4 Background Processes on the SLC
This chapter provides a description of the programs or executables used by CCS as background processes on the SLCs.
Executables are located in the /IN/service_packages/CCS/bin directory.
Some executables have accompanying scripts that run the executables after performing certain cleanup functions. All scripts should be located in the same directory as the executable.
For more information about the processes and systems that use these programs and executables, see System Overview.
WARNING:
It is a pre-requisite for managing these core service functions that the operator is familiar with the basics of Unix process scheduling and management. Specifically, the following Unix commands:
  • init (and inittab)
  • cron (and crontab)
  • ps
  • kill
  • top
  • vi (or other editing tool)
BeClient
The BeClient is a SLEE interface which handles connections to the beServer process on the VWS for SLEE applications running on the SLC.
The BeClient needs to be configured for CCS so functions such as voucher recharge can be completed. This is implemented as a CCS specific plug-in that is described further below.
For more information about the BeClient, see VWS Technical Guide.
BeClient plugins
The BeClient can be extended by installing plug-ins. This section lists the available BeClient plug-ins which are provided with CCS.
Voucher Plugin
This plug-in controls the voucher recharge process. It splits the voucher recharge wallet message into three messages:
  • Voucher reserve
  • Wallet recharge
  • Voucher commit
If the voucher reserve or wallet recharge operation fails, the whole process stops. This allows for the possibility that the vouchers and wallets are on different VWS pairs and provides for an automatic voucher redeem process that does not require post-process reversals.
This function is contained within the libccsClientPlugins.so library.
For this plug-in to function properly, the Broadcast plug-in (libclientBcast.so) must also be installed and configured. For more information about the Broadcast plug-in, see VWS Technical Guide.
Merge Wallets Plug-in
The plug-in manages the merging of two wallets. It:
  • Receives merge wallets requests.
  • Obtains identifiers for the wallets involved.
  • Determines whether a link or a merge is required.
  • If a link is required, the plug-in relinks the wallets and subscribers.
  • If a merge is required, the plug-in:
    • Locks the source wallet for 30 seconds,
    • Merges the source and destination wallets
    • Relinks the wallets and subscribers.
The merge wallets function is contained in the libccsClientPlugins.so library.
Location
This binary is located on SLCs.
Startup
The BeClient is a SLEE interface and is started during SLEE initialization. The line in the SLEE.cfg which starts the BeClient is:
INTERFACE=ccsBeClient BeClientStartup.sh /IN/service_packages/CCS/bin/ 1 EVENT
The above settings are defaults and may vary.
For instructions about starting and stopping BeClient, see SLEE Technical Guide.
Configuration
In order to load and operate, BeClient plug-ins read the BeClient section of the eserv.config file. The BeClient section is listed below, showing the configuration for the plug-ins provided with CCS.
This text does not show the full configuration for BeClient. For more information about the full configuration for the BeClient, see VWS Technical Guide.
BeClient = {
             standard BeClient configuration
             plugins = [
                     # Voucher recharge plugin (VRW)
                     config="voucherRechargeOptions",
                     library="libccsClientPlugins.sl",
                     function="makeVoucherRechargePlugin"
                     # Broadcast plugin needed by VRW
                     config="broadcastOptions",
                     library="libclientBcast.so",
                     function="makeBroadcastPlugin"
                     # Voucher Type recharge plugin (VTR)
                     config="voucherTypeRechargeOptions",
                     library="libccsClientPlugins.so",
                     function="makeVoucherTypeRechargePlugin"
voucherRechargeOptions = {
              voucherRechargeTriggers = [
                     "VRW "
                 srasActivatesPreuseAccount = false
                 srActivatesPreuseAccount = true
                 sendBadPin = false
broadcastOptions = {
                 aggregateNAckCodes = [
                     "NVOU"
voucherTypeRechargeOptions = {
                 srasActivatesPreuseAccount=false
                 voucherTypeRechargeTriggers = ["VTR "]
Parameters
BeClient has no command line parameters.
The BeClient supports the following parameters from the BE section of eserv.config.
plugins
Syntax
plugins = [
         config=""
         library="lib"
         function="str"
Description Defines any client process plug-ins to run. Also defines the string which maps to their configuration section.
Type Parameter array
Optionality Mandatory
Allowed
Default
Notes
The VRW needs the libclientBcast plug-in to function properly. It must be placed last in the plugins configuration list.
For more information about the libclientBcast plug-in, see VWS Technical Guide.
Example
plugins = [
        function="makeVoucherRechargePlugin" }
        function="makeBroadcastPlugin" }
        function="makeVoucherTypeRechargePlugin"}
config
Syntax config="name"
Description The name of the configuration section for this plug-in. This corresponds to a configuration section within the plugins section in the eserv.config file.
Type String
Optionality Required (must be present to load the plug-in)
Allowed
Default No default
Notes
Example config="voucherRechargeOptions"
function
Syntax function="str"
Description The function the plug-in should perform.
Type String
Allowed
Default No default
Notes
Example function="makeVoucherRechargePlugin"
library
Syntax library="lib"
Description The filename of the plug-in library.
Type String
Allowed
Default No default
Notes
Example library="libccsClientPlugins.so"
broadcastOptions
Syntax
              aggregateNAckCodes = [config]
Description Name of configuration section for the BeClient Broadcast plug-in libclientBcast.
Optionality
Allowed
Default
Notes
libclientBcast is used by a range of processes which connect to the beServer, including:
  • BeClient
  • PIbeClient
  • ccsBeOrb
For more information about libclientBcast, see libclientBcast.
Example
      aggregateNAckCodes = [ ]
aggregateNAckCodes
Syntax
            "NVOU"
Description When this parameter is set, the BeClient waits for a response from all the VWS pairs in use and filters the responses from the broadcast request using the configured NAck codes.
Optionality
Allowed NVOU
Default
Notes When a voucher recharge request is broadcast, this ensures that all the available VWS pairs are checked for the required voucher before a voucher not found message is returned to the requesting process.
Example
maxPollTime
Syntax
maxPollTime = micro-seconds
Description Maximum poll time in micro-seconds for BeClient.
Type Integer
Optionality Optional (default used if not set).
Allowed
Default 10000
Notes
Example
BE = {
    BeClient = {
        maxPollTime = 100000 #100 ms
Example
BeClient = {
      clientName = "scpClient1"
      heartbeatPeriod = 3000000
      maxOutstandingMessages = 100
      connectionRetryTime = 5
   plugins = [
          function="makeVoucherRechargePlugin"}
          "VRW "
   sendBadPin = false
          "NVOU"
  notEndActions = [ {type="IR  ", action="ACK "}
                  {type="SR  ", action="ACK "}
                  {type="SR  ", action="NACK"}
                  {type="INER", action="ACK "}
                  {type="SNER", action="ACK "}
                  {type="SNER", action="NACK"}
Output
The BeClient writes error messages to the system messages file.
PIClientIF
The PI Client Interface is a TCP client interface that runs on the SLC and communicates with one or more PIProcesses running on the SMS.
PI commands are received from the Service Logic Execution Environment (SLEE) and forwarded to any available PI process with the appropriate synstamp. PI responses are sent back to the SLEE on the appropriate dialog.
Add subscriber (CCSCD1=ADD) and delete subscriber (CCSCD1=DEL) commands are both supported. Add subscriber can be configured to override or add additional parameters to those provided in the incoming message, but delete subscriber does not require additional configuration, which is why there is no CCSCD1.DEL section in the example configuration file.
Startup
The PIClientIF is a SLEE interface and is started during SLEE initialization. The line in the SLEE.cfg which starts the PIClientIF is:
INTERFACE=ccsPiClientIF ccsPiClientIF.sh /IN/service_packages/CCS/bin 1 EVENT
For instructions about starting and stopping PIClientIF, see SLEE Technical Guide.
Output
The PIClientIF writes error messages to the system messages file.
Example
piClientIF = {
 # Hostname or IP address of the PI
 # (Mandatory)
 # Default: None
 # host = "usms"
 # Ports on which the PI processes are listening
 # (Mandatory)
 # Default: None
 ports = [ 2999 , 3000 ]
 # Username for the PI login
 # (Optional)
 # Default: "admin"
 username = "admin"
 # Password for the PI login
 # (Optional)
 # Default: "admin"
 password = "admin"
 # Time (in milliseconds) to wait for a response
 # from the PI.
 # (Optional)
 # Default: 2000
 timeoutInterval = 2000
 # Maximum number of timed-out PI requests on
 # a connection before that connection is closed
 # where "0" indicates that the connection will
 # be immediately closed after a timeout occurs.
 # It is recommended that maxTimeouts is set to
 # the default (0), the connection will be
 # re-opened after connectionRetryTimeout has
 # expired.
 # (Optional)
 # Default: 0
 maxTimeouts = 0
 # Time (in milliseconds) to wait before re-trying
 # a failed connection.
 # (Optional)
 # Default: 1000
 connectionRetryTimeout = 1000
 # Maximum number of outstanding PI requests.
 # New requests will be rejected if this limit
 # is reached.
 # (Optional)
 # Default: 50
 maxQueueSize = 50
 # Period (in milliseconds) to log statistics for
 # debugging. Information such as pending request
 # queue length, number of available connections
 # and notifications of dialog closed events will
 # be logged. A value of "0" indicates this feature
 # is disabled. Note: some PI requests (eg CCSCD1=DEL)
 # will not be sent on more than 1 connection at a time.
 # (Optional)
# Default: 0
statsTimer = 0
ccsActions
ccsActions provides the functions which enable the CCS Feature Nodes to interact with other elements in the system, including:
  • acsChassis
  • the VWS (via the BeClient and beServer), and
  • other elements on the network (such as the VPU).
Startup
If ccsActions is included in the acs.conf, ccsActions will be started by slee_acs when the SLEE is started.
For more information about how this included in acs.conf, see acsChassis.
Configuration
In order to load and operate, ccsActions reads the ccsActions section of the eserv.config file. The ccsActions section is listed below.
ccsActions = {
    maxOutstandingBeClientMsgs = int
    loggedNotificationPeriod = int
    loggedInvalidPeriod = int
    exceptionLogPeriod = int
    configuredVolumeITC = int
    volumeReservationLength = int
    accumulateChargeInfoCosts = true|false
    allowNegativeNofundsPolicyOnCommit = true|false
Parameters
ccsActions supports the following parameters from the CCS section of eserv.config.
Syntax accumulateChargeInfoCosts = true|false
Description Determines if charge costs are allowed to accumulate.
Type Boolean
Allowed
  • true - will allow to accumulate
  • false - will reset the cost for each charge
Default true
Notes
Example accumulateChargeInfoCosts = true
allowNegativeNoFundsPolicyOnCommit
Syntax allowNegativeNoFundsPolicyOnCommit = true|false
Description If funds have been depleted during a reservation request, sets whether or not to allow the overall balance to go negative when committing the reservation.
Type Boolean
Allowed
true (allow the overall balance to go negative)
false (do not allow the overall balance to go negative)
Default false
Notes
Example allowNegativeNoFundsPolicyOnCommit = true
configuredVolumeITC
Syntax configuredVolumeITC = val
Description Sets the bearer capability - Information Transfer Capability value for a data charging session.
Type
Optionality
Allowed
Valid values (in decimal) are:
  • 0 = speech
  • 8 = UDI (unrestricted digital information)
  • 9 = RDI (restricted digital information)
  • 16 = 3.1 kHz Audio
  • 17 = UDI with tones / announcements (Q.931 1998)
  • 24 = Video
Default 8
Notes
Example configuredVolumeITC = 8
loggedInvalidPeriod
Syntax loggedInvalidPeriod = seconds
Description Interval separating the writing of each summary of ccsActions errors to the syslog.
Type
Allowed
Default 10
Notes
Example loggedInvalidPeriod = 10
Syntax loggedNotificationPeriod = int
Description The logged notification period.
Type Integer
Optionality
Allowed
Default
Notes
Example loggedNotificationPeriod = 10
Syntax maxOutstandingBeClientMsgs = number
Description The maximum number of outstanding BeClient messages.
Type Integer
Optionality Optional (default used if missing)
Allowed
Default 1000
Notes Too small a value may result in calls being dropped.
Example maxOutstandingBeClientMsgs = 2000
quotaProfileBlock
Syntax quotaProfileBlock = int
Description
The profile block number to use for retrieving quota related profile fields. Five pairs of quota value and quota opt-out tags are looked up in this block:
  • Quota value tags (numbers 0x140511 to 0x140515)
  • Quota opt-out tags (numbers 0x140521 to 0x140525)
Type Integer
Allowed An integer in the range 8 to 15 for the APP1 to APP8 profile blocks, or 16 for the ANY_VALID profile block.
Default 8 – This is the subscriber profile block
Notes
Example quotaProfileBlock = 16
Syntax volumeReservationLength = days
Description The reservation length, in days, for data charging sessions such as Radius Control Agent.
Type
Optionality
Allowed
Default 5
Notes The UBE parameter noExpectedKeep should be set to the same value (in seconds) as this parameter. See VWS Technical Guide.
Example volumeReservationLength = 5
Example
ccsActions = {
       maxOutstandingBeClientMsgs = 1000
Failure
If ccsActions fails, the CCS feature node functionality will fail. This will usually result in call processing becoming unstable or failing.
Output
ccsActions writes summaries of its error messages to the system messages file.
ccsCB10HRNAES
The ccsCB10HRNAES library is available only if you have purchased the Voucher Management license.
For more information about this library, see Voucher Manager Technical Guide.
ccsCB10HRNSHA
The ccsCB10HRNSHA library is available only if you have purchased the Voucher Management license.
ccsMacroNodes
The CCS service library handles initial call setup for calls that use CCS functionality and configures any necessary profile data used in CCS feature node parameters. For information about the available CCS feature nodes, see Feature Nodes Reference Guide.
Startup
If ccsMacroNodes is configured in acs.conf, it is made available to slee_acs when slee_acs is initialized. It is included in the acsChassis section of acs.conf in a MacroNodePluginFile entry as follows:
acsChassis
   MacroNodePluginFile ccsMacroNodes.so
Configuration
ccsMacroNodes accepts the following parameters.
Example ccsMacroNodes config
Here is an example of the CCS.ccsMacroNodes section of the eserv.config file.
ccsMacroNodes = {
      expireAtMidnightTZ="GMT"
      MaximumMenuRetries = 2
      MaximumBadCodeRetries = 3
      MaxCreditCardNumberLength = 20
      MinCreditCardNumberLength = 20
      PromptAndCollectMaxAnnouncements = 10
      PromptAndCollectInterMenuBlockTimeout = 1
      ATBNoAnswerTimeout = 10
      AVPProfileTagData = ["Idle", "Blocked"]
      CCACustomAvpProfileTag = 512
      resetUATBOnINSF = false
      armAnswer = false
      PAVRBalancesUseSystemCurrency = true
      NoChargeEventClass = "FnF FnD Events"
      NoChargeEventName = "FnF Config Change"
          FFDiscountRule = "EXPLICIT"
          HomeCountryNationalPrefix = ""
          UseDisconnectLeg = false
          BFTGracePeriodLength = 0
          BSPlayAllExpiriesAtEnd = false
          VRRedeemUnavailableBranch = 3
          BSAnnBalanceTypes = [
             acsCustomerId = 1
             balTypeIds = [6, 7, 10]
          DOCCRAnnBalanceTypes = [
             acsCustomerId = 1
             balTypeIds = [6, 7]
          VRRedeemMinVoucherLength=9
          VRRedeemMaxVoucherLength=15
          VRRedeemAcctFrozenCheck=true
          SMSCIIncludeZeroBalances = true
          SMSCIExcludeZeroBalanceTypes = [78,79]
          SMSABUseFormattedExpiryDate=true
          SMSABExpiryFormat = "%d/%m/%y"
          # UATB Node:
          # If vws returns IR_Nack with INSF -
          #   [1] create a zero-value reservation
          #   [2] enable SR_Ack grants of 0
          #   [3] grant 0 deciseconds in AC
          # Optional.
          holdReservationOpen = false
          # UATB Node
          # Enable UATB macronode loopback
          # Optional.
          macronodeLoopbackBranch1 = false  #IR_Ack no funds
          macronodeLoopbackBranch15 = false #SR_Nack no funds
          macronodeLoopbackBranch16 = false #SR_Ack with funds
          # UATB Node
          # Reroute IR_Nack failures to alternative exits
          # Optional.
          IR_Nack = {
          # The following are default settings:
          PROC = 2 # Route IR_Nack[PROC] (UnknownWallet)      to exit 2: BFT
          INSF = 1 # Route IR_Nack[INSF] (InsufficientFunds)  to exit 1: Declined(No Funds)
          TMNY = 1 # Route IR_Nack[TMNY] (MaxConcurrent)      to exit 1: Declined(No Funds)
          CRIS = 1 # Route IR_Nack[CRIS] (CallRestricted)     to exit 1: Declined(No Funds)
          COM = 2 # Route IR_Nack[COM ] (CommunicationError) to exit 2: BFT
          NACK = 2 # Route IR_Nack[NACK] (SystemError)        to exit 2: BFT
          WDIS = 1 # Route IR_Nack[WDIS] (WalletDisabled)     to exit 1: Declined(No Funds)
ATBNoAnswerTimeout
Syntax
Description
Type
Optionality
Allowed
Default 10
Notes This parameter is not used.
Example
Syntax HomeCountryNationalPrefix = "prefix"
Description Defines the prefix for the home country.
Type String
Optionality
Allowed
Default ""
Notes
Example HomeCountryNationalPrefix = ""
AVPProfileTagData
Syntax AVPProfileTagData = ["value1", "value2",…]
Description This parameter holds the values which should be checked with CCACustomAvpProfileTag.
Type Array
Optionality
Allowed
Default None
Notes
Example AVPProfileTagData = ["Idle", "Blocked"]
Syntax CCACustomAvpProfileTag = num
Description This parameter decide the profile tag which is holding the AVP value. The value 0 indicates that the feature is disabled.
Type Integer
Optionality
Allowed Numerical value
Default 0
Notes
Example CCACustomAvpProfileTag = 512
The profile tag configured in CCACustomAvpProfileTag should be of type string. As per the above example, profile tag 512 should be of type string.
resetUATBOnINSF
Syntax resetUATBOnINSF = true|false
Description This flag decides whether to reset the UATB state in case of insufficient balance and exit from UATB exit1.
Type Boolean
Optionality
Allowed true, false
Default false
Notes
Example resetUATBOnINSF = false
Syntax MaxCreditCardNumberLength = len
Description Defines the maximum length allowed for credit card numbers.
Type Integer
Optionality
Allowed
Default 20
Notes Applies to the Credit Card Starter Menu node only.
Example MaxCreditCardNumberLength = 20
Syntax
Description
Type integer
Optionality
Allowed
Default
Notes This parameter is not used currently.
Example
MaximumMenuRetries
Syntax MaximumMenuRetries = num
Description Defines the maximum number of times the subscriber can attempt to enter voucher numbers, PINs, and other menu options correctly, before they are blocklisted.
Type Integer
Optionality
Allowed
Default 2
Notes Applies to all nodes which limit subscriber retry attempts.
Example MaximumMenuRetries = 2
Syntax MinCreditCardNumberLength = len
Description Defines the minimum length allowed for credit card numbers.
Type Integer
Optionality
Allowed
Default 20
Example MinCreditCardNumberLength = 20
Syntax PromptAndCollectInterMenuBlockTimeout = seconds
Description Defines the timeout in seconds, after playing all the announcements for the current menu.
Type Integer
Optionality
Allowed
Default 1
Notes Applies to the Account Type Swap, Dynamic Menu, and Credit Card Recharge nodes.
Example PromptAndCollectInterMenuBlockTimeout = 1
Syntax PromptAndCollectMaxAnnouncements = num
Description Defines the maximum number of announcements to play at one time.
Type Integer
Optionality
Allowed
Default 10
Notes Applies to the Account Type Swap and Dynamic Menu nodes only.
Example PromptAndCollectMaxAnnouncements = 10
Syntax VRRedeemUnavailableBranch = num
Description This parameter determines the exit branch when NACK-VBUA is returned.
Type Integer
Optionality
Allowed 2 to 10
Default 5
Notes
Example VRRedeemUnavailableBranch = 3
armAnswer
Syntax armAnswer = true|false
Description This flag decides whether to arm the UATB with oAnswer as well.
Type Boolean
Allowed true, false
Default false
Notes To handle ERBCSM answer event in ACS, see ACS Configuration in the Advanced Control Services Technical Guide.
Example armAnswer = false
Node Specific Parameters
Additional node-specific parameters follow.
Balance Status
BSAnnBalanceTypes = [{}{}]
The list of balance types to be announced in the node. This parameter is mandatory.
acsCustomerId
Default 1
balTypeIds
[n,n,n]
Syntax BSPlayAllExpiriesAtEnd = true|false
Description Determines if each expiry is played after its corresponding balance announcement.
Type Boolean
Allowed
  • true - Play all expiry limits after all balance announcements are played.
  • false - Play each expiry to be after its corresponding balance announcement.
Default
Notes
Example BSPlayAllExpiriesAtEnd = false
RetryReserveOnNoFunds
Syntax RetryReserveOnNoFunds = true|false
Description
When true, the UATB node will try a second reservation attempt when:
  • Only the duration withheld from the IRR remains
  • We have received a NAck from the BE on our final reservation
This is intended for use with configurations where a low credit notification may be triggered by the reservation attempt, which recharges the account or frees other funds. The second attempt may then succeed.
Type Boolean
Allowed true, false
Default false
Notes
Example RetryReserveOnNoFunds = false
Balance Status Branch
BSBCheckBalance
The list of balance types to check for each customer. The balance types must all have the same balance unit. For more information, see Introduction to Charging Control Services. This parameter is optional.
acsCustomerId
Default 1
balTypeIds
[n,n,n]
expireAtMidnightTZ
Syntax expireAtMidnightTZ = "tz"
Description Sets wallets and buckets to expire at midnight for the time zone specified.
Type String
Allowed
The time zone part of the parameter must be typed in a form that the operating system recognizes.
Alternatively you can select a time zone from the operating system's list. To view top-level time zone names, enter ls /usr/share/lib/zoneinfo from a shell. To see second-level time zone names enter ls /usr/share/lib/zoneinfo TopLevelName/. For example, to verify that the operating system recognizes a time zone name for DeNoranha, in Brazil, you would enter ls /usr/share/lib/zoneinfo/Brazil/. DeNoranha is listed, so the time zone name would be "Brazil/DeNoranha".
Default false (do not modify expiry calculation).
Notes A list of time zones can be found in the Time Zones appendix of ACS Technical Guide.
Example
An account is created at 2 p.m. on 5 September 2006 and is set to have a life span of 24 days.
If the parameter expireAtMidnightTZ = "Asia/Vladivostok" is included, the account will expire on 29 September 2006 at midnight, Vladivostok time.
If this parameter is omitted, the account will expire on 29 September 2006 at 2 p.m.
Call Info
Syntax SMSCIIncludeZeroBalances = true|false
Description Controls the inclusion of zero balances in the final notification composed by the Call Information SMS feature node.
Type Boolean
Allowed
true - Include zero balances
false - Exclude zero balances
Default false
Notes This value determines the behavior of all instances of the Call Information SMS feature node. For information about the Call Information SMS feature node, see Feature Nodes Reference Guide.
Example SMSCIIncludeZeroBalances = true
Syntax
SMSCIExcludeZeroBalanceTypes = [n,n,n]
where, n = ccs_balance_type.ID
Description
Controls the exclusion of balance types having value zero, in the final notification composed by the Call Information SMS (SMSCI) feature node.
When SMSCIIncludeZeroBalances is set as true, then by default all the balance types having value as zero, are included in the notification composed by SMSCI node. In this case, SMSCIExcludeZeroBalanceTypes will help in excluding the unwanted balance types from the notification string.
Type
Allowed ccs_balance_type.ID
Default
Notes
Example SMSCIExcludeZeroBalanceTypes = [78,79]
Do Credit Card Recharge
DOCCRAnnBalanceTypes = [{}{}]
The list of balance types (Cash only) to be announced in the node (mandatory).
acsCustomerId
Default 1
balTypeIds
[n,n,n]
Friends and Family config
FFDiscountRule
Syntax FFDiscountRule = "rule"
Description Determines how discount is applied for an individual call.
Type string
Optionality
Allowed
Valid values are:
  • EXPLICIT = the discount is applied as configured
  • DIVIDED = the discount applied is divided by the number of F+F members configured for the subscriber.
Default "EXPLICIT"
Notes
Example FFDiscountRule = "EXPLICIT"
NoChargeEventClass
Syntax NoChargeEventClass = "class"
Description The event class to use when sending named event requests to the Voucher and Wallet Server.
Type string
Optionality
Allowed A valid event class
Default "FnF FnD Events"
Notes
Example NoChargeEventClass = "FnF FnD Events"
NoChargeEventName
Syntax NoChargeEventName = "name"
Description The event name to use when sending named event requests to the Voucher and Wallet Server.
Type string
Optionality
Allowed A valid event name
Default "FnF Config Change"
Notes
Example NoChargeEventName = "FnF Config Change"
Play Voucher Redeemed Info config
Syntax PAVRBalancesUseSystemCurrency = true|false
Description Whether to force the use of the system currency for the Play Voucher Redeemed Info feature node.
Type Boolean
Allowed
true: Use the system currency.
false: Use the currency of the active wallet.
Default false
Notes
In addition, the configuration item systemCurrencyIdAgeSeconds may be used to control the cache time applied to system currency ID.
For more information about the Play Voucher Redeemed Info feature node, see Feature Nodes Reference Guide.
Example PAVRBalancesUseSystemCurrency = false
SMS Account Balance
SMSABExpiryFormat
Syntax SMSABExpiryFormat = "format"
Description If SMSABUseFormattedExpiryDate is set to true, use this format.
Type String
Allowed: Maximum format length is 49 characters
Default: "%d/%m/%y"
Notes:
Example: SMSABExpiryFormat = "%d/%m/%y"
SMSABIncludeZeroBalances
Syntax SMSABIncludeZeroBalances = true|false
Description Whether to include zero balances when using SMS Account Balance node.
Type Boolean
Allowed
true: Include zero balances in the notification.
false: Do not include zero balances in the notification.
Default false
Notes
Example SMSABIncludeZeroBalances = true
Syntax SMSABUseFormattedExpiryDate = true|false
Description Whether or not to format the expiry date.
Type Boolean
Allowed
true: Use SMSABExpiryFormat to define how the expiry date is formatted.
Do not alter the format of the expiry date.
Default false
Notes If set to true, the date variable should be included in the Balance Expiry Template (for example, using "It will expire on %s."). For more information about the Balance Expiry Template, see Charging Control Services User's Guide.
Example SMSABUseFormattedExpiryDate = false
UATB
The following parameters are used for the UATB node.
The UATB node may also require switch configuration. See Switch Configuration for the UATB Node.
Syntax BFTGracePeriodLength = seconds
Description How to handle grace periods for reservations under BFT.
Type Integer
Allowed
  • -1 – No grace period on BFT (communication or system error) for subsequent reservations. Node will branch disconnected (NSF) on communication/system error.
  • 0 – No grace period on BFT (communication or system error) for subsequent reservations. Node will properly treat call as BFT, branching disconnected (BFT) on communication/system error. Call length of 0 is confirmed.
  • Positive – The call is allowed to continue for the specified number of seconds on communication/system error for subsequent reservations. Node will properly treat call as BFT, branching disconnected (BFT) on communication or system error. Call length of O is confirmed.
Default -1
Notes BFT is usually triggered when a Voucher and Wallet Server fails. Used with UATB node.
Example BFTGracePeriodLength = 30
continueIfAnnouncementFails
Syntax continueIfAnnouncementFails = true|false
Description
If the UATB feature node fails to play the pre-announcement and this flag is set to:
  • true – The UATB feature node continues to try to charge the subscriber.
  • false – The UATB feature node follows the appropriate failure branch.
Type Boolean
Allowed true or false
Default false
Example continueIfAnnouncementFails = true
MinResRemainingBeforeSubReservation
Syntax MinResRemainingBeforeSubReservation = num
Description
The value the UATB uses to decide if it should issue a subsequent reservation (SR) request to the VWS.
An SR request is made if the remaining reservation is greater than this parameter (read notes below).
Type Integer
Optionality Optional (default value used if not set)
Allowed -1 for no limit (that is, infinite), or any integer.
Default 300
Notes
  • When configured, if the time elapsed since the last SR was sent exceeds the the "Requested Reservation Chunk" value on the SMS screens, then UATB will send an SR, regardless of any value set for this parameter.
  • The units will be in the units applicable for the service being processed. For example for Camel voice, the units will be in deci-seconds. If the SLC processes calls or sessions for more than one type of service or protocol, then service-specific configuration will be required for each service (see Service).
  • This feature can be used to prevent the SLC from generating too many reservation request messages to the VWS if the remaining reservation is below the configured threshold.
  • For Used Units Confirmation (UUC) functionality, configure this value to a large value or -1 so an SR Request message will always be sent to the VWS and reservations size can be controlled by the "Requested Reservation Chunk" value on the SMS screens.
  • The value configured at the ccsMacroNodes level will be the default or global value used if no service-specific configuration exists (see Service).
Example MinResRemainingBeforeSubReservation = 300
Service
Syntax Service = [{service1}{service2}{servicen}]
Description Different MinResRemainingBeforeSubReservation values can be configured for different services on the SLC. Each array element or sub-section in the Service Array specifies the ACS service name and corresponding MinResRemainingBeforeSubReservation value for that service.
Type Array
Notes If no service array exists or if no service-specific entry exists in the Service array section for the specific service, the ccsUATB node will use the global value described in the parent section.
Example
Here is example array:
Service = [
                 ServiceName = "CCS_DATA"
                 MinResRemainingBeforeSubReservation = -1
                 ServiceName = "CCS"
                 ServiceName = "CCS_OTHER"
UseDisconnectLeg
Syntax UseDisconnectLeg = true|false
Description How to end BFT call.
Type Boolean
Allowed
  • true – Sends a TCAP Disconnect (2).
  • false – Sends a TCAP release.
Default false
Notes
Example UseDisconnectLeg = true
Voice Call Cost
VCCTimeAnnParts
Syntax VCCTimeAnnParts = num
Description Defines the number of variable parts to use for time balance announcements.
Type
Optionality Optional.
Allowed
Default 2
Notes
Example VCCTimeAnnParts = 2
Voucher Recharge
Syntax VRRedeemAcctFrozenCheck = true|false
Description Whether or not ccsMacroNodes should check whether the subscriber's account state is frozen following voucher redeem failure.
Type Boolean
Allowed
  • true – Use a WI request to check the subscriber's account state.
  • false – Do not send a wallet information request.
Default true
Notes
Example VRRedeemAcctFrozenCheck = true
VRRedeemDefaultScenario
Syntax VRRedeemDefaultScenario = true|false
Description Indicates if the voucher recharge node should attempt to use a default scenario.
Type Boolean
Allowed true, false
Default false
Notes
Needs to be set to true for VWS vouchers using default scenarios.
For Voucher Manager vouchers this parameter has no effect.
Example VRRedeemDefaultScenario = true
Syntax VRRedeemMaxVoucherLength = len
Description The maximum number of digits in a voucher number.
Type Integer
Allowed Must be equal to or larger than VRRedeemMinVoucherLength.
Default 14
Notes See also VRRedeemMaxVoucherLength .
Example VRRedeemMaxVoucherLength = 15
Syntax VRRedeemMinVoucherLength = len
Description The minimum number of digits in a voucher number.
Type Integer
Allowed Must be equal to or smaller than VRRedeemMaxVoucherLength.
Default 14
Notes See also VRRedeemMinVoucherLength .
Example VRRedeemMinVoucherLength = 9
ccsSvcLibrary
Based on the incoming call details, the ccsSvcLibrary loads up the relevant control plan and feature nodes.
Startup
If ccsSvcLibrary is configured in acs.conf, it is made available to slee_acs when slee_acs is initialized. It is included in the acsChassis section of acs.conf in a ServiceEntry.
acsChassis
   ServiceEntry (CCS,ccsSvcLibrary.so)
Configuration
ccsSvcLibrary supports parameters from the ccsServiceLibrary parameter group in the eserv.config file on a SLC. It contains parameters arranged in the structure shown below.
ccsServiceLibrary = {
       UnknownDataReleaseCause = int
       callPlanAndDataCacheValidityTime = seconds
       callPlanAndDataCacheFlushTime = seconds
       callPlanAndDataCacheMaxAge = seconds
       enableProfile6 = true|false
       AccountLength = int
       IncomingCallBarEnable = "int"
       IncomingCallBarDisable = "int"
       MobileTerminatingHomeCli = "cli"
       ContinueAsConnect = true|false
       InterpretAccountNumberAsCLI = true|false
       NoCallPlanError = "sev"
       GlobalDefaultForAcctRefCallPlanName = "name"
       GlobalDefaultForSMOrigCallPlanName = "name"
       GlobalDefaultForSMTermCallPlanName = "name"
       globalCapabilityFlushPeriod = 10
       promptForAccountOnOriginatingSK = true|false
       promptForAccountOnTerminatingSK = true|false
       productCapabilitiesCacheFlushTime = seconds
       productCapabilitiesCacheMaxAge = seconds
       productCapabilitiesCacheValidityTime = seconds
       productTypeForExternalSub = "pt_name"
       SubscriberDomainType = id
       VoucherDomainType = id
       PreCallAnnouncementId = id
       WithheldDuration = int
       SingleReservation = true|false
       PreCallLowBalance = true|false
       RetrieveLCRNumbers = true|false
       ConvergedScenario = true|false
AccountLength
Syntax AccountLength = int
Description Defines the length of the subscriber number, and is used when splitting the subscriber number entered from the PIN.
Type Integer
Optionality
Allowed
Default 10
Notes
Example AccountLength = 10
Syntax callPlanAndDataCacheFlushTime = seconds
Description How often a check is made for data older than its validity time.
Type Integer
Allowed Any positive integer
Default 3600
Notes
Applies to control plans matched on originator or destination addresses only.
To reload the cache more frequently with the latest versions of control plans, set the callPlanAndDataCacheFlushTime to a low value. For example, when set to 60, the cache is flushed every 60 seconds.
Example callPlanAndDataCacheFlushTime = 300
Syntax callPlanAndDataCacheMaxAge = seconds
Description The time after which an unused or unchanged control plan is dropped from the control plan cache.
Type Integer
Default 3600
Notes
To reload the cache more frequently with the latest versions of control plans, set the callPlanAndDataCacheMaxAge to a low value. For example, when set to 60, the cache is flushed every 60 seconds.
Example callPlanAndDataCacheMaxAge = 300
Syntax callPlanAndDataCacheValidityTime = seconds
Description The maximum age of the data before it is refreshed from the database.
Type Integer
Default 3600000
Notes Applies to control plans matched on originator or destination addresses only.
Example callPlanAndDataCacheValidityTime = 300
ContinueAsConnect
Syntax ContinueAsConnect = true|false
Description If this is a TCAP-CONTINUE, then replace the TCAP-CONTINUE with a TCAP-CONNECT and send it to a switch.
Type Boolean
Optionality
Allowed true, false
Default false
Notes
Example ContinueAsConnect = false
ConvergedScenario
Syntax ConvergedScenario = true|false
Description This parameter is set to true in convergent charging deployments. When it is set to true, it disables the functionality that is not required in converged billing scenarios. For example, database subscriber lookup is not performed as converged deployments do not have subscribers in the database.
Type Boolean
Optionality
Allowed true, false
Default false
Notes
Example ConvergedScenario = false
enableProfile6
Syntax enableProfile6 = true|false
Description Enable application profile block 6 for use with alternate subscriber data.
Type Boolean
Allowed true, false
Default false
Notes Warnings will be output in the log file when voucher recharge calls are processed if this is false.
Example enableProfile6 = true
getCallPlanNumberFromProfile
Syntax getCallPlanNameFromProfile = true|false
Description Controls whether call plan name should be fetched from the subscriber's profile.
Type Boolean
Allowed
  • true - from subscriber's profile
  • false - use normal control plan selection rules.
Default false
Notes
Example getCallPlanNameFromProfile = true
Syntax GlobalDefaultForAcctRefCallPlanName = "name"
Description This specifies the global default control plan for the account reference.
Type string
Optionality
Allowed:
Default "E2 Global Prompt For Account Reference"
Notes
Example GlobalDefaultForAcctRefCallPlanName = "E2 Global Prompt For Account Reference"
GlobalDefaultSMOrigCallPlanName
Syntax GlobalDefaultForSMOrigCallPlanName = "name"
Description This specifies the global default call plan for SM originating.
Type string
Optionality
Allowed
Default ""
Notes
Example
GlobalDefaultSMTermCallPlanName
Syntax GlobalDefaultForSMTermCallPlanName = "name"
Description This specifies the global default control plan for SM terminating.
Type string
Optionality
Allowed
Default ""
Notes
Example
Syntax globalCapabilityFlushPeriod = seconds
Description Sets the flush period in seconds. This overrides the default (1 hour) CCS capability cache flush period.
Type Integer
Allowed
Default 3600 (1 hour)
Notes Enables updates to the default control plan to be recognized by the service loader more quickly.
Example globalCapabilityFlushPeriod = 10
Syntax
Description
Type
Optionality
Allowed
Default
Example
Syntax
Description
Type
Optionality
Allowed
Default
Example
Syntax
Description Whether to interpret the subscriber number as a CLI.
Type
Optionality
Allowed true, false
Default false
Example
Syntax MobileTerminatingHomeCli = "cli"
Description Defines the CLI to use to replace the normalized calling number in the ACS Chassis when the service being used is 'Roaming'.
Type
Optionality
Allowed
Default ""
Notes
Example MobileTerminatingHomeCli = ""
NoCallPlanError
Syntax NoCallPlanError = "sev"
Description This is the severity of the syslog message when no control plan is found for the CCS service.
Type Integer
Optionality
Allowed notice, warning, error, critical
Default warning
Notes
Example NoCallPlanError = "warning"
Syntax PreCallAnnouncementId = id
Description This is the ID of the pre call announcement as used by the UATB node.
Type
Optionality
Allowed
A valid pre call announcement ID. This can be any entry ID from the announcements table.
Note: This ID cannot be viewed from any announcement configuration screen.
Default 0
Notes A zero setting indicates there is no pre call announcement.
Example PreCallAnnouncementId = 0
PreCallLowBalance
Syntax PreCallLowBalance = true|false
Description Determines whether or not to enable pre-call low balance warnings.
Type Boolean
Optionality
Allowed false, true
Default false
Notes This parameter is used by the UATB node in conjunction with the WithheldDuration parameter.
Example PreCallLowBalance = false
Syntax productCapabilitiesCacheFlushTime = seconds
Type Integer
Default 120
Notes Applies to product capabilities matched on capability and product type. To reload the cache more frequently with the latest versions of control plans, set productCapabilitiesCacheFlushTime to a low value. For example, when set to 60, the cache is flushed every 60 seconds. The value should be less than or equal to that of callPlanAndDataCacheFlushTime so that a valid capability is used when retrieving control plan data.
Example productCapabilitiesCacheFlushTime = 60
Syntax productCapabilitiesCacheMaxAge = seconds
Description The time after which an unused or unchanged product capability is dropped from cache.
Type Integer
Default 3600
Notes
Applies to product capabilities matched on capability and product type. To remove stale entries from cache more frequently, set productCapabilitiesCacheMaxAge to a low value. For example, when set to 900, ccsSvcLibrary removes entries that have been unused/unchanged for 900 seconds.
The value should be greater than that of productCapabilitiesCacheValidityTime and less than or equal to that of callPlanAndDataCacheMaxAge.
Example productCapabilitiesCacheMaxAge = 900
Syntax productCapabilitiesCacheValidityTime = seconds
Type Integer
Default 600
Notes
Applies to product capabilities matched on capability and product type. To refresh entries in the cache more frequently, set productCapabilitiesCacheValidityTime to a low value. For example, when set to 300, entries are refreshed after 300 seconds by the next flushing cycle.
The value should be greater than that of productCapabilitiesCacheFlushTime and less than or equal to that of callPlanAndDataCacheValidityTime.
Example productCapabilitiesCacheValidityTime = 300
Syntax productTypeForExternalSub = "pt_name"
Description Specifies the name of the product type for external subscribers that do not exist on the Convergent Charging ControllerConvergent Charging Controller platform. Convergent Charging Controller uses the product type for external subscribers when sending requests to update external subscriber balances to Oracle Communications Billing and Revenue Management (BRM) Elastic Charging Engine (ECE) through a Diameter interface.
Type String
Allowed
Default "EXTERNAL"
Notes
Example productTypeForExternalSub = "EXTERNAL"
Syntax promptForAccountOnOriginatingSK = true|false
Description
When set to true, the service library will prompt the caller to enter the subscriber number and PIN when:
  • The ccsSvcLibrary cannot identify the subscriber who is calling
  • The call was not triggered with an INAP service key associated with the service handle of "CCS_ROAM" or "SM_MT" in the SLEE.cfg file.
Type Boolean
Optionality
Allowed true, false
Default true
Notes
Example promptForAccountOnOriginatingSK = true
Syntax promptForAccountOnTerminatingSK = true|false
Description
When set to true, the service library will prompt the caller to enter the subscriber number and PIN when the:
  • ccsSvcLibrary cannot identify the subscriber who is calling
  • Call was triggered with an INAP service key associated with the service handle of "CCS_ROAM" or "SM_MT" in the SLEE.cfg file.
Type Boolean
Optionality
Allowed true, false
Default true
Notes
Example promptForAccountOnTerminatingSK = true
RetrieveLCRNumbers
Syntax RetrieveLCRNumbers = true|false
Description Determines whether the UATB node can retrieve LCR numbers.
Type Boolean
Optionality
Allowed true, false
Default true
Notes
Example RetrieveLCRNumbers = true
SingleReservation
Syntax SingleReservation = true|false
Description Switches single reservation on or off.
Type Boolean
Optionality
Allowed true, false
Default false
Notes
Example SingleReservation = false
SubcriberDomainType
Syntax SubscriberDomainType = id
Description The ID of the domain type through which subscribers are stored (normally the VWS).
Type Integer
Allowed A valid domain type ID, as defined in a CCS domain type on the Domain tab in the Service Management screen.
Default 1 (for VWS)
Notes
For more information about domains, see Voucher and Wallet Server and CCS.
For more information about what ID corresponds to the domain type which is used for an application, see the application's technical guide.
Example SubscriberDomainType = 1
Syntax UnknownDataReleaseCause = int
Description Defines the release cause to send back to the switch in the TCAP-CONNECT when the service cannot be loaded.
Type Integer
Optionality
Allowed
Default 31
Notes
Example UnknownDataReleaseCause = 31
VoucherDomainType
Syntax VoucherDomainType = id
Description The ID of the domain type through which vouchers are redeemed (normally the VWS).
Type Integer
Default 1 (for VWS)
Notes
2 sets voucher redemptions to process through the Voucher Manager server. When the CCS Balance Top Up Suite is installed, the VoucherDomainType is automatically set to "2".
You can manually change the value back to '1' to use the VWS even when the CCS Balance Top Up Suite SLC package is installed.
For more information about domains, see Overriding default domain types.
Example VoucherDomainType = 1
WithheldDuration
Syntax WithheldDuration = seconds
Description The length of time withheld for low balance warnings.
Type Integer
Optionality
Allowed
Default 0
Notes This parameter is used by the UATB node.
Example WithheldDuration = 0
libccsClientPlugins
libccsClientPlugins is a library which provides CCS plug-ins to the beClient. The plug-ins include:
  • VoucherRechargePlugin
  • VoucherTypeRechargePlugin
  • MergeWalletsPlugin
Startup
libccsClientPlugins is used if the library and one or more of its functions is included in a plugins section in eserv.config. For an example of a process which uses this library, see Table 3-*.
Configuration
libccsClientPlugins is configured in the section specified in the config parameter in the plug-ins entry which calls the related function and the libccsClientPlugins library.
For examples, see Table 3-*.
Name of the configuration section required for the Voucher Recharge plug-in.
sendBadPin
Syntax sendBadPin = true|false
Description When true, increments the Bad PIN for a failed voucher recharge.
Type
Optionality
Allowed true, false
Default false
Notes Used for invalid voucher number or voucher PIN only - does not apply to failed wallet recharges.
Example sendBadPin = false
singleBonusEdrs
Syntax singleBonusEdrs = true|false
Description Whether to produce a single bonus EDR.
Type Boolean
Allowed
Default false
Notes
Example singleBonusEdrs = false
Syntax: srActivatesPreuseAccount = true|false
Description Weather or not SR (Voucher Recharge) activate wallets with a Pre-use state.
Type Boolean
Allowed
true: Voucher recharges can activate pre-use wallets.
false: Voucher recharges cannot be used with pre-use wallets.
Default false
Notes The application of this parameter is also affected by rechargePreUseAccounts (on page 2).
Example srActivatesPreuseAccount = false
Syntax srasActivatesPreuseAccount = true|false
Description When true, SRAS activates the wallet.
Type Boolean
Optionality
Allowed true, false
Default false
Notes
Example srasActivatesPreuseAccount = false
This configuration is required for the Voucher plug-in. It defines the type of message that triggers the plug-in.
libccsCommon
libccsCommon provides common functions to various CCS processes.
Startup
libccsCommon is used by a number of CCS processes. No startup configuration is required for this library to be used.
Configuration
The libccsCommon library supports parameters from the common parameter group in the eserv.config file on all machines. For more information, see eserv.config Configuration.
