18 Copying and Deleting Configuration
This chapter explains how to copy and delete configuration.
This chapter contains the following topics.
Copying Configuration
The Copy function allows you to copy the SPM configuration defined for the currently selected service provider and product type to a new service provider and/or product type.
Note: You can only copy periodic charges to a new product type with the same service provider, not to a new service provider.
Follow these steps to copy the configuration for a selected Service Provider and Product Type.
Note: The copy operation will only copy the configuration for the tab you have selected.
In the Subscriber Profile Manager screen, select the Service Provider that you want to copy from.
From the drop down list, select the Product Type you want to copy from.
Note: Product type selection is disabled from the CCP Dashboard and Group Configuration tabs. To enable product type selection, click on the Subscriber Config, Product Type Config, or Sub-Group Configuration tabs.
Select the tab of the records to copy.
To copy:
Edit Subscriber screen configuration, select the Subscriber Config tab.
Edit Product Type screen configuration, select the Product Type Config tab.
Sub-Groups, select the Sub-Group Configuration tab.
Click the Copy <data> button at the top of the screen.
Result: You see the Copy Configuration screen showing details of the records you can copy with this operation.
To copy the configuration to a different Service Provider, select the new Service Provider from the drop down list.
Note: Selecting a new Service Provider means that the CCP Dashboard configuration will also be copied.
Select the Product Type from the drop down list to which the configuration will be copied.
Warning: You will not be able to copy configuration to a Product Type for which configuration has already been defined.
Click Copy.
The Delete Configuration function allows you to return some of the configuration for the currently selected Service Provider to the initial defaults.
Notes:
There are no defaults for product type and sub-group configuration, so returning to defaults will delete all existing configuration for those types of records.
You cannot delete the configuration defined for the Boss Service Provider.
Returning subscriber configuration to defaults
Follow these steps to return the subscriber configuration for a selected Service Provider to the defaults.
Note: Returning subscriber configuration does not delete any sub-groups which are used by the subscriber configuration.
In the Subscriber Profile Manager screen, select the Service Provider whose configuration you want to delete.
Select the Subscriber Config tab.
Click Reset Subscriber to Defaults.
Result: You see the Reset to Defaults Confirmation prompt.
Click OK.
Result: The unique Edit Subscriber screen configuration defined for the Service Provider and all its associated Product Types is deleted.
Deleting product type configuration
Follow these steps to delete the Edit Product Type screen configuration for a selected Service Provider.
Select the Product Type Config tab.
Click Reset Product Type to Defaults.
Click OK.
Result: The Edit Product Type screen configuration defined for the Service Provider and all its associated Product Types is deleted.
Deleting sub-group configuration
Follow these steps to delete the Sub-groups configuration for a selected Service Provider.
Note: If the sub-groups are used for either Edit Subscriber screen configuration or CCP Dashboard screen configuration, you will not be able to delete them.
Select the Sub-Group Configuration tab.
Click Delete Sub-Group Configuration.
Click OK.
Result: The Sub-Group configuration defined for the Service Provider and all its associated Product Types is deleted.
