3 Configuring the Environment
This chapter describes the steps required to configure ACS.
Configuration File
Many ACS tools and processes depend on a shared configuration file. This file acs.conf is located in the $ACS_ROOT/etc directory. The configuration file consists of several sections named for the processable they control. Each section contains a name value pair representing a single configuration option.
If the operator changes the acs.conf file, the corresponding service needs to be restarted, so that the configuration file is reread and the changes take effect.
Final Configuration
It is important to complete the final configuration of ACS after this chapter. See ACS User's Guide - Setting up ACS for the First Time.
Setting the ACS Root Directory
The ACS installation depends on a single environment variable to determine the location of the configuration and other support files.
If the software is not installed in the default location, the UNIX system accounts used to run the service logic and ancillary tools must have this environment variable defined.
The ACS_ROOT variable will only need to be modified if you intend to manually configure two ACS installations side-by-side on the same machine.
This should only be done in consultation with a qualified Oracle engineer.If you are not required to manually configure two ACS installations, side-by-side, on the same machine the ACS_ROOT variable does not need to be set.
Table 3-1 ACS_ROOT
| Variable | Default | Description |
| ACS_ROOT | /IN/service_packages/ACS | ACS installation base directory |
Table 3-2 ACS_ROOT
| Description | The ACS installation base directory |
| Type | String |
| Optionality | Optional (default used if not set) |
| Default | /IN/service_packages/ACS |
Oracle Variables
The ACS account (acs_oper) requires the standard ORACLE environment variables to be present.
Oracle usr/pwd String
While it is possible to specify the usr/pwd string a process uses to connect to Oracle, it is recommended to use the defaults.
Most ACS processes are run by the UNIX user acs_oper. The OPS$ACS_OPER Oracle operator account corresponds to acs_oper. This allows acs_oper to log on to oracle as OPS$ACS_OPER without specifying a user name or password (that is, the process uses the default of "/"). A separate Oracle password is not needed for OPS$ACS_OPER because it is, in Oracle terms, identified externally.
Configuration File
ACS is configured by the following components:
Table 3-3 Configuration of ACS Components
| Components | Locations | Description | Further Information |
| acs.conf | all SMSs and VWSs in the $(ACS_ROOT)/etc directory | This file consists of several sections named for the ACS processable they control. There are different configuration options in the acs.conf on the SMS to the configuration options in the acs.conf on the SLC. | Configuring the acs.conf |
| SLEE.cfg | all SLCs | This file sets up SLEE interfaces and applications. | SLEE Technical Guide |
| eserv.config | all SMSs and VWSs | ACS has some additional configuration in the ACS section of eserv.config. | eserv.config Configuration |
Defining the Screen Language
The default language file sets the language that the Java administration screens start in. The user can change to another language after logging in.
The default language can be changed by the system administrator.
By default, the language is set to English. If English is your preferred language, you can skip this step and proceed to the next configuration task, Defining the Help Screen Language
Default.lang
When ACS is installed, a file called Default.lang is created in the application's language directory in the screens module. This contains a soft-link to the language file that defines the language that will be used by the ACS UI.
If a Default.lang file is:
- Not present, the English.lang file will be used
- Present, a user must explicitly set their language to their required language in the Tools screen or the default language will be used
The ACS Default.lang file is located in the
/IN/html/Acs_Service/language/ directory.
Example Screen Language
If Dutch is the language you want to set as the default, create a soft-link from the Default.lang file to the Dutch.lang file.
- Go to the /IN/html/Acs_Service/language directory.
Example command:
cd /IN/html/Acs_Service/language - Ensure the Default.lang file exists in this directory.
- If the required file does not exist, create an empty file called Default.lang.
- Ensure that the language file for your language exists in this
directory. The file should be in the
format:
language.langWhere:
language is your language.
Example:
Spanish.lang
- If the required language file does not exist, perform one of the following
actions:
- Create a new one with your language preferences
- Contact Oracle support.
To create a language file, you will need a list of the phrases and words used in the screens. These should appear in a list with the translated phrase in the following format:original phrase=translated phraseAny existing language file should have the full set of phrases. If you do not have an existing file to work from, contact Oracle support.
- Create a soft link between the Default.lang file, and the language
file you want to use as the default language for the SMS UI.
Example command:
ln -s Dutch.lang Default.lang
The default Helpset file sets the language that the help system for the Java Administration screens start in. The user can change to another language after logging in.
The default language can be changed by the system administrator. By default, the language is set to English.
Default_Acs_Service.hs
When ACS is installed, a file called Default_Acs_Service.hs is created in the application's language directory in the screens module. This contains a soft-link to the language file which defines the language that will be used by the ACS UI.
If a Default_Acs_Service.hs file is:
- Not present, the English_Acs_Service.hs file will be used.
- Present, a user must explicitly set their language to their required language in the Tools screen or the default language will be used.
The Default_Acs_Service.hs file is located in the /IN/html/Acs_Service/helptext/ directory.
Example Helpset Language
If Dutch is the language you want to set as the default, create a soft-link from the Default_Acs_Service.hs file to the Dutch_Acs_Service.hs file.
Procedure
Follow these steps to set the default language for your ACS user interface (UI):
Example command:
cd /IN/html/Acs_Service/helptext - Ensure the Default_Acs_Service.hs file exists in this directory.
- If the required file does not exist, create an empty file called Default_Acs_Service.hs.
- Check if the language file for your language exists in this
format:
language.Acs_Service.hsWhere:
Example:
following actions:
- Create a soft link between the Default_Acs_Service.hs file,
and the language file you want to use as the default language for the SMS UI.
Example command:
ln -s Dutch_Acs_Service.hs Default_Acs_Service.hs
Setting up the Screens
Accessing ACS
To use the Graphical user interface, you will need to do the following:
- Ensure the Java SE Runtime Environment version 21 is installed on your computer.
- If required, obtain, and install the trusted certificate for the database connection into your keystore.
- Obtain the application zip file containing jars and executable. (acsGui.bat
or acsGui.sh)
- In Windows: Run acsGui.bat to start the application.
- In other machines:
- Change the permission of smsGui.sh by using "chmod 755 acsGui.sh"
- Run the application by using "bash acsGui.sh" command.
- Where SMS_hostname is the hostname of an SMS in the IN.
- For more information about the ACS UI, see ACS User's Guide.
About Customizing the ACS UI
- acsGui.bat/acsGui.sh
- smsGui.bat/acsGui.sh
- You use the following syntax to set a Java application property in the
smsGui.bat/acsGui.sh or the smsGui.bat/acsGui.sh
file:
Where:-Dproperty="value"- property is the name of the Java application property.
- value is the value to which that property is set.
Some Java application properties may be set in both the acsGui.bat/acsGui.sh file and in the smsGui.bat/acsGui.sh file. You must specify the same value in both files.
Java Application Properties
The following application properties are available to customize the UI:
jnlp.acs.ACSDefaultCustomerIsPrepaid
| Syntax: | -Djnlp.acs.ACSDefaultCustomerIsPrepaid="value" |
| Description: | Specifies whether the ACS New Customer screen has the Prepaid Charging Customer check box selected by default. |
| Type: | String |
| Optionality: | Optional |
| Allowed: |
All other values are considered to be false. |
| Default: | |
| Notes: | If set to:
| Example: | -Djnlp.acs.ACSDefaultCustomerIsPrepaid="value" |
jnlp.acs.ACSStartScreenVersion
| Syntax: | jnlp.acs.allowRefInCustCombo |
| Description: | Specifies whether users can perform searches in the ACS UI by using the customer reference number rather than the customer name. |
| Type: | String |
| Allowed: |
All other values are considered to be false |
| Default: | False |
| Notes: |
If set to:
| Example: | -Djnlp.acs.allowRefInCustCombo =
"t" |
jnlp.acs.allowCallPlanSchedulingInPast
| Syntax: | -Djnlp.acs.allowCallPlanSchedulingInPast = "value" |
| Description: | Specifies whether control plans can be scheduled to start in the past. |
| Type: | String |
| Allowed: |
| Default: | False |
| Notes: |
If set to:
| Example: | -Djnlp.acs.jnlp.acs.allowCallPlanSchedulingInPast
= "t" |
| Syntax: | -Djnlp.acs.allowRefInCustCombo =
"value" |
| Type: | String |
| Allowed: |
| Default: | False |
| Notes: |
If set to:
"t" |
jnlp.acs.autoCloseCompileDialog
| Syntax: | -Djnlp.acs.autoCloseCompileDialog =
"value" |
| Description: | Specifies whether the CPE compiler report closes automatically after a control plan compiles successfully. |
| Type: | String |
| Allowed: |
| Default: | False |
| Notes: |
If set to:
| Example: | -Djnlp.acs.autoCloseCompileDialog =
"t" |
jnlp.acs.autoCloseCPE
| Syntax: | -Djnlp.acs.autoCloseCPE =
"value” |
| Description: | Specifies whether the Control Plan Editor closes automatically after a control plan compiles successfully. |
| Type: | String |
| Allowed: |
| Default: | False |
| Notes: |
If set to:
| Example: | -Djnlp.acs.autoCloseCPE = “t" |
jnlp.sms.clusterDatabaseHost
| Syntax: | -Djnlp.sms.clusterDatabaseHost = "(DESCRIPTION=
(LOAD_BALANCE=YES)(FAILOVER=ON)(ENABLE=BROKEN)
(ADDRESS_LIST=(ADDRESS=(PROTOCOL=type)(HOST=name)(PORT=port))
(ADDRESS=(PROTOCOL=type)(HOST=name)(PORT=port)))
(CONNECT_DATA=(SERVICE_NAME=SMF)(FAILOVER_MODE=(TYPE=SESSION)
(METHOD=BASIC)(RETRIES=5)(DELAY=3))))" |
| Description: | Specifies the connection string (including a host and an
alternative host address, in case the first IP address is unavailable)
for non-SSL cluster-aware connection to the database.
To
use non-SSL connections to the database, set the |
| Type: | String |
| Allowed: | |
| Default: | By default, port is set to 1521. |
| Notes: | If present, this property is used instead of the
jnlp.sms.databaseID property.
| Example: | -Djnlp.sms.clusterDatabaseHost = "(DESCRIPTION=
(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=smsphysnode1)
(PORT=1521)) (ADDRESS=(PROTOCOL=TCP)(HOST=smsphysnode2)(PORT=1521)))
jnlp.acs.connectionsDialog
| Syntax: | -Djnlp.acs.connectionsDialog =
"value" |
| Description: | Specifies whether the Control Plan Editor displays the Manage Node Exits dialog box when you hold down the Shift key while dragging the mouse to connect a feature node exit to a feature node entry. |
| Type: | String |
| Optionality: | Optional. (default used if not set) |
| Allowed: |
| Default: | shown |
| Notes: | |
| Example: | -Djnlp.acs.connectionsDialog =
"hidden" |
jnlp.acs.cpeLineDrawingMechanism
| Syntax: | -Djnlp.acs.cpeLineDrawingMechanism =
"connection_type" |
| Description: |
Specifies the type of connector lines that the Control Plan Editor displays. You use connector lines to connect feature nodes in control plans. Connector lines can be angled or straight lines:
| Type: | String |
| Allowed: |
| Default: | ColouredNodeConnectionDrawer |
| Notes: | |
| Example: | -Djnlp.acs.cpeLineDrawingMechanism =
"HVNodeConnectionDrawer" |
jnlp.sms.database
| Syntax: | -Djnlp.sms.database = "SMF" |
| Description: | Specifies the Oracle SID for the SMF database. |
| Type: | String |
| Optionality: | Optional (default used if not set) |
| Allowed: | |
| Default: | SMF |
| Notes: | Set at installation |
| Example: | -Djnlp.sms.database = "SMF" |
jnlp.sms.databaseHost
| Syntax: | -Djnlp.sms.databaseHost =
"ip:port:sid" |
| Description: | Sets the IP address and port to use for non-SSL
connections to the SMF database, and the database SID.
| Type: | String |
| Allowed: | |
| Default: | Not set. Secure SSL connection is enabled at installation by default. |
| Notes: | Internet Protocol version 6 (IPv6) addresses must be
enclosed in square brackets []; for Example: [2001:db8
:n:n:n:n:n:n] where n is a group of 4 hexadecimal digits.
The industry standard for omitting zeros is also allowed when specifying
IP addresses.
| Example: | -Djnlp.sms.databaseHost =
"192.0.2.1:2484:SMF"-Djnlp.sms.databaseHost =
"[2001:db8:0000:1050:0005:0600:300c:326b]:2484:SMF"-Djnlp.sms.databaseHost
= "[2001:db8:0:0:0:500:300a:326f]:2484:SMF" -Djnlp.sms.databaseHost
= "[2001:db8::c3]:2484:SMF" |
jnlp.sms.databaseID
| Syntax: | -Djnlp.sms.databaseID =
"port:sid" |
| Description: | Specifies the SQL*Net port for connecting to the database, and the database SID. |
| Type: | String |
| Optionality: | Required |
| Allowed: | |
| Default: | 1521:SMF |
| Notes: |
| Example: | -Djnlp.sms.databaseID =
"1521:SMF" |
jnlp.sms.dbPassword
| Syntax: | -Djnlp.sms.dbPassword =
"password" |
| Description: | Specifies the database password. This password is for a special database user that the ACS Logon screen uses before the user logs in. This property is set during installation and is then not changed |
| Type: | String |
| Allowed: | |
| Default: | acs_public |
| Notes: | Do not change this value. |
| Example: | -Djnlp.sms.dbPassword =
"acs_public" |
jnlp.sms.dBUser
| Syntax: | -Djnlp.sms.dBUser = "user" |
| Description: | Specifies the database user name. This is a special database user that the ACS Logon screen uses before the user logs in. This property is set during installation and is then not changed. |
| Type: | String |
| Allowed: | |
| Example: | -Djnlp.sms.dBUser =
"acs_public" |
jnlp.acs.defaultTelcoManaged
| Syntax: | -Djnlp.acs.defaultTelcoManaged =
"value" |
| Description: |
Specifies whether new ACS customer accounts are marked as being managed by a Telecommunications Operator (telco) by default. Telco-managed customers are customers that never log into ACS but are managed explicitly (and without resource limits) by the telco. This property controls whether the Managed Customer check box is selected in the ACS New Customer Details dialog box by default. |
| Type: | String |
| Allowed: |
| Default: | True |
| Notes: |
If set to:
| Example: | -Djnlp.acs.defaultTelcoManaged =
"f" |
jnlp.sms.EncryptedSSLConnection
| Syntax: | -Djnlp.sms.EncryptedSSLConnection =
"value" |
| Description: | Specifies whether connections to the client UI use encrypted SSL. |
| Type: | Boolean |
| Allowed: |
true – Use encrypted SSL connections to access the client UI. false – Use non-SSL connections to access the client UI. |
| Default: | true |
| Notes: |
| Example: | -Djnlp.sms.EncryptedSSLConnection =
"true" |
jnlp.sms.host
| Syntax: | -Djnlp.sms.host = "IPaddress" |
| Description: | Specifies the Internet Protocol (IP) address for the SMS host machine that is set at installation. |
| Type: | String |
| Allowed: |
| Default: | No default |
| Notes: | You can use the industry standard for omitting zeros when specifying IP addresses. |
| Example: |
jnlp.acs.issuePCClockWarning
| Syntax: | -Djnlp.acs.issuePCClockWarning =
"value" |
| Description: | Specifies whether a warning is raised when the user's PC clock time is more than two minutes faster or slower than the SMS platform's clock time. |
| Type: | String |
| Allowed: |
| Default: | True |
| Notes: |
If set to:
| Example: | -Djnlp.acs.issuePCClockWarning =
"t" |
jnlp.sms.logo
| Syntax: | -Djnlp.sms.logo = "file" |
| Description: |
Specifies the logo displayed on the splash screen immediately before the ACS Logon screen appears. At installation, the property is set to an Oracle logo GIF file. |
| Type: | String |
| Allowed: | A valid network path and filename. |
| Default: | None |
| Notes: | |
| Example: | -Djnlp.sms.logo =
"SMS/images/oracle.gif" |
jnlp.acs.MAX_CONTROL_PLANS_DISPLAYED
| Syntax: | -Djnlp.acs.MAX_CONTROL_PLANS_DISPLAYED =
"num" |
| Description: | Specifies the maximum number of control plans that can be displayed in the search results section of an ACS UI dialog box. |
| Type: | String |
| Allowed: | 1 through 999 |
| Default: | 200 |
| Notes: | |
| Example: | -Djnlp.acs.MAX_CONTROL_PLANS_DISPLAYED =
"200" |
jnlp.acs.maximiseAcsScreens
| Syntax: | -Djnlp.acs.maximiseAcsScreens="value" |
| Description: | Specifies whether the windows in the ACS UI are opened at maximum size or optimum size. |
| Type: | String |
| Allowed: |
| Default: | False |
| Notes: |
If set to:
| Example: | -Djnlp.acs.maximiseAcsScreens =
"t" |
jnlp.acs.paletteStyle
| Syntax: | -Djnlp.acs.paletteStyle =
"value" |
| Description: |
Specifies the style used to display the feature palette in the Control Plan Editor window. There are two possible feature palette styles:
| Type: | String |
| Allowed: |
| Default: | Floating panel style |
| Notes: | To enable the jnlp.acs.paletteStyle property, clear the Java cache and the client browser cache before restarting the Control Plan Editor. |
| Example: | -Djnlp.acs.paletteStyle = "old" |
jnlp.sms.port
| Syntax: | -Djnlp.sms.port = "num" |
| Description: | Specifies the SQL*Net port for connecting to the SMS host machine. |
| Type: | Integer |
| Allowed: | |
| Default: | 1521 |
| Example: | -Djnlp.sms.port = "num" |
jnlp.acs.ProfileN
| Syntax: | -Djnlp.acs.Profilenumber = "new_name"
smsGui.bat/smsGui.sh |
| Description: | Specifies to suppress or change the name of any of the 20 profile blocks. |
| Type: | String |
| Allowed: |
1 £ number £ 20 new_name is one of the following:
| Default: |
The following table lists default profile block names in the order in which they appear in feature node drop-down lists. Profile1 - VPN Network Profile Profile2 - VPNStation Profile Profile3 - Customer Profile Profile4 - Control Plan Profile Profile5 - Global Profile Profile6 - CLI Subscriber Profile Profile7 - Service Number Profile Profile8 - App Specific 1 Profile9 - App Specific 2 Profile10 - App Specific 3 Profile11 - App Specific 4 Profile12 - App Specific 5 Profile13 - App Specific 6 Profile14 - App Specific 7 Profile15 - App Specific 8 Profile16 - Any Valid Profile Profile17 - Temporary Storage Profile18 - Call Context Profile19 - Outgoing Extensions Profile20 - Incoming Extensions |
| Notes: |
| Example: |
jnlp.acs.requireCustomerReference
| Syntax: | -Djnlp.acs.requireCustomerReference =
"value" |
| Description: | Specifies whether a customer reference number is mandatory for each ACS customer that is created. |
| Type: | String |
| Allowed: |
| Default: | True |
| Notes: |
If set to:
| Example: | -Djnlp.acs.requireCustomerReference =
"f" |
jnlp.acs.scfs
| Syntax: | -Djnlp.acs.scfs = "scfn" |
| Description: |
Lists the network entities that are available for handover. The names listed in this section are used by the following feature nodes:
| Type: | String |
| Optionality: | Optional. However, the TCAP Handover feature node must have at least one scf to work. |
| Allowed: | Any scf name configured in the acs.conf file. See acsChassis SSF Configuration (SLC) for more information. |
| Default: | None |
| Notes: | For every jnlp.acs.scfs property in the
JNLP file, you must create a matching scf entry in the acs.conf file on
each SLC defining the address associated with this entry.
| Example: | -Djnlp.acs.scfs =
"SCF_Name1,SCF_Name2" |
jnlp.acs.SDRfastTimeoutDefault
| Syntax: | -Djnlp.acs.SDRfastTimeoutDefault =
"secs"
| Description: | Specifies the default fast timeout period, in seconds, for the Selection Dependent Routing feature node. If the specified timeout period expires before a customer enters a digit on their telephone keypad, the feature node exits. You can use this feature, for example, to connect calls directly to the operator after timing out. |
| Type: | Integer |
| Allowed: | Any positive integer |
| Default: | 10 |
| Notes: | |
| Example: | -Djnlp.acs.SDRfastTimeoutDefault = "5"
jnlp.sms.secureConnectionDatabaseHost
| Syntax: |
| Description: |
Specifies the connection string (including host address and port) for encrypted SSL connections to the SMF database on a non-clustered system. To use SSL connections to the database, set port
to 2484 and set the
| Type: | String |
| Allowed: | |
| Default: | |
| Example: |
jnlp.sms.secureConnectionClusterDatabaseHost
| Syntax: |
| Description: |
Specifies the connection string (including host address and port) for encrypted SSL connections to the SMF database on a clustered system. To enable secure SSL connections to the database, set port to 2484 and set the jnlp.sms.EncryptedSSLConnection property to true. |
| Type: | String |
| Allowed: | |
| Default: | |
| Notes: | If present, this property is used instead of the jnlp.sms.secureConnectionDatabaseHost property. |
| Example: |
jnlp.acs.showAnnouncementSource
| Syntax: | -Djnlp.acs.showAnnouncementSource =
"value" |
| Description: | Specifies whether announcement sources (i.e., the resource name and resource ID) are displayed next to announcement names in ACS UI windows. |
| Type: | String |
| Allowed: |
| Default: | True |
| Notes: |
If set to:
| Example: | -Djnlp.acs.showAnnouncementSource =
"f" |
jnlp.acs.showCallPlanCopy
| Syntax: | -Djnlp.acs.showCallPlanCopy =
"value" |
| Description: | Specifies whether the Copy button is enabled on the ACS Numbers screen. |
| Type: | String |
| Allowed: |
| Default: | True |
| Notes: |
If set to:
| Example: | -Djnlp.acs.showCallPlanCopy" =
"f" |
jnlp.acs.showNetwork
| Syntax: | -Djnlp.acs.showNetwork = "value" |
| Description: | Specifies whether the Network field is displayed in the ACS New Customer dialog box. |
| Type: | String |
| Allowed: |
| Default: | True |
| Notes: |
If set to:
| Example: | -Djnlp.acs.showNetwork = "f" |
jnlp.acs.ssfs
| Syntax: | -Djnlp.acs.ssfs = "ssf1,ssf2,...,ssfn"
| Description: |
Lists the switches that are available in the IN network. The switches listed in this section are used by the Call Initiation feature node (as the switch name list). |
| Type: | String |
| Optionality: | Optional. However, the Call Initiation feature node must have at least one scf to work. |
| Allowed: | Any ssf name configured in the acs.conf file. See acsChassis SSF Configuration (SLC) for more information. |
| Default: | None |
| Notes: | |
| Example: | -Djnlp.acs.ssfs =
"SSF_Name1,SSF_Name2" |
jnlp.sms.sslCipherSuites
| Syntax: | -Djnlp.sms.sslCipherSuites =
"(TLS_RSA_WITH_AES_128_CBC_SHA)" |
| Description: | Specifies the cipher suites to use for SSL encryption. You must set this property if you are using encrypted SSL for connecting to the SMS database. |
| Type: | String |
| Allowed: | (TLS_RSA_WITH_AES_128_CBC_SHA) |
| Default: | (TLS_RSA_WITH_AES_128_CBC_SHA) |
| Notes: | You must also set the SSL_CIPHER_SUITES property to (TLS_RSA_WITH_AES_128_CBC_SHA) in the listener.ora and sqlnet.ora files. |
| Example: | -Djnlp.sms.sslCipherSuites =
jnlp.acs.suppressedSDRDigits
| Syntax: | -Djnlp.acs.suppressedSDRDigits = "digits"
| Description: |
The Selection Dependent Routing feature node allows you to route calls based on the number, letter, or special character entered on the caller's telephone keypad. You use the jnlp.acs.suppressedSDRDigits property to prevent users from assigning specified digits to a calling route and to exclude those digits from the Configure Selection Dependent Routing dialog box of the ACS Control Plan Editor. |
| Type: | String |
| Allowed: |
| Default: | None |
| Notes: | |
| Example: | -Djnlp.acs.suppressedSDRDigits = "12ab" |
jnlp.acs.SuppressTagID
| Syntax: | -Djnlp.acs.SuppressTagID =
"value" |
| Description: |
Specifies to not include the profile tag value when displaying a profile field name in the ACS Control Plan Editor. For example, when jnlp.acs.SuppressTagID is set to:
| Type: | Boolean |
| Allowed: |
| Default: | True |
| Notes: |
If set to:
| Example: | -Djnlp.acs.SuppressTagID = "True"
jnlp.trace
| Syntax: | -Djnlp.trace = "value" |
| Description: | Specifies whether to enable tracing for the Control Plan Editor. The output is displayed in the Java Console. |
| Type: | Boolean |
| Allowed: | on | off, true | false, yes | no, 1 | 0, enabled | disabled |
| Default: | Off |
| Notes: | |
| Example: | -Djnlp.trace = "on" |
jnlp.sms.TZ
| Syntax: | Djnlp.sms.TZ = "timezone" |
| Description: | Specifies the time zone used for all time and date values displayed in Convergent Charging Controller UI windows. |
| Type: | String |
| Allowed: | Any Java supported time zone. |
| Default: | GMT |
| Notes: | For a full list of Java supported time zones, see Time Zones for more information. |
| Example: | -Djnlp.sms.TZ = "GMT" |
jnlp.acs.updateCPReferences
| Syntax: | -Djnlp.acs.updateCPReferences =
"value" |
| Description: | When you update a control plan, the Control Plan Editor creates a new version of the control plan. If any customers are scheduled to use the older version of the control plan, the customers' service numbers or CLIs remain attached to the older version by default. This property specifies whether you can attach customers' service numbers or CLIs to the new control plan version. |
| Type: | String |
| Allowed: |
| Default: | None |
| Notes: |
If set to:
| Example: | -Djnlp.acs.updateCPReferences =
"t" |
jnlp.ccs.UseAnnouncements
| Syntax: | -Djnlp.ccs.UseAnnouncements =
"value" |
| Description: | Specifies whether to play announcements. |
| Type: | String |
| Allowed: |
| Default: | False |
| Notes: | |
| Example: | -Djnlp.ccs.UseAnnouncements =
"Yes" |
jnlp.acs.useTNForNodeName
| Syntax: | -Djnlp.acs.useTNForNodeName = "value"
value="value" /> |
| Description: |
Specifies whether the feature node name displayed in the Control Plan Editor window is the Termination Number (TN). This applies to the following feature nodes only:
The TN is displayed for any UT or AT feature node in the CPE window, without requiring you to save each feature node to update the stored control plan data. |
| Type: | Boolean |
| Allowed: |
| Default: | False |
| Notes: |
If set to:
You can update the TN for these feature nodes in a control plan by using the ACS Numbers screen. See the discussion about Editing Termination Numbers in ACS User's Guide for more information. |
| Example: | -Djnlp.acs.useTNForNodeName =
"true" |
jnlp.acs.warnAboutUnfilledExits
| Syntax: | -Djnlp.acs.warnAboutUnfilledExits =
"True" |
| Description: |
Specifies whether a control plan passes validation if any of its feature nodes are missing exits. This property has a dependency on the
| Type: | String |
| Allowed: |
| Default: | False |
| Notes: |
If set to:
| Example: | -Djnlp.acs.warnAboutUnfilledExits =
"True" |
Example GUI Script Application Properties
Here is an example acsGui.bat/acsGui.sh file showing the application property settings at installation.
acsGui.bat
@echo off
REM Copyright (c) 2025 Oracle. All rights reserved.
REMREM This material is the confidential property of Oracle Corporation or its
REM licensors and may be used, reproduced, stored or transmitted only in
REM accordance with a valid Oracle license or sublicense agreement.
REM
REM
REM acsGui.bat: runs the ACS application
REM Run: execute acsGui.bat
REM Set JAR_PATH to the current directory
set JAR_PATH=%~dp0
REM Enable delayed expansion
setlocal enabledelayedexpansion
REM Set classpath
set
CLASSPATH=%JAR_PATH%;%JAR_PATH%sms.jar.sig;%JAR_PATH%acs.jar.sig;%JAR_PATH%common.jar
.sig;%JAR_PATH%ojdbc11.jar.sig;%JAR_PATH%oraclepki.jar.sig;%JAR_PATH%ohj.jar.sig;%JAR
_PATH%help-
share.jar.sig;%JAR_PATH%oracle_ice.jar.sig;%JAR_PATH%jewt.jar.sig;%JAR_PATH%share.jar
.sig;%JAR_PATH%osd.jar.sig;%JAR_PATH%rims.jar.sig;%JAR_PATH%xms.jar.sig;%JAR_PATH%ses
.jar.sig;
REM Starting GUI....
java ^
-Djava.util.Arrays.useLegacyMergeSort=true ^
-Djnlp.sms.TZ=GMT ^
-Djnlp.sms.host=OUI_HOSTNAME ^
-Djnlp.sms.port=LPORT ^
-Djnlp.sms.database=OUI_ORACLE_SID ^
-Djnlp.sms.databaseHost=NCC_DBHOST:LPORT:OUI_ORACLE_SID ^
-Djnlp.sms.secureConnectionDatabaseHost="(DESCRIPTION= (ADDRESS_LIST=
(ADDRESS=(PROTOCOL=TCPS)(HOST=NCC_DBHOST)(PORT=SECPORT))) (CONNECT_DATA=
(SERVICE_NAME=OUI_ORACLE_SID)))" ^
-Djnlp.sms.EncryptedSSLConnection=true ^
-Djnlp.sms.sslCipherSuites="(TLS_RSA_WITH_AES_128_CBC_SHA)" ^
-Djnlp.vpn.INProtocol=IN_PROTOCOL ^
-Djnlp.acs.SuppressTagID=TRUE ^
-Djnlp.acs.Profile8="Account Reference Profile" ^
-Djnlp.acs.Profile9="Product Type Profile" ^
-Djnlp.acs.Profile10="Control Plan Profile (App 3)" ^
-Djnlp.acs.Profile12="CCS Global Profile" ^
-Djnlp.acs.Profile13="CCS Temporary Profile (App 6)" ^
-Djnlp.acs.Profile14="CCS Temporary Profile (App 7)" ^
-Djnlp.acs.Profile15="CCS Temporary Profile (App 8)" ^
-Djnlp.acs.ACSDefaultCustomerIsPrepaid=false ^
-Djnlp.ccs.UseAnnouncements=YES ^
-cp "%CLASSPATH%" ^
com.g8labs.acs.coreScreens.Application
REM End delayed expansion
endlocal#!/bin/bash
# Copyright (c) 2025 Oracle. All rights reserved.
# This material is the confidential property of Oracle Corporation or its
# licensors and may be used, reproduced, stored or transmitted only in
# accordance with a valid Oracle license or sublicense agreement.
# acsGui.sh : runs the ACS application
# Run: bash acsGui.sh
JAR_PATH=$(pwd)
CLASSPATH=$JAR_PATH/:$JAR_PATH/sms.jar.sig:\
$JAR_PATH/acs.jar.sig:\
$JAR_PATH/common.jar.sig:\
$JAR_PATH/ojdbc11.jar.sig:\
$JAR_PATH/oraclepki.jar.sig:\
$JAR_PATH/ohj.jar.sig:\
$JAR_PATH/help-share.jar.sig:\
$JAR_PATH/oracle_ice.jar.sig:\
$JAR_PATH/jewt.jar.sig:\
$JAR_PATH/share.jar.sig:\
$JAR_PATH/osd.jar.sig:\
$JAR_PATH/rims.jar.sig:\
$JAR_PATH/xms.jar.sig:\
$JAR_PATH/ses.jar.sig:
echo "Starting GUI...."
exec ${JAVA_HOME}/bin/java \
-Djava.util.Arrays.useLegacyMergeSort=true \
-Djnlp.sms.TZ=GMT \
-Djnlp.sms.host=OUI_HOSTNAME \
-Djnlp.sms.port=LPORT \
-Djnlp.sms.database=OUI_ORACLE_SID \
-Djnlp.sms.databaseHost=NCC_DBHOST:LPORT:OUI_ORACLE_SID \
(SERVICE_NAME=OUI_ORACLE_SID)))" \
-Djnlp.sms.EncryptedSSLConnection=true \
-Djnlp.sms.sslCipherSuites="(TLS_RSA_WITH_AES_128_CBC_SHA)" \
-Djnlp.vpn.INProtocol=IN_PROTOCOL \
-Djnlp.acs.SuppressTagID=TRUE \
-Djnlp.acs.Profile8="Account Reference Profile" \
-Djnlp.acs.Profile9="Product Type Profile" \
-Djnlp.acs.Profile10="Control Plan Profile (App 3)" \
-Djnlp.acs.Profile12="CCS Global Profile" \
-Djnlp.acs.Profile13="CCS Temporary Profile (App 6)" \
-Djnlp.acs.Profile14="CCS Temporary Profile (App 7)" \
-Djnlp.acs.Profile15="CCS Temporary Profile (App 8)" \
-Djnlp.acs.ACSDefaultCustomerIsPrepaid=false \
-Djnlp.ccs.UseAnnouncements=YES \
-cp "$CLASSPATH" \
