDs in the pin_glid file.
Tip:
You can change the existing G/L IDs, such as 109 (payment), to a custom G/L ID.
Save the reasons.en_US file.
Run the following command, which loads this change into the /config/map_glid object:
load_localized_strings reasons.locale
To assign G/L IDs to prerated events or partially rated events, use the PCM_OP_ACT_POL_SPEC_GLID policy opcode. See "Assigning G/L IDs to Prerated Events" in BRM Opcode Guide.
