Upgrading K8s container engine from Docker to Containerd
This
section explains the procedure to upgrade K8s container engine from docker to
container.
Note: This step is only for execution from 1.3.2 to 1.4.0 where kube version is same but there is a change to container engine for cluster, this step should be removed for future upgrade procedure.
- Get k8s dependencies for
1.4.0 k8s upgrade for containerd on Bastion Host
Example- ANSIBLE_NOCOLOR=1 OCCNE_VERSION= K8S_IMAGE=winterfell:5000/occne/k8s_install:1.4.0 CENTRAL_REPO=winterfell K8S_ARGS="" K8S_SKIP_TEST=1 K8S_SKIP_DEPLOY=1 /var/occne/cluster/<cluster-name>/artifacts/pipeline.sh - Create
upgrade_container.yml in /var/occne/cluster/<cluster_name> directory with
contents below:
- hosts: k8s-cluster tasks: - name: Switch Docker container runtime to containerd shell: "{{ item }}" with_items: - "sudo cp /etc/cni/net.d/calico.conflist.template 10-containerd-net.conflist" - "systemctl daemon-reload" - "systemctl enable containerd" - "systemctl restart containerd" - "systemctl stop docker" - "systemctl daemon-reload" - "systemctl restart kubelet" - "sudo yum remove -y docker-ce" ignore_errors: yes - Run k8s install in bash
mode to update container engine from docker to container d
Bare Metal ClustersVCNE Clusters
docker run -it --rm --cap-add=NET_ADMIN --network host -v /var/occne/cluster/<cluster-name>:/host -v /var/occne:/var/occne:rw -e ANSIBLE_NOCOLOR=1 -e 'OCCNEARGS= ' winterfell:5000/occne/k8s_install:1.4.0 bash
Below steps are common once in bash docker mode for both vcne and bare metal:// Get Values from Cloud Config Example- docker run -it --rm --cap-add=NET_ADMIN --network host -v /var/occne/cluster/<cluster-name>:/host -v /var/occne:/var/occne:rw -e OCCNEINV=/host/terraform/hosts -e 'OCCNEARGS=--extra-vars={"occne_vcne":"1","occne_cluster_name":"ankit-upgrade-3","occne_repo_host":"ankit-upgrade-3-bastion-1","occne_repo_host_address":"192.168.200.9"} --extra-vars={"openstack_username":"ankit.misra","openstack_password":"{Cloud-Password}","openstack_auth_url":"http://thundercloud.us.oracle.com:5000/v3","openstack_region":"RegionOne","openstack_tenant_id":"811ef89b5f154ab0847be2f7e41117c0","openstack_domain_name":"LDAP","openstack_lbaas_subnet_id":"2787146b-56fe-4c58-bd87-086856de24a9","openstack_lbaas_floating_network_id":"e4351e3e-81e3-4a83-bdc1-dde1296690e3","openstack_lbaas_use_octavia":"true","openstack_lbaas_method":"ROUND_ROBIN","openstack_lbaas_enabled":true} ' winterfell:5000/occne/k8s_install:<image_tag> bash
Wait for all pods to become ready with 1/1 and status as running. This can be done by executing kubectl get pods. Run next steps after confirming all pods are ready , running.sed -i /kubespray/roles/bootstrap-os/tasks/bootstrap-oracle.yml -re '2, 16d' sed -i /kubespray/roles/kubernetes-apps/ingress_controller/cert_manager/tasks/main.yml -re '3, 58d' // The command runs the playbook to add configuration files for containerd /copyHosts.sh ${OCCNEINV} && ansible-playbook -i /kubespray/inventory/occne/hosts \ --become \ --become-user=root \ --private-key /host/.ssh/occne_id_rsa \ /kubespray/cluster.yml ${OCCNEARGS} // Once done run the upgrade_container in bash mode below. // Around a 2 -3 minute timeout for some services may occur depending on how quickly the next command is executed. /copyHosts.sh ${OCCNEINV} && ansible-playbook -i /kubespray/inventory/occne/hosts \ --become \ --become-user=root \ --private-key /host/.ssh/occne_id_rsa \ /host/upgrade_container.yml // Note : There will be a prompt during running above task on vcne that calico.conflist.template does not exist, this is because flannel is used rather then calico. Prompt will be skipped for vcne - Test to check all
containers are managed by containerd:
// Login into any node of the cluster to see all the containers are managed by crictl sudo /usr/local/bin/crictl ps
