3 Messaging Manager Replication Screen
Replication is the process used to ensure several instances of databases are kept synchronized. This chapter explains the Messaging Manager replication process.
This chapter contains the following topics.
Configuring Messaging Manager replication enables you to replicate MM data only to nodes which are running MM. Setting up replication has three parts:
SMF database synchronization across the platform
Messaging Manager run time synchronization.
For more information about replication, see SMS User's Guide.
Configuring MM replication
The Replication tab on the Messaging Manager Replication screen enables you to specify which nodes receive Messaging Manager data through replication.
SMF database synchronisation
The replication process copies all the updates to the SCP database on each SLC, as defined by SMS Node Management, Table Replication tab.
Replication configuration is set up by clicking the Create Config File button in SMS replication screen. For more information about the SMS replication process, see SMS User's Guide.
MM run time synchronization
On a regular basis MM Multigate checks MM database tables for any changes made. When found, the differences are extracted and copied to the run time Messaging Manager configuration. This technique allows for Messaging Manager configuration to continuously be updated without the need to stop and restart.
For more information about how to configure the configuration checking period, see
loadIntervalSeconds parameter in MM Technical Guide.
The Messaging Manager Replication screen enables you to configure which nodes receive MM data.
It has only one tab, the Replication tab.
Replication
The Replication tab enables you to specify which nodes (SLCs) should have Messaging Manager data replicated to them.
Follow these steps to flag the Messaging Manager nodes to be included in replication.
Open the Messaging Manager Replication screen.
Review the listed Messaging Manager nodes. In each Replicated check box, perform one of the following actions:
Select, to have the node replicated
Deselect, to stop the node from being replicated
Click Apply to save to the database.
Result: SMS will update the "Allocated Replication Groups" in "Table Replication" for all selected nodes.
