2 Base Feature Nodes
Available Feature Nodes
Base Feature Nodes List
This table lists the available Base feature nodes.
| Node name | Node description |
| Attempt Termination |
The Attempt Termination node will attempt to terminate the call to a specified Termination Number but, if for some reason cannot terminate it to that number correctly, it takes a branch determined by the status of the call so that (for example) call diversion can be performed by the next node. Shortcut keys: Alt+A |
| Control Plan Notes |
Allows you to place notes on the CPE canvas. The note box can be expanded or contracted by clicking and dragging the resizing handle in the bottom right hand corner of the feature node. Note: There is no feature node icon for this, just a yellow box for entering notes. |
| Disconnect Call |
Plays tone or message to the caller and disconnects the call. Shortcut keys: Alt+R |
| Dynamic Switch | Takes a specific exit which can be specified in the node edit dialog and which may be overridden by dialing a management control plan. |
| End |
Signifies the end of the control plan branch. Shortcut keys: Alt+E |
| Junction |
Use the Junction feature node to collect all incoming feature node connections into a single exit point. The usefulness is being able to position this feature node in a strategic position to move connecting lines clear of other feature nodes, thus making it easier to see what the control plan is doing. |
| Proportional Distribution |
Routes set proportions of the calls down each exit. Shortcut keys: Alt+D |
| Sleep | The Sleep node allows time for background tasks to complete before proceeding to the next step in the control plan. |
| Start |
The start node must be the first node in the control plan. Shortcut keys: Alt+S |
| Terminate Unchanged | Tells the switch to continue, which normally results in the call being terminated to the number originally dialed. |
| Unconditional Termination |
Directs the call to be terminated to a specified termination number. Shortcut keys: Alt+U |
