4 Update Mode
This chapter explains how to update ENUM records.
This chapter contains the following topics.
Update Flags
Follow these steps to amend or delete a flag record.
List the flag records. See Finding flag records.
Click on the record to amend.
Click Select.
Result: The record detail is displayed in Update mode.
To delete the record, click Delete.
Result: The Confirm Delete Record appears.
Click one of the following:
Yes to delete the record
No to keep the record.
Change fields as required.
Click Save.
Result: A saved confirmation message appears at the bottom of the screen.
If required, click Check Consistency to check that the currently selected record matches those held upon any replication targets.
Update Services
Follow these steps to amend or delete a Service record.
List the service records. See Finding service records.
Click Select.
Click Save.
Update Subscriber or Operator
Follow these steps to amend or delete a Subscriber or Operator record.
List the Subscriber or Operator records. See Finding subscriber or operator records.
Click Select.
Click Save.
Update NAPTR Records
Follow these steps to amend or delete a NAPTR record.
List the NAPTR records. See Finding NAPTR Records.
Click Select.
Click Save.
