31 Building a Connector Application
Learn how to set up enterprise applications to access Oracle Communications Billing and Revenue Management (BRM) event data by using a connector application for Enterprise Application Integration (EAI) Manager.
Topics in this document:
To provide access to BRM event data for enterprise applications, you need to build a module connector application that handles transaction management and transformation schemes specific to your environment.
The EAI DM calls the functions listed in Table 31-1 when it starts, processes event data, and shuts down. You must implement these functions in your connector application.
Table 31-1 Functions Called by EAI Data Manager
Function | Description |
Called by the EAI DM after the transaction is cancelled in BRM. |
Called by the EAI DM after BRM commits the transaction to its database. |
Called when the EAI DM process is shutting down. |
Called from a connector application to access the context initialized with InitializeGlobalContext. |
Called by the EAI DM when it starts. |
Called by the EAI DM before it calls PublishEvent. |
Called by the EAI DM when BRM is about to commit the transaction to the database. |
Called by the EAI DM when there is a business event to be published. |
Called from the connector application to set a return identifier for a published business event. |
Called by the EAI DM when it shuts down. |
The plugin_flist.c and plugin_xml.c files in the BRM_home/sys/dm_eai directory provide sample implementations of the EAI functions in flist and XML format.
After you build your connector application, configure EAI Manager. See "Configuring EAI Manager".
