3 Debug Tool
Overview
CNC Console IAM is not applicable for OCI.
The Debug Tools provides third-party troubleshooting tools for debugging the runtime issues for the lab environment. Following are the available tools:
  • tcpdump
  • ip
  • netstat
  • curl
  • ping
  • dig
Debug Tool is only applicable for lab setup, and not recommended for production use.
While testing in OCCNE environment, check the Kyverno policies and make sure to exclude the namespace in the disallow-capabilities.
Prerequisites
This section explains the prerequisites for using debug tool.
  • For CNE 23.2.0 and later versions, follow step a of Configuration in CNE.
  • For CNE versions prior to 23.2.0, follow step b of Configuration in CNE.
  1. Configuration in CNE
    The following configurations must be performed in the Bastion Host.
    1. When CNC Console is installed on CNE version 23.2.0 or above
      • You need admin privileges to edit or patch the clusterpolicies that are mentioned in following steps.
      • In CNE v23.2.0 onwards, kyverno policy, disallow-capabilities does not allow NET_ADMIN and NET_RAW capabilities required for debug tool.
      Adding Namespace to the Empty Resource
      If the current disallow-capabilities cluster policy has no namespace in it, for example:
      $ kubectl get clusterpolicies disallow-capabilities -oyaml
      Sample output
      apiVersion: kyverno.io/v1
      kind: ClusterPolicy
      spec:
        rules:
        - exclude:
            resources: {}
      Then, run the following command to add the namespace:
      $ kubectl patch clusterpolicy disallow-capabilities --type=json \
        -p='[{"op": "add", "path": "/spec/rules/0/exclude/any/0/resources", "value": {"namespaces":["<namespace>"]} }]'
      Example:
        -p='[{"op": "add", "path": "/spec/rules/0/exclude/any/0/resources", "value": {"namespaces":["cncc"]} }]'
      Sample output
      kind: ClusterPolicy
      spec:
        rules:
        - exclude:
            resources:
              namespaces:
              - cncc
      To remove the namespace, run the following:
        -p='[{"op": "replace", "path": "/spec/rules/0/exclude/any/0/resources", "value": {} }]'
      Sample output
      kind: ClusterPolicy
      spec:
        rules:
        - exclude:
            resources: {}
      Adding a Namespace to the Existing Namespace List
      If the current disallow-capabilities cluster policy has already namespaces added in it, for example:
      Output:
      kind: ClusterPolicy
      spec:
        rules:
        - exclude:
            resources:
              namespaces:
              - namespace1
              - namespace2
              - namespace3
      Then, run the following command to add your namespace:
        -p='[{"op": "add", "path": "/spec/rules/0/exclude/any/0/resources/namespaces/-", "value": "<namespace>" }]'
      Example:
        -p='[{"op": "add", "path": "/spec/rules/0/exclude/any/0/resources/namespaces/-", "value": "cncc" }]'
      Sample Output:
      kind: ClusterPolicy
      spec:
        rules:
        - exclude:
            resources:
              namespaces:
              - namespace1
              - namespace2
              - namespace3
              - cncc
      To remove the namespace, run the following command:
        -p='[{"op": "remove", "path": "/spec/rules/0/exclude/any/0/resources/namespaces/<index>"}]'
      Example:
        -p='[{"op": "remove", "path": "/spec/rules/0/exclude/any/0/resources/namespaces/3"}]'
      Output:
      kind: ClusterPolicy
      spec:
        rules:
        - exclude:
            resources:
              namespaces:
              - namespace1
              - namespace2
              - namespace3
    2. Configurations in CNE Versions Prior to 23.2.0
      These steps are needed only when you have PSP admission controller enabled in your kubernetes environment.
      PodSecurityPolicy (PSP) Creation
      1. Log in to the Bastion Host.
      2. Create a new PSP by running the following command. The parameters readOnlyRootFileSystem, allowPrivilegeEscalation, allowedCapabilities are needed by debug container.
        Other parameters are mandatory for PSP creation and can be customized as per the CNE environment. Default values are recommended.
      PodSecurityPolicy
      kubectl apply -f - <<EOF
      apiVersion: policy/v1beta1
      kind: PodSecurityPolicy
      metadata:
      spec:
        readOnlyRootFilesystem: false
        allowPrivilegeEscalation: true
        allowedCapabilities:
        - NET_ADMIN
        - NET_RAW
        fsGroup:
          ranges:
          - max: 65535
            min: 1
          rule: MustRunAs
        runAsUser:
          rule: MustRunAsNonRoot
        seLinux:
          rule: RunAsAny
        supplementalGroups:
          rule: RunAsAny
        volumes:
        - configMap
        - downwardAPI
        - emptyDir
        - persistentVolumeClaim
        - projected
        - secret
      EOF
      Table 3-1 PodSecurityPolicy
      Parameter Description
      apiVersion APIVersion defines the versioned schema of this representation of an object.
      kind Kind is a string value representing the REST resource this object represents.
      metadata Standard object's metadata.
      metadata.name Name must be unique within a namespace.
      spec spec defines the policy enforced.
      spec.readOnlyRootFilesystem Controls whether the containers run with a read-only root filesystem (that is no writable layer).
      spec.allowPrivilegeEscalation Gates whether or not a user is allowed to set the security context of a container to allowPrivilegeEscalation=true.
      spec.allowedCapabilities Provides a list of capabilities that are allowed to be added to a container.
      spec.fsGroup Controls the supplemental group applied to some volumes. RunAsAny allows any fsGroup ID to be specified.
      spec.runAsUser Controls which user ID the containers are run with. RunAsAny allows any runAsUser to be specified.
      spec.seLinux RunAsAny allows any seLinuxOptions to be specified.
      spec.supplementalGroups Controls which group IDs containers add. RunAsAny allows any supplementalGroups to be specified.
      spec.volumes Provides a list of allowed volume types. The allowable values correspond to the volume sources that are defined when creating a volume.
    Role Creation
    Create a role for the PSP by running the following commands:
    Role
    apiVersion: rbac.authorization.k8s.io/v1
    kind: Role
    metadata:
      namespace: cncc
    rules:
    - apiGroups:
      - policy
      resources:
      - podsecuritypolicies
      verbs:
      - use
      resourceNames:
      - debug-tool-psp
    EOF
    Table 3-2 Role
    apiGroups APIGroups is the name of the APIGroup that contains the resources.
    metadata.namespace Namespace defines the space within which each name must be unique.
    rules Rules holds all the PolicyRules for this Role
    rules.resourceNames ResourceNames is an optional white list of names that the rule applies to.
    rules.resources Resources is a list of resources this rule applies to.
    rules.verbs Verbs is a list of Verbs that apply to ALL the ResourceKinds and AttributeRestrictions contained in this rule.
    RoleBinding Creation
    Run the following command to attach the service account for your namespace with the role created for the tool PSP:
    RoleBinding
    kind: RoleBinding
    metadata:
      namespace: cncc
    roleRef:
      apiGroup: rbac.authorization.k8s.io
      kind: Role
    subjects:
    - kind: Group
    EOF
    Table 3-3 RoleBinding
    roleRef RoleRef can reference a Role in the current namespace or a ClusterRole in the global namespace.
    roleRef.apiGroup APIGroup is the group for the resource being referenced
    roleRef.kind Kind is the type of resource being referenced
    roleRef.name Name is the name of resource being referenced
    subjects Subjects holds references to the objects the role applies to.
    subjects.kind Kind of object being referenced. Values defined by this API group are "User", "Group", and "ServiceAccount".
    subjects.apiGroup APIGroup holds the API group of the referenced subject.
    subjects.name Name of the object being referenced.
Configuration Changes in CNCC Helm Charts
To enable debug tools container, make changes to occncc_custom_values_<version>.yaml file at Global level by setting extraContainers: ENABLED.
global:
  # Allowed Values: DISABLED, ENABLED
  # Preference is to set  "resources" request and limit to same values to avoid HPA issues.
  debugToolContainerMemoryLimit: 4Gi
  extraContainersVolumesTpl: |
    - name: debug-tools-dir
      emptyDir:
        medium: Memory
        sizeLimit: {{ .Values.global.debugToolContainerMemoryLimit | quote }}
  extraContainersTpl: |
    - command:
        - /bin/sleep
        - infinity
      image: {{ .Values.global.dockerRegistry }}/occncc/ocdebug-tools:<debugtool_version
      imagePullPolicy: IfNotPresent
      name: {{ printf "%s-tools-%s" (include "getprefix" .) (include "getsuffix" .) | trunc 63 | trimPrefix "-" | trimSuffix "-"  }}
      resources:
        limits:
          ephemeral-storage: "512Mi"
          cpu: "0.5"
          memory: {{ .Values.global.debugToolContainerMemoryLimit | quote }}
        requests:
          cpu: "0.5"
      securityContext:
        capabilities:
          drop:
          - ALL
          add:
          - NET_RAW
          - NET_ADMIN
        #runAsUser: <user-id>
      volumeMounts:
      - mountPath: /tmp/tools
To enable debug tools at service level, make changes to occncc_custom_values_<version>.yaml file at service level by setting extraContainers: USE_GLOBAL_VALUE
cncc-iam:
  kc:
    # Allowed Values: DISABLED, ENABLED, USE_GLOBAL_VALUE
  ingress-gateway:
mcncc-core:
  cmservice:
  ingress-gateway:
acncc-core:
  ingress-gateway:
Debug Tool Container comes up with the default user ID - 7000. If the operator wants to override this default value, it can be done using the runAsUser field, otherwise the field can be skipped.
Default value: uid=7000(debugtool) gid=7000(debugtool) groups=7000(debugtool)
To override runAsUser add this line under securityContext in extraContainersTpl
Configuration Options
Table 3-4 Configuration Options
global.extraContainersTpl Describes the kubernetes container template for the debug-tool.
global.debugToolContainerMemoryLimit This field describes the memory size (request and limit) and emptyDir volume size for the Debug-tool container.
global.extraContainersTpl.command String array used for container command.
global.extraContainersTpl.image Docker image name
global.extraContainersTpl.imagePullPolicy Image Pull Policy
global.extraContainersTpl.name Name of the container
global.extraContainersTpl.resources Compute Resources required by this container
global.extraContainersTpl.resources.limits Limits describes the maximum amount of compute resources allowed
global.extraContainersTpl.resources.requests Requests describes the minimum amount of compute resources required
global.extraContainersTpl.resources.limits.cpu CPU limits
global.extraContainersTpl.resources.limits.memory Memory limits
global.extraContainersTpl.resources.limits.ephemeral-storage Ephemeral Storage limits
global.extraContainersTpl.resources.requests.cpu CPU requests
global.extraContainersTpl.resources.requests.memory Memory requests
global.extraContainersTpl.resources.requests.ephemeral-storage Ephemeral Storage requests
global.extraContainersTpl.securityContext Security options the container should run with.
global.extraContainersTpl.securityContext.allowPrivilegeEscalation AllowPrivilegeEscalation controls whether a process can gain more privileges than its parent process. This boolen directly controls if the no_new_privs flag will be set on the container process
global.extraContainersTpl.securityContext.capabilities The capabilities to add or drop when running containers. Defaults to the default set of capabilities granted by the container runtime.
global.extraContainersTpl.securityContext.capabilities.drop Removed capabilities
global.extraContainersTpl.secuirtyContext.capabilities.add Added capabilities
global.extraContainersTpl.securityContext.runAsUser The UID to run the entrypoint of the container process.
global.extraContainersTpl.volumeMounts.mountPath The path where the emptyDir volume has to be mounted inside the container.
global.extraContainersTpl.volumeMounts.name Name of the emptyDir volume.
Debug Tool Volume Parameters
Table 3-5 Debug Tool Volume Parameters
global.extraContainersVolumesTpl Describes the kubernetes volume template for the debug-tool container
global.extraContainersVolumesTpl.name Name of the emptyDir volume.
global.extraContainersVolumesTpl.emptyDir.sizeLimit The size of the emptyDir volume.
global.extraContainersVolumesTpl.emptyDir.medium Describes where emptyDir volumes are stored.
Debug Tool Usage
Following is the procedure to run Debug Tool:
  1. Run the following command to retrieve the POD details:
    $ kubectl get pods -n <k8s namespace>
    Example:
    # kubectl get pod -n cncc
    Sample Output:
     NAME                                         READY   STATUS   RESTARTS   AGE
    cncc-acore-ingress-gateway-764f7f5f77-qnr5p   2/2     Running   0         19m
    cncc-iam-ingress-gateway-55987f7dc9-x5nt2     2/2     Running   0         147m
    cncc-iam-kc-0                                 2/2     Running   0         147m
    cncc-mcore-cmservice-947cf4c89-76vq6          2/2     Running   0         19m
    cncc-mcore-ingress-gateway-764f7f5f77-qnr5p   2/2     Running   0         19m
  2. Run the following command to enter Debug Tools Container:
    kubectl exec -it <pod name> -c <debug_container name> -n <namespace> bash
    Example:
    kubectl exec -it cncc-mcore-ingress-gateway-599d858867-x9pvz -c tools -n cncc bash
  3. Run the debug tools:
    bash -4.2$ <debug_tools>
    Example:
    bash -4.2$ tcpdump
  4. Run the following command to copy output files from container to host:
    $ kubectl cp -c <debug_container name>  <pod name>:<file location in container> -n <namespace>  <destination location>
    Example:
    $ kubectl cp -c tools -n cncc cncc-mcore-ingress-gateway-764f7f5f77-qnr5p:/tmp/capture.pcap /tmp/
Steps to Enable Debug Tools Container
Debug tools container can be enabled or disabled for CNCC components by using helm install or helm upgrade command.
CNC Console
Run the following command to enable or disable CNC Console IAM after updating occncc_custom_values_<version>.yaml file on a installed setup:
$ helm upgrade <release_name> -f occncc_custom_values_<version>.yaml <helm-repo> --version <helm_version>
Example:
$ helm upgrade cncc -f occncc_custom_values_25.1.200.yaml ocspf_helm-repo/cncc --version 25.2.100
