4 User Interface
Overview
Introduction
This chapter explains the functionality provided by the ACS user interface (UI).
Using the Search Option
Introduction
The search function enables a specific number to be found.
Search Screen Example
Here is an example of the Search for Numbers screen.
This is image alt text.
Searching for Numbers
Follow these steps to find a number.
Step Action
1
From the Numbers screen, click Search.
Result: The Search for Numbers screen displays.
2
Enter selection criteria in one or more query fields.
  • Customer Name
  • Customer Number
  • Toll Free Number
  • CLI Number
Tip: If a field is left empty, then the search will ignore that field.
3
Select one of the result filter options:
  • Show all
  • Customers only
  • Service numbers only
  • CLI numbers only
4
Click Find to start the search.
Result: All matches are displayed in the Search Results section of the screen.
5 To clear the selection fields, click Reset.
6
To close the search screen, click Cancel.
Result: The Numbers screen displays again.
7
To select a found number, click the record line and click Select.
