B Supported Protocol Fields for mipt
This appendix lists the fields supported by the mipt utility for each of the protocols that you can use:
Supported Fields for the Diameter Protocol
Following is a list of the Diameter protocol fields that the mipt utility supports:
  • 3gpp_abort_cause
  • 3gpp_acceptable_service_info
  • 3gpp_access_network_charging_address
  • 3gpp_access_network_charging_identifier
  • 3gpp_access_network_charging_identifier_gx
  • 3gpp_access_network_charging_identifier_value
  • 3gpp_access_network_information
  • 3gpp_account_expiration
  • 3gpp_accumulated_cost
  • 3gpp_adaptations
  • 3gpp_additional_content_information
  • 3gpp_additional_mbms_trace_info
  • 3gpp_additional_type_information
  • 3gpp_addressee_type
  • 3gpp_address_data
  • 3gpp_address_domain
  • 3gpp_address_type
  • 3gpp_af_application_identifier
  • 3gpp_af_charging_identifier
  • 3gpp_af_correlation_information
  • 3gpp_af_signalling_protocol
  • 3gpp_allocation_retention_priority
  • 3gpp_alternate_charged_party_address
  • 3gpp_alternative_apn
  • 3gpp_an_gw_address
  • 3gpp_aoc_cost_information
  • 3gpp_aoc_format
  • 3gpp_aoc_information
  • 3gpp_aoc_request_type
  • 3gpp_aoc_service
  • 3gpp_aoc_service_obligatory_type
  • 3gpp_aoc_service_type
  • 3gpp_aoc_subscription_information
  • 3gpp_apn_aggregated_max_bitrate_dl
  • 3gpp_apn_aggregated_max_bitrate_ul
  • 3gpp_application_provided_called_party_address
  • 3gpp_application_server
  • 3gpp_application_server_information
  • 3gpp_application_service_provider_identity
  • 3gpp_applic_id
  • 3gpp_associated_party_address
  • 3gpp_associated_uri
  • 3gpp_authorised_qos
  • 3gpp_aux_applic_info
  • 3gpp_base_time_interval
  • 3gpp_bearer_control_mode
  • 3gpp_bearer_identifier
  • 3gpp_bearer_operation
  • 3gpp_bearer_service
  • 3gpp_bearer_usage
  • 3gpp_billing_information
  • 3gpp_called_asserted_identity
  • 3gpp_called_party_address
  • 3gpp_calling_party_address
  • 3gpp_carrier_select_routing_information
  • 3gpp_cause_code
  • 3gpp_cg_address
  • 3gpp_change_condition
  • 3gpp_change_time
  • 3gpp_charged_party
  • 3gpp_charging_characteristics_selection_mode
  • 3gpp_charging_correlation_indicator
  • 3gpp_charging_id
  • 3gpp_charging_rule_base_name
  • 3gpp_charging_rule_definition
  • 3gpp_charging_rule_install
  • 3gpp_charging_rule_name
  • 3gpp_charging_rule_remove
  • 3gpp_charging_rule_report
  • 3gpp_class_identifier
  • 3gpp_client_address
  • 3gpp_cn_ip_multicast_distribution
  • 3gpp_coa_information
  • 3gpp_coa_ip_address
  • 3gpp_codec_data
  • 3gpp_content_class
  • 3gpp_content_disposition
  • 3gpp_content_length
  • 3gpp_content_size
  • 3gpp_content_type
  • 3gpp_csg_access_mode
  • 3gpp_csg_information_reporting
  • 3gpp_csg_membership_indication
  • 3gpp_cug_information
  • 3gpp_current_tariff
  • 3gpp_data_coding_scheme
  • 3gpp_dcd_information
  • 3gpp_default_eps_bearer_qos
  • 3gpp_deferred_location_event_type
  • 3gpp_delivery_report
  • 3gpp_delivery_report_requested
  • 3gpp_diagnostics
  • 3gpp_domain_name
  • 3gpp_drm_content
  • 3gpp_dynamic_address_flag
  • 3gpp_dynamic_address_flag_extension
  • 3gpp_early_media_description
  • 3gpp_envelope
  • 3gpp_envelope_end_time
  • 3gpp_envelope_reporting
  • 3gpp_envelope_start_time
  • 3gpp_event
  • 3gpp_event_charging_timestamps
  • 3gpp_event_report_indication
  • 3gpp_event_trigger
  • 3gpp_event_type
  • 3gpp_experimental_result_code
  • 3gpp_expires
  • 3gpp_file_repair_supported
  • 3gpp_flows
  • 3gpp_flow_description
  • 3gpp_flow_direction
  • 3gpp_flow_information
  • 3gpp_flow_label
  • 3gpp_flow_number
  • 3gpp_flow_status
  • 3gpp_flow_usage
  • 3gpp_ggsn_address
  • 3gpp_guaranteed_bitrate_dl
  • 3gpp_guaranteed_bitrate_ul
  • 3gpp_imsi
  • 3gpp_imsi_unauthenticated_flag
  • 3gpp_ims_application_reference_identifier
  • 3gpp_ims_charging_identifier
  • 3gpp_ims_communication_service_identifier
  • 3gpp_ims_information
  • 3gpp_im_information
  • 3gpp_incoming_trunk_group_id
  • 3gpp_incremental_cost
  • 3gpp_initial_ims_charging_identifier
  • 3gpp_initial_recipient_address
  • 3gpp_interface_id
  • 3gpp_interface_port
  • 3gpp_interface_text
  • 3gpp_interface_type
  • 3gpp_inter_operator_identifier
  • 3gpp_ip_can_type
  • 3gpp_ip_realm_default_indication
  • 3gpp_lcs_client_dialed_by_ms
  • 3gpp_lcs_client_external_id
  • 3gpp_lcs_client_id
  • 3gpp_lcs_client_name
  • 3gpp_lcs_client_type
  • 3gpp_lcs_data_coding_scheme
  • 3gpp_lcs_format_indicator
  • 3gpp_lcs_information
  • 3gpp_lcs_name_string
  • 3gpp_lcs_requestor_id
  • 3gpp_lcs_requestor_id_string
  • 3gpp_local_gw_inserted_indication
  • 3gpp_local_sequence_number
  • 3gpp_location_estimate
  • 3gpp_location_estimate_type
  • 3gpp_location_type
  • 3gpp_low_balance_indication
  • 3gpp_low_priority_indicator
  • 3gpp_maximum_bandwidth
  • 3gpp_max_bandwidth_ul
  • 3gpp_max_requested_bandwidth_dl
  • 3gpp_max_supported_bandwidth_dl
  • 3gpp_max_supported_bandwidth_ul
  • 3gpp_mbms_2g_3g_indicator
  • 3gpp_mbms_access_indicator
  • 3gpp_mbms_bmsc_ssm_ipv6_address
  • 3gpp_mbms_bmsc_ssm_ip_address
  • 3gpp_mbms_bmsc_ssm_udp_port
  • 3gpp_mbms_counting_information
  • 3gpp_mbms_flow_identifier
  • 3gpp_mbms_ggsn_address
  • 3gpp_mbms_ggsn_ipv6_address
  • 3gpp_mbms_gw_address
  • 3gpp_mbms_gw_ssm_ipv6_address
  • 3gpp_mbms_gw_ssm_ip_address
  • 3gpp_mbms_gw_udp_port
  • 3gpp_mbms_gw_udp_port_indicator
  • 3gpp_mbms_hc_indicator
  • 3gpp_mbms_information
  • 3gpp_mbms_service_area
  • 3gpp_mbms_service_type
  • 3gpp_mbms_session_duration
  • 3gpp_mbms_session_identity
  • 3gpp_mbms_session_repetition_number
  • 3gpp_mbms_startstop_indication
  • 3gpp_mbms_time_to_data_transfer
  • 3gpp_mbms_user_data_mode_indication
  • 3gpp_mbms_user_service_type
  • 3gpp_media_component_description
  • 3gpp_media_component_number
  • 3gpp_media_initiator_flag
  • 3gpp_media_initiator_party
  • 3gpp_media_sub_component
  • 3gpp_media_type
  • 3gpp_message_body
  • 3gpp_message_class
  • 3gpp_message_id
  • 3gpp_message_size
  • 3gpp_message_type
  • 3gpp_metering_method
  • 3gpp_min_requested_bandwidth_dl
  • 3gpp_min_requested_bandwidth_ul
  • 3gpp_mm10_recipient_address
  • 3gpp_mmbox_storage_requested
  • 3gpp_mms_information
  • 3gpp_mmtel_information
  • 3gpp_mm_content_type
  • 3gpp_monitoring_key
  • 3gpp_mps_identifier
  • 3gpp_msisdn
  • 3gpp_network_request_support
  • 3gpp_next_tariff
  • 3gpp_node_functionality
  • 3gpp_node_id
  • 3gpp_number_of_diversions
  • 3gpp_number_of_messages_sent
  • 3gpp_number_of_participants
  • 3gpp_number_of_received_talk_bursts
  • 3gpp_number_of_talk_bursts
  • 3gpp_number_portability_routing_information
  • 3gpp_offline
  • 3gpp_offline_charging
  • 3gpp_online
  • 3gpp_online_charging_flag
  • 3gpp_originating_interface
  • 3gpp_originating_ioi
  • 3gpp_originator
  • 3gpp_originator_address
  • 3gpp_originator_received_address
  • 3gpp_originator_sccp_address
  • 3gpp_outgoing_session_id
  • 3gpp_outgoing_trunk_group_id
  • 3gpp_packet_filter_content
  • 3gpp_packet_filter_identifier
  • 3gpp_packet_filter_information
  • 3gpp_packet_filter_operation
  • 3gpp_packet_filter_usage
  • 3gpp_participants_involved
  • 3gpp_participant_access_priority
  • 3gpp_participant_action_type
  • 3gpp_participant_group
  • 3gpp_pcc_rule_status
  • 3gpp_pdg_address
  • 3gpp_pdg_charging_id
  • 3gpp_pdn_connection_charging_id
  • 3gpp_pdn_connection_id
  • 3gpp_pdp_address
  • 3gpp_pdp_address_prefix_length
  • 3gpp_pdp_context_type
  • 3gpp_poc_change_condition
  • 3gpp_poc_change_time
  • 3gpp_poc_controlling_address
  • 3gpp_poc_event_type
  • 3gpp_poc_group_name
  • 3gpp_poc_information
  • 3gpp_poc_server_role
  • 3gpp_poc_session_id
  • 3gpp_poc_session_initiation_type
  • 3gpp_poc_session_type
  • 3gpp_poc_user_role
  • 3gpp_poc_user_role_ids
  • 3gpp_poc_user_role_info_units
  • 3gpp_positioning_data
  • 3gpp_precedence
  • 3gpp_preemption_vulnerability
  • 3gpp_preferred_aoc_currency
  • 3gpp_pre_emption_capability
  • 3gpp_priority
  • 3gpp_priority_level
  • 3gpp_ps_append_free_format_data
  • 3gpp_ps_free_format_data
  • 3gpp_ps_furnish_charging_information
  • 3gpp_ps_information
  • 3gpp_qos_class_identifier
  • 3gpp_qos_information
  • 3gpp_qos_negotiation
  • 3gpp_qos_rule_base_name
  • 3gpp_qos_rule_definition
  • 3gpp_qos_rule_install
  • 3gpp_qos_rule_name
  • 3gpp_qos_rule_remove
  • 3gpp_qos_rule_report
  • 3gpp_qos_upgrade
  • 3gpp_quota_consumption_time
  • 3gpp_quota_holding_time
  • 3gpp_rai
  • 3gpp_rate_element
  • 3gpp_rat_type
  • 3gpp_read_reply
  • 3gpp_read_reply_report_requested
  • 3gpp_real_time_tariff_information
  • 3gpp_reason_code
  • 3gpp_received_talk_burst_time
  • 3gpp_received_talk_burst_volume
  • 3gpp_recipient_address
  • 3gpp_recipient_info
  • 3gpp_recipient_received_address
  • 3gpp_recipient_sccp_address
  • 3gpp_refund_information
  • 3gpp_remaining_balance
  • 3gpp_reply_applic_id
  • 3gpp_reply_path_requested
  • 3gpp_reporting_level
  • 3gpp_reporting_reason
  • 3gpp_requested_party_address
  • 3gpp_required_mbms_bearer_capabilities
  • 3gpp_resource_allocation_notification
  • 3gpp_result_recipient_address
  • 3gpp_revalidation_time
  • 3gpp_role_of_node
  • 3gpp_routeing_address
  • 3gpp_routeing_address_resolution
  • 3gpp_routing_filter
  • 3gpp_routing_ip_address
  • 3gpp_routing_rule_definition
  • 3gpp_routing_rule_identifier
  • 3gpp_routing_rule_install
  • 3gpp_routing_rule_remove
  • 3gpp_rr_bandwidth
  • 3gpp_rs_bandwidth
  • 3gpp_rule_activation_time
  • 3gpp_rule_deactivation_time
  • 3gpp_rule_failure_code
  • 3gpp_scale_factor
  • 3gpp_sdp_answer_timestamp
  • 3gpp_sdp_media_component
  • 3gpp_sdp_media_description
  • 3gpp_sdp_media_name
  • 3gpp_sdp_offer_timestamp
  • 3gpp_sdp_session_description
  • 3gpp_sdp_timestamps
  • 3gpp_sdp_type
  • 3gpp_security_parameter_index
  • 3gpp_sender_address
  • 3gpp_sender_visibility
  • 3gpp_sequence_number
  • 3gpp_served_party_ip_address
  • 3gpp_served_user_identity
  • 3gpp_service_data_container
  • 3gpp_service_generic_information
  • 3gpp_service_id
  • 3gpp_service_information
  • 3gpp_service_info_status
  • 3gpp_service_key
  • 3gpp_service_mode
  • 3gpp_service_specific_data
  • 3gpp_service_specific_info
  • 3gpp_service_specific_type
  • 3gpp_service_type
  • 3gpp_service_urn
  • 3gpp_serving_node_type
  • 3gpp_session_linking_indicator
  • 3gpp_session_release_cause
  • 3gpp_sgsn_address
  • 3gpp_sgsn_mcc_mnc
  • 3gpp_sgw_address
  • 3gpp_sgw_change
  • 3gpp_sip_forking_indication
  • 3gpp_sip_method
  • 3gpp_sip_request_timestamp
  • 3gpp_sip_request_timestamp_fraction
  • 3gpp_sip_response_timestamp
  • 3gpp_sip_response_timestamp_fraction
  • 3gpp_smsc_address
  • 3gpp_sms_information
  • 3gpp_sms_node
  • 3gpp_sm_discharge_time
  • 3gpp_sm_message_type
  • 3gpp_sm_protocol_id
  • 3gpp_sm_service_type
  • 3gpp_sm_status
  • 3gpp_sm_user_data_header
  • 3gpp_specific_action
  • 3gpp_sponsored_connectivity_data
  • 3gpp_sponsor_identity
  • 3gpp_start_time
  • 3gpp_status
  • 3gpp_status_code
  • 3gpp_status_text
  • 3gpp_stop_time
  • 3gpp_submission_time
  • 3gpp_subscriber_role
  • 3gpp_supplementary_service
  • 3gpp_talk_burst_exchange
  • 3gpp_talk_burst_time
  • 3gpp_talk_burst_volume
  • 3gpp_tariff_information
  • 3gpp_tariff_xml
  • 3gpp_terminating_ioi
  • 3gpp_tft_filter
  • 3gpp_tft_packet_filter_information
  • 3gpp_time_first_usage
  • 3gpp_time_last_usage
  • 3gpp_time_quota_mechanism
  • 3gpp_time_quota_threshold
  • 3gpp_time_quota_type
  • 3gpp_time_stamps
  • 3gpp_time_usage
  • 3gpp_tmgi
  • 3gpp_token_text
  • 3gpp_tos_traffic_class
  • 3gpp_traffic_data_volumes
  • 3gpp_transcoder_inserted_indication
  • 3gpp_trigger
  • 3gpp_trigger_event
  • 3gpp_trigger_type
  • 3gpp_trunk_group_id
  • 3gpp_tunnel_header_filter
  • 3gpp_tunnel_header_length
  • 3gpp_tunnel_information
  • 3gpp_type_number
  • 3gpp_unit_cost
  • 3gpp_unit_quota_threshold
  • 3gpp_usage_monitoring_information
  • 3gpp_usage_monitoring_level
  • 3gpp_usage_monitoring_report
  • 3gpp_usage_monitoring_support
  • 3gpp_user_csg_information
  • 3gpp_user_location_information
  • 3gpp_user_participating_type
  • 3gpp_user_session_id
  • 3gpp_vasp_id
  • 3gpp_vas_id
  • 3gpp_volume_quota_threshold
  • 3gpp_wag_address
  • 3gpp_wag_plmn_id
  • 3gpp_wlan_information
  • 3gpp_wlan_radio_container
  • 3gpp_wlan_session_id
  • 3gpp_wlan_technology
  • 3gpp_wlan_ue_local_ipaddress
  • abort_session_answer
  • abort_session_request
  • ACA
  • ACCOUNTING
  • accounting_answer
  • accounting_realtime_required
  • accounting_record_number
  • accounting_record_type
  • accounting_request
  • accounting_session_id
  • accounting_sub_session_id
  • acct_application_id
  • acct_interim_interval
  • acct_multi_session_id
  • ACR
  • ALLOW_SERVICE
  • ALL_APPLICATION
  • ALL_HOST
  • ALL_REALM
  • ALL_SESSION
  • ALL_USER
  • application_id
  • art_AUTHORIZE_AUTHENTICATE
  • art_AUTHORIZE_ONLY
  • ASA
  • ASR
  • AUTHENTICATE_ONLY
  • authorization_lifetime
  • auth_application_id
  • auth_grace_period
  • auth_request_type
  • auth_session_state
  • balanceExpiry
  • balanceInfo
  • balanceLimitType
  • balanceMaxCredit
  • balanceType
  • balanceUnit
  • balanceUserValue
  • balanceValue
  • BUSY
  • capabilities_exchange_answer
  • capabilities_exchange_request
  • CCA
  • CCR
  • cc_correlation_id
  • cc_input_octets
  • cc_money
  • cc_output_octets
  • cc_request_number
  • cc_request_type
  • cc_service_specific_units
  • cc_session_failover
  • cc_sub_session_id
  • cc_time
  • cc_total_octets
  • cc_unit_type
  • CEA
  • CER
  • charge
  • chargeBalanceType
  • chargeBalanceUnit
  • chargeBalanceValue
  • chargeInfo
  • chargingStartTimestamp
  • CHECK_BALANCE
  • check_balance_result
  • class
  • command_flags
  • CONTINUE
  • cost_information
  • cost_unit
  • CREDIT_AUTHORIZATION
  • credit_control
  • credit_control_answer
  • credit_control_failure_handling
  • credit_control_request
  • currency_code
  • DELIVER_AND_GRANT
  • destination_host
  • destination_realm
  • device_watchdog_answer
  • device_watchdog_request
  • DIRECT_DEBITING
  • direct_debiting_failure_handling
  • disconnect_cause
  • disconnect_peer_answer
  • disconnect_peer_request
  • DONT_CACHE
  • DO_NOT_WANT_TO_TALK_TO_YOU
  • DPA
  • DPR
  • DWA
  • DWR
  • ELECTION_LOST
  • end_to_end_identifier
  • END_USER_IMSI
  • END_USER_NAI
  • END_USER_PRIVATE
  • END_USER_SIP_URI
  • ENOUGH_CREDIT
  • error_message
  • error_reporting_host
  • esg_address
  • esg_diamident
  • esg_diamuri
  • esg_enumerated
  • esg_grouped
  • esg_grouped_1
  • esg_grouped_2
  • esg_grouped_3
  • esg_grouped_4
  • esg_grouped_5
  • esg_integer32
  • esg_integer32_1
  • esg_integer32_2
  • esg_integer32_3
  • esg_integer64
  • esg_ipfiltrrule
  • esg_octetstring
  • esg_time
  • esg_unsigned32
  • esg_unsigned64
  • esg_utf8string
  • esg_utf8string_1
  • esg_utf8string_2
  • esg_utf8string_3
  • EVENT_RECORD
  • EVENT_REQUEST
  • event_timestamp
  • experimental_result
  • experimental_result_code
  • exponent
  • failed_avp
  • FAILOVER_NOT_SUPPORTED
  • FAILOVER_SUPPORTED
  • final_unit_action
  • final_unit_indication
  • firmware_revision
  • granted_service_unit
  • GRANT_AND_LOSE
  • GRANT_AND_STORE
  • g_s_u_pool_identifier
  • g_s_u_pool_reference
  • hop_by_hop_identifier
  • host_ip_address
  • IMEISV
  • inband_security_id
  • INITIAL_REQUEST
  • INPUT_OCTETS
  • INTERIM_RECORD
  • MAC
  • message_process_answer
  • message_process_request
  • Mobile_IP
  • MONEY
  • MPA
  • MPR
  • multiple_services_credit_control
  • multiple_services_indicator
  • MULTIPLE_SERVICES_NOT_SUPPORTED
  • MULTIPLE_SERVICES_SUPPORTED
  • multi_round_time_out
  • NASREQ
  • NO_CREDIT
  • NO_INBAND_SECURITY
  • NO_STATE_MAINTAINED
  • origin_host
  • origin_realm
  • origin_state_id
  • OUTPUT_OCTETS
  • PRICE_ENQUIRY
  • product_name
  • proxy_host
  • proxy_info
  • proxy_state
  • RAA
  • RAR
  • rart_AUTHORIZE_AUTHENTICATE
  • rart_AUTHORIZE_ONLY
  • rating_group
  • REALM_AND_APPLICATION
  • REBOOTING
  • REDIRECT
  • redirect_address_type
  • redirect_host
  • redirect_host_usage
  • redirect_max_cache_time
  • redirect_server
  • redirect_server_address
  • REFUND_ACCOUNT
  • REFUSE_SERVICE
  • Relay
  • requested_action
  • requested_service_unit
  • restriction_filter_rule
  • RESTRICT_ACCESS
  • result_code
  • RETRY_AND_TERMINATE
  • RE_AUTH
  • RE_AUTHORIZATION
  • re_auth_answer
  • re_auth_request
  • re_auth_request_type
  • route_record
  • sb_STR
  • service_context_id
  • service_identifier
  • service_parameter_info
  • service_parameter_type
  • service_parameter_value
  • SERVICE_SPECIFIC_UNITS
  • session_binding
  • session_id
  • session_server_failover
  • session_termination_answer
  • session_termination_request
  • session_timeout
  • STA
  • START_RECORD
  • STATE_MAINTAINED
  • STOP_RECORD
  • STR
  • subscription_id
  • subscription_id_data
  • subscription_id_type
  • supported_vendor_id
  • tariff_change_usage
  • tariff_time_change
  • TERMINATE
  • TERMINATE_OR_BUFFER
  • termination_cause
  • TERMINATION_REQUEST
  • TIME
  • TLS
  • topUpAmount
  • topUpValueDigits
  • topUpVoucherId
  • topUpVoucherNumber
  • topUpVoucherType
  • TOTAL_OCTETS
  • TRY_AGAIN
  • TRY_AGAIN_ALLOW_SERVICE
  • UNIT_AFTER_TARIFF_CHANGE
  • UNIT_BEFORE_TARIFF_CHANGE
  • UNIT_INDETERMINATE
  • unit_value
  • UPDATE_REQUEST
  • URL
  • used_service_unit
  • user_equipment_info
  • user_equipment_info_type
  • user_equipment_info_value
  • user_name
  • validity_time
  • value_digits
  • vendor_id
  • vendor_specific_application_id
  • voucherBalance
  • voucherInfo
  • voucherInfoBalanceExpiryExtension
  • voucherInfoBalanceExpiryExtensionPolicy
  • voucherInfoBalanceExpiryExtensionType
  • voucherInfoBalanceType
  • voucherInfoMissingBalancePolicy
  • voucherInfoNewBucket
  • voucherInfoReplaceBalance
  • voucherInfoValue
  • voucherInfoVoucher
  • voucherInfoWalletExpiryExtension
  • voucherInfoWalletExpiryExtensionPolicy
  • voucherInfoWalletExpiryExtensionType
  • voucherTypeName
  • walletActivationDate
  • walletExpiry
  • walletInfo
  • walletLastAccessed
  • walletMaxConcurrent
  • walletState
  • walletSysCurrency
  • walletUserCurrency
Base AVP Diameter Fields
Table B-1 lists separately the base AVP fields that the mipt utility supports for the Diameter protocol.
Table B-1 Base AVP Diameter Fields
Base AVP Diameter Field Name MIPT Field Name
Acct-Interim-Interval
acct_Interim_interval
Accounting-Realtime-Required
Acct-Multi-Session-Id
Accounting-Record-Number
Accounting-Record-Type
Accounting-Session-Id
Accounting-Sub-Session-Id
Acct-Application-Id
acct_application_id
Auth-Application-Id
auth_application_id
Auth-Request-Type
auth_request_type
Authorization-Lifetime
Auth-Grace-Period
auth_grace_period
Auth-Session-State
auth_session_state
Re-Auth-Request-Type
Class
class
Destination-Host
destination_host
Destination-Realm
destination_realm
Disconnect-Cause
disconnect_cause
Error-Message
error_message
Error-Reporting-Host
Event-Timestamp
event_timestamp
Experimental-Result
experimental_result
Experimental-Result-Code
Failed-AVP
failed_avp
Firmware-Revision
firmware_revision
Host-IP-Address
host_ip_address
Inband-Security-Id
inband_security_id
Multi-Round-Time-Out
Origin-Host
origin_host
Origin-Realm
origin_realm
Origin-State-Id
origin_state_id
Product-Name
product_name
Proxy-Host
proxy_host
Proxy-Info
proxy_info
Proxy-State
proxy_state
Redirect-Host
redirect_host
Redirect-Host-Usage
redirect_host_usage
Redirect-Max-Cache-Time
Result-Code
result_code
Route-Record
route_record
Session-Id
session_id
Session-Timeout
session_timeout
Session-Binding
session_binding
Session-Server-Failover
Supported-Vendor-Id
supported_vendor_id
Termination-Cause
termination_cause
User-Name
user_name
Vendor-Id
vendor_id
Vendor-Specific-Application-Id
CC-Correlation-Id
cc_correlation_id
CC-Input-Octets
cc_input_octets
CC-Money
cc_money
CC-Output-Octets
cc_output_octets
CC-Request-Number
cc_request_number
CC-Request-Type
cc_request_type
CC-Service-Specific-Units
CC-Session-Failover
cc_session_failover
CC-Sub-Session-Id
cc_sub_session_id
CC-Time
cc_time
CC-Total-Octets
cc_total_octets
CC-Unit-Type
cc_unit_type
Check-Balance-Result
Cost-Information
cost_information
Cost-Unit
cost_unit
Credit-Control
credit_control
Credit-Control-Failure-Handling
Currency-Code
currency_code
Direct-Debiting-Failure-Handling
Exponent
exponent
Final-Unit-Action
final_unit_action
Final-Unit-Indication
Granted-Service-Unit
G-S-U-Pool-Identifier
G-S-U-Pool-Reference
Multiple-Services-Credit-Control
Multiple-Services-Indicator
Rating-Group
rating_group
Redirect-Address-Type
Redirect-Server
redirect_server
Redirect-Server-Address
Requested-Action
requested_action
Requested-Service-Unit
Restriction-Filter-Rule
Service-Context-Id
service_context_id
Service-Identifier
service_identifier
Service-Parameter-Info
Service-Parameter-Type
Service-Parameter-Value
Subscription-Id
subscription_id
Subscription-Id-Data
Subscription-Id-Type
Tariff-Change-Usage
tariff_change_usage
Tariff-Time-Change
tariff_time_change
Unit-Value
unit_value
Used-Service-Unit
used_service_unit
User-Equipment-Info
user_equipment_info
User-Equipment-Info-Type
User-Equipment-Info-Value
Value-Digits
value_digits
Validity-Time
validity_time
Vendor-Specific Diameter Fields
Table B-2 lists the vendor-specific fields that the mipt utility supports for the Diameter protocol.
Table B-2 Vendor-Specific Diameter Fields
Vendor-Specific Diameter Field Name MIPT Field Name Vendor ID
Abort-Cause
3gpp_abort_cause
10415
Acceptable-Service-Info
10415
Access-Network-Charging-Address
10415
Access-Network-Charging-Identifier
10415
Access-Network-Charging-Identifier-Gx
10415
Access-Network-Charging-Identifier-Value
10415
Access-Network-Information
10415
Account-Expiration
10415
Accumulated-Cost
10415
Adaptations
3gpp_adaptations
10415
Additional-Content-Information
10415
Additional-MBMS-Trace-Info
10415
Additional-Type-Information
10415
Address-Data
3gpp_address_data
10415
Address-Domain
3gpp_address_domain
10415
Address-Type
3gpp_address_type
10415
Addressee-Type
3gpp_addressee_type
10415
AF-Application-Identifier
10415
AF-Charging-Identifier
10415
AF-Correlation-Information
10415
AF-Signalling-Protocol
10415
Allocation-Retention-Priority
10415
Alternate-Charged-Party-Address
10415
Alternative-APN
10415
AN-GW-Address
3gpp_an_gw_address
10415
AoC-Cost-Information
10415
AoC-Format
3gpp_aoc_format
10415
AoC-Information
10415
AoC-Request-Type
10415
AoC-Service
3gpp_aoc_service
10415
AoC-Service-Obligatory-Type
10415
AoC-Service-Type
10415
AoC-Subscription-Information
10415
APN-Aggregated-Max-Bitrate-DL
10415
APN-Aggregated-Max-Bitrate-UL
10415
Applic-Id
3gpp_applic_id
10415
Application-Provided-Called-Party-Address
10415
Application-Server
10415
Application-Server-Information
10415
Application-Service-Provider-Identity
10415
Associated-Party-Address
10415
Associated-URI
3gpp_associated_uri
10415
Authorised-QoS
3gpp_authorised_qos
10415
Aux-Applic-Info
10415
Base-Time-Interval
10415
Bearer-Control-Mode
10415
Bearer-Identifier
10415
Bearer-Operation
10415
Bearer-Service
3gpp_bearer_service
10415
Bearer-Usage
3gpp_bearer_usage
10415
Billing-Information
10415
Called-Asserted-Identity
10415
10415
Calling-Party-Address
10415
Carrier-Select-Routing-Information
10415
Cause-Code
3gpp_cause_code
10415
CG-Address
3gpp_cg_address
10415
Change-Condition
10415
Change-Time
3gpp_change_time
10415
Charged-Party
3gpp_charged_party
10415
Charging-Characteristics-Selection-Mode
10415
Charging-Correlation-Indicator
10415
Charging-Rule-Base-Name
10415
Charging-Rule-Definition
10415
Charging-Rule-Install
10415
Charging-Rule-Name
10415
Charging-Rule-Remove
10415
Charging-Rule-Report
10415
Class-Identifier
10415
Client-Address
3gpp_client_address
10415
CN-IP-Multicast-Distribution
10415
CoA-Information
10415
CoA-IP-Address
3gpp_coa_ip_address
10415
Codec-Data
3gpp_codec_data
10415
Content-Class
3gpp_content_class
10415
Content-Disposition
10415
Content-Length
3gpp_content_length
10415
Content-Size
3gpp_content_size
10415
Content-Type
3gpp_content_type
10415
CSG-Access-Mode
10415
CSG-Information-Reporting
10415
CSG-Membership-Indication
10415
CUG-Information
10415
Current-Tariff
3gpp_current_tariff
10415
Data-Coding-Scheme
10415
DCD-Information
10415
Default-EPS-Bearer-QoS
10415
Deferred-Location-Event-Type
10415
Delivery-Report
10415
Delivery-Report-Requested
10415
Diagnostics
3gpp_diagnostics
10415
Domain-Name
3gpp_domain_name
10415
DRM-Content
3gpp_drm_content
10415
Dynamic-Address-Flag
10415
Dynamic-Address-Flag-Extension
10415
Early-Media-Description
10415
Envelope
3gpp_envelope
10415
Envelope-End-Time
10415
Envelope-Reporting
10415
Envelope-Start-Time
10415
Event
3gpp_event
10415
Event-Charging-TimeStamps
10415
Event-Report-Indication
10415
Event-Trigger
3gpp_event_trigger
10415
Event-Type
3gpp_event_type
10415
10415
Expires
3gpp_expires
10415
File-Repair-Supported
10415
Flow-Description
10415
Flow-Direction
3gpp_flow_direction
10415
Flow-Information
10415
Flow-Label
3gpp_flow_label
10415
Flow-Number
3gpp_flow_number
10415
Flow-Status
3gpp_flow_status
10415
Flow-Usage
3gpp_flow_usage
10415
Flows
3gpp_flows
10415
GGSN-Address
3gpp_ggsn_address
10415
Guaranteed-Bitrate-DL
10415
Guaranteed-Bitrate-UL
10415
IM-Information
3gpp_im_information
10415
IMS-Application-Reference-Identifier
10415
IMS-Charging-Identifier
10415
IMS-Communication-Service-Identifier
10415
IMS-Information
10415
IMSI-Unauthenticated-Flag
10415
Incoming-Trunk-Group-Id
10415
Incremental-Cost
10415
Initial-IMS-Charging-Identifier
10415
Initial-Recipient-Address
10415
Inter-Operator-Identifier
10415
Interface-Id
3gpp_interface_id
10415
Interface-Port
3gpp_interface_port
10415
Interface-Text
3gpp_interface_text
10415
Interface-Type
3gpp_interface_type
10415
IP-CAN-Type
3gpp_ip_can_type
10415
IP-Realm-Default-Indication
10415
LCS-Client-Dialed-By-MS
10415
LCS-Client-External-Id
10415
LCS-Client-Id
3gpp_lcs_client_id
10415
LCS-Client-Name
10415
LCS-Client-Type
10415
LCS-Data-Coding-Scheme
10415
LCS-Format-Indicator
10415
LCS-Information
10415
LCS-Name-String
10415
LCS-Requestor-Id
10415
LCS-Requestor-Id-String
10415
Local-GW-Inserted-Indication
10415
Local-Sequence-Number
10415
Location-Estimate
10415
Location-Estimate-Type
10415
Location-Type
3gpp_location_type
10415
Low-Balance-Indication
10415
Low-Priority-Indicator
10415
Max-Bandwidth-UL
10415
Max-Requested-Bandwidth-DL
10415
Max-Supported-Bandwidth-DL
10415
Max-Supported-Bandwidth-UL
10415
Maximum-Bandwidth
10415
MBMS-2G-3G-Indicator
10415
MBMS-Access-Indicator
10415
MBMS-BMSC-SSM-IP-Address
10415
MBMS-BMSC-SSM-IPv6-Address
10415
MBMS-BMSC-SSM-UDP-Port
10415
MBMS-Counting-Information
10415
MBMS-Flow-Identifier
10415
MBMS-GGSN-Address
10415
MBMS-GGSN-IPv6-Address
10415
MBMS-GW-Address
10415
MBMS-GW-SSM-IP-Address
10415
MBMS-GW-SSM-IPv6-Address
10415
MBMS-GW-UDP-Port
10415
MBMS-GW-UDP-Port-Indicator
10415
MBMS-HC-Indicator
10415
MBMS-Information
10415
MBMS-Service-Area
10415
MBMS-Service-Type
10415
MBMS-Session-Duration
10415
MBMS-Session-Identity
10415
MBMS-Session-Repetition-Number
10415
MBMS-StartStop-Indication
10415
MBMS-Time-To-Data-Transfer
10415
MBMS-User-Data-Mode-Indication
10415
MBMS-User-Service-Type
10415
Media-Component-Description
10415
Media-Component-Number
10415
Media-Initiator-Flag
10415
Media-Initiator-Party
10415
Media-Sub-Component
10415
Media-Type
3gpp_media_type
10415
Message-Body
3gpp_message_body
10415
Message-Class
3gpp_message_class
10415
Message-Id
3gpp_message_id
10415
Message-Size
3gpp_message_size
10415
Message-Type
3gpp_message_type
10415
Metering-Method
10415
Min-Requested-Bandwidth-DL
10415
Min-Requested-Bandwidth-UL
10415
MM10-Recipient-Address
10415
MM-Content-Type
10415
MMBox-Storage-Requested
10415
MMS-Information
10415
MMTel-Information
10415
Monitoring-Key
3gpp_monitoring_key
10415
MPS-Identifier
3gpp_mps_identifier
10415
Network-Request-Support
10415
Next-Tariff
3gpp_next_tariff
10415
Node-Functionality
10415
Node-Id
3gpp_node_id
10415
Number-Of-Diversions
10415
Number-Of-Messages-Sent
10415
Number-Of-Participants
10415
Number-Of-Received-Talk-Bursts
10415
Number-Of-Talk-Bursts
10415
Number-Portability-Routing-Information
10415
Offline
3gpp_offline
10415
Offline-Charging
10415
Online
3gpp_online
10415
Online-Charging-Flag
10415
Originating-Interface
10415
Originating-IOI
10415
Originator
3gpp_originator
10415
Originator-Address
10415
Originator-Received-Address
10415
Originator-SCCP-Address
10415
Outgoing-Session-Id
10415
Outgoing-Trunk-Group-Id
10415
Packet-Filter-Content
10415
Packet-Filter-Identifier
10415
Packet-Filter-Information
10415
Packet-Filter-Operation
10415
Packet-Filter-Usage
10415
Participant-Access-Priority
10415
Participant-Action-Type
10415
Participant-Group
10415
Participants-Involved
10415
PCC-Rule-Status
10415
PDG-Address
3gpp_pdg_address
10415
PDG-Charging-Id
10415
PDN-Connection-Charging-Id
10415
PDN-Connection-Id
10415
PDP-Address
3gpp_pdp_address
10415
PDP-Address-Prefix-Length
10415
PDP-Context-Type
10415
PoC-Change-Condition
10415
PoC-Change-Time
10415
PoC-Controlling-Address
10415
PoC-Event-Type
3gpp_poc_event_type
10415
PoC-Group-Name
3gpp_poc_group_name
10415
PoC-Information
10415
PoC-Server-Role
10415
PoC-Session-Id
3gpp_poc_session_id
10415
PoC-Session-Initiation-Type
10415
PoC-Session-Type
10415
PoC-User-Role
3gpp_poc_user_role
10415
PoC-User-Role-IDs
10415
Poc-User-Role-Info-Units
10415
Positioning-Data
10415
Pre-Emption-Capability
10415
Precedence
3gpp_precedence
10415
Preemption-Vulnerability
10415
Preferred-AoC-Currency
10415
Priority
3gpp_priority
10415
Priority-Level
3gpp_priority_level
10415
PS-Append-Free-Format-Data
10415
PS-Free-Format-Data
10415
PS-Furnish-Charging-Information
10415
PS-Information
3gpp_ps_information
10415
QoS-Class-Identifier
10415
QoS-Information
10415
QoS-Negotiation
10415
QoS-Rule-Base-Name
10415
QoS-Rule-Definition
10415
QoS-Rule-Install
10415
QoS-Rule-Name
3gpp_qos_rule_name
10415
QoS-Rule-Remove
10415
QoS-Rule-Report
10415
QoS-Upgrade
3gpp_qos_upgrade
10415
Quota-Consumption-Time
10415
Quota-Holding-Time
10415
RAI
3gpp_rai
10415
RAT-Type
3gpp_rat_type
10415
Rate-Element
3gpp_rate_element
10415
Read-Reply
3gpp_read_reply
10415
Read-Reply-Report-Requested
10415
Real-Time-Tariff-Information
10415
Reason-Code
3gpp_reason_code
10415
Received-Talk-Burst-Time
10415
Received-Talk-Burst-Volume
10415
Recipient-Address
10415
Recipient-Info
3gpp_recipient_info
10415
Recipient-Received-Address
10415
Recipient-SCCP-Address
10415
Refund-Information
10415
Remaining-Balance
10415
Reply-Applic-Id
10415
Reply-Path-Requested
10415
Reporting-Level
10415
Reporting-Reason
10415
Requested-Party-Address
10415
Required-MBMS-Bearer-Capabilities
10415
Resource-Allocation-Notification
10415
Result-Recipient-Address
10415
Revalidation-Time
10415
Role-Of-Node
3gpp_role_of_node
10415
Routeing-Address
10415
Routeing-Address-Resolution
10415
Routing-Filter
3gpp_routing_filter
10415
Routing-IP-Address
10415
Routing-Rule-Definition
10415
Routing-Rule-Identifier
10415
Routing-Rule-Install
10415
Routing-Rule-Remove
10415
RR-Bandwidth
3gpp_rr_bandwidth
10415
RS-Bandwidth
3gpp_rs_bandwidth
10415
Rule-Activation-Time
10415
Rule-Deactivation-Time
10415
Rule-Failure-Code
10415
Scale-Factor
3gpp_scale_factor
10415
SDP-Answer-Timestamp
10415
SDP-Media-Component
10415
SDP-Media-Description
10415
SDP-Media-Name
3gpp_sdp_media_name
10415
SDP-Offer-Timestamp
10415
SDP-Session-Description
10415
SDP-TimeStamps
3gpp_sdp_timestamps
10415
SDP-Type
3gpp_sdp_type
10415
Security-Parameter-Index
10415
Sender-Address
3gpp_sender_address
10415
Sender-Visibility
10415
Sequence-Number
10415
Served-Party-IP-Address
10415
Served-User-Identity
10415
Service-Data-Container
10415
Service-Generic-Information
10415
Service-Id
3gpp_service_id
10415
Service-Info-Status
10415
Service-Information
10415
Service-Key
3gpp_service_key
10415
Service-Mode
3gpp_service_mode
10415
Service-Specific-Data
10415
Service-Specific-Info
10415
Service-Specific-Type
10415
Service-Type
3gpp_service_type
10415
Service-URN
3gpp_service_urn
10415
Serving-Node-Type
10415
Session-Linking-Indicator
10415
Session-Release-Cause
10415
SGSN-Address
3gpp_sgsn_address
10415
SGW-Address
3gpp_sgw_address
10415
SGW-Change
3gpp_sgw_change
10415
SIP-Forking-Indication
10415
SIP-Method
3gpp_sip_method
10415
SIP-Request-Timestamp
10415
SIP-Request-Timestamp-Fraction
10415
SIP-Response-Timestamp
10415
SIP-Response-Timestamp-Fraction
10415
SM-Discharge-Time
10415
SM-Message-Type
10415
SM-Protocol-Id
3gpp_sm_protocol_id
10415
SM-Service-Type
10415
SM-Status
3gpp_sm_status
10415
SM-User-Data-Header
10415
SMS-Information
10415
SMS-Node
3gpp_sms_node
10415
SMSC-Address
3gpp_smsc_address
10415
Specific-Action
10415
Sponsor-Identity
10415
Sponsored-Connectivity-Data
10415
Start-Time
3gpp_start_time
10415
Status
3gpp_status
10415
Status-Code
3gpp_status_code
10415
Status-Text
3gpp_status_text
10415
Stop-Time
3gpp_stop_time
10415
Submission-Time
10415
Subscriber-Role
10415
Supplementary-Service
10415
Talk-Burst-Exchange
10415
Talk-Burst-Time
10415
Talk-Burst-Volume
10415
Tariff-Information
10415
Tariff-XML
3gpp_tariff_xml
10415
Terminating-IOI
10415
TFT-Filter
3gpp_tft_filter
10415
TFT-Packet-Filter-Information
10415
Time-First-Usage
10415
Time-Last-Usage
10415
Time-Quota-Mechanism
10415
Time-Quota-Threshold
10415
Time-Quota-Type
10415
Time-Stamps
3gpp_time_stamps
10415
Time-Usage
3gpp_time_usage
10415
TMGI
3gpp_tmgi
10415
Token-Text
3gpp_token_text
10415
ToS-Traffic-Class
10415
Traffic-Data-Volumes
10415
Transcoder-Inserted-Indication
10415
Trigger
3gpp_trigger
10415
Trigger-Event
3gpp_trigger_event
10415
Trigger-Type
3gpp_trigger_type
10415
Trunk-Group-Id
3gpp_trunk_group_id
10415
Tunnel-Header-Filter
10415
Tunnel-Header-Length
10415
Tunnel-Information
10415
Type-Number
3gpp_type_number
10415
Unit-Cost
3gpp_unit_cost
10415
Unit-Quota-Threshold
10415
Usage-Monitoring-Information
10415
Usage-Monitoring-Level
10415
Usage-Monitoring-Report
10415
Usage-Monitoring-Support
10415
User-CSG-Information
10415
User-Participating-Type
10415
User-Session-Id
10415
VAS-Id
3gpp_vas_id
10415
VASP-Id
3gpp_vasp_id
10415
Volume-Quota-Threshold
10415
WAG-Address
3gpp_wag_address
10415
WAG-PLMN-Id
3gpp_wag_plmn_id
10415
WLAN-Information
10415
WLAN-Radio-Container
10415
WLAN-Session-Id
10415
WLAN-Technology
10415
WLAN-UE-Local-IPAddress
10415
eServGlobal-Address
esg_address
16247
eServGlobal-DiamIdent
esg_diamident
16247
eServGlobal-DiamURI
esg_diamuri
16247
eServGlobal-Enumerated
esg_enumerated
16247
eServGlobal-Grouped
esg_grouped
16247
eServGlobal-Integer32
esg_integer32
16247
eServGlobal-Integer64
esg_integer64
16247
eServGlobal-IPFiltrRule
esg_ipfiltrrule
16247
eServGlobal-OctetString
esg_octetstring
16247
eServGlobal-Time
esg_time
16247
eServGlobal-Unsigned32
esg_unsigned32
16247
eServGlobal-Unsigned64
esg_unsigned64
16247
eServGlobal-UTF8String
esg_utf8string
16247
eServGlobal-Grouped
esg_grouped_1
16247
eServGlobal-Grouped
esg_grouped_2
16247
eServGlobal-Grouped
esg_grouped_3
16247
eServGlobal-Grouped
esg_grouped_4
16247
eServGlobal-Grouped
esg_grouped_5
16247
esg_utf8string_1
16247
esg_utf8string_2
16247
esg_utf8string_3
16247
esg_integer32_1
16247
esg_integer32_2
16247
esg_integer32_3
16247
Balance-Expiry
balanceExpiry
16247
Balance-MaxCredit
balanceMaxCredit
16247
Balance-LimitType
balanceLimitType
16247
Balance-Unit
balanceUnit
16247
Balance-Value
balanceValue
16247
Balance-Value
balanceUserValue
16247
Balance-Type
balanceType
16247
Balance-Information
balanceInfo
16247
Wallet-Information
walletInfo
16247
Wallet-Expiry
walletExpiry
16247
Wallet-State
walletState
16247
Wallet-LastAccessed
walletLastAccessed
16247
Wallet-ActivationDate
16247
Wallet-MaxConcurrent
walletMaxConcurrent
16247
Wallet-SystemCurrency
walletSysCurrency
16247
walletUserCurrency
16247
Charge-Information
chargeInfo
16247
Charge
charge
16247
Charge-Balance-Type
chargeBalanceType
16247
Charge-Balance-Value
chargeBalanceValue
16247
Charge-Balance-Unit
chargeBalanceUnit
16247
Voucher-Information
voucherInfo
16247
Voucher-Info-Voucher
voucherInfoVoucher
16247
Voucher-Info-Wallet-Expiry-Extension
16247
Voucher-Info-Wallet-Expiry-Extension-Policy
16247
Voucher-Info-Wallet-Expiry-Extension-Type
16247
Voucher-Balance
voucherBalance
16247
Voucher-Info-Balance-Type
16247
Voucher-Info-Value
voucherInfoValue
16247
Voucher-Info-Balance-Expiry-Extension
16247
Voucher-Info-Voucher-Expiry-Extension-Policy
16247
Voucher-Info-Balance-Expiry-Extension-Type
16247
Voucher-Info-New-Bucket
16247
Voucher-Info-Missing-Balance-Policy
16247
Voucher-Info-Replace-Balance
16247
Voucher-Type
voucherTypeName
16247
Charging-Start-Timestamp
16247
Top-Up-Voucher-Number
topUpVoucherNumber
16247
Top-Up-Voucher-Id
topUpVoucherId
16247
Top-Up-Amount
topUpAmount
16247
Voucher-Value-Digits
topUpValueDigits
16247
Top-Up-Voucher-Type
topUpVoucherType
16247
3GPP-IMSI
3gpp_imsi
10415
3GPP-Charging-Id
3gpp_charging_id
10415
3GPP-SGSN-MCC-MNC
3gpp_sgsn_mcc_mnc
10415
MSISDN
3gpp_msisdn
10415
User-Location-Information
10415
Fail-If-Below-Threshold
awcc_fail_if_below_threshold
16247
awcc_charging_start_timestamp
16247
Product-Type
awcc_product_type
16247
Policy-Control
awcc_policy_control
16247
Calling-Party-Presentation-Indicator
awcc_calling_party_presentation_indicator
16247
Data-Source-System
awcc_data_source_system
16247
Data-Application-Id
awcc_data_application_id
16247
Data-Transaction-Id
awcc_data_transaction_id
16247
Balance-Information
awcc_balance_information
16247
Balance-Type-Id
awcc_balance_type_id
16247
Balance-Expire-Date
awcc_balance_expire_date
16247
Supported Fields for the EMI Protocol
Following is a list of the EMI protocol fields that the mipt utility supports:
  • AC
  • ACK
  • AdC
  • AMsg
  • call_input
  • call_input_ack
  • call_input_nack
  • call_input_with_supplementary_services
  • call_input_with_supplementary_services_ack
  • call_input_with_supplementary_services_nack
  • CPg
  • CSUM
  • DCs
  • DD
  • DDT
  • delete_message
  • delete_message_ack
  • delete_message_nack
  • delivery_notification
  • delivery_notification_ack
  • delivery_notification_nack
  • deliver_sm
  • deliver_sm_ack
  • deliver_sm_nack
  • DSCTS
  • Dst
  • EC
  • GAs
  • HPLMN
  • inquiry_message
  • inquiry_message_ack
  • inquiry_message_nack
  • LAdC
  • LEN
  • LNPI
  • LPID
  • LPR
  • LRAd
  • LRC
  • LRq
  • LTON
  • LUR
  • MCLs
  • MMS
  • modify_sm
  • modify_sm_ack
  • modify_sm_nack
  • ms_message_transfer
  • ms_message_transfer_ack
  • ms_message_transfer_nack
  • MT
  • mt_alert
  • mt_alert_ack
  • mt_alert_nack
  • multiple_address_call_input
  • multiple_address_call_input_ack
  • multiple_address_call_input_nack
  • MVP
  • NACK
  • NAd
  • NAdC
  • NB
  • NMsg
  • NPID
  • NPL
  • NPWD
  • NRq
  • NT
  • OAdC
  • ONPI
  • OPID
  • OT
  • OTOA
  • OTON
  • O_R
  • PID
  • PR
  • provisioning_actions
  • provisioning_actions_ack
  • provisioning_actions_nack
  • PWD
  • RAd
  • RAds
  • RC
  • RES1
  • RES2
  • RES4
  • RES5
  • response_delete_message
  • response_delete_message_ack
  • response_delete_message_nack
  • response_inquiry_message
  • response_inquiry_message_ack
  • response_inquiry_message_nack
  • RP
  • RPI
  • RPID
  • RPLy
  • Rsn
  • SCTS
  • session_management
  • session_management_ack
  • session_management_nack
  • SM
  • STYP
  • submit_sm
  • submit_sm_ack
  • submit_sm_nack
  • TMsg
  • TRN
  • UR
  • VERS
  • VP
  • XSer
Supported Fields of the M3UA Protocol
Following is a list of the M3UA protocol fields that the mipt utility supports:
  • affected_point_code
  • ASPAC
  • ASPAC_ACK
  • ASPDN
  • ASPDN_ACK
  • ASPIA
  • ASPIA_ACK
  • ASPUP
  • ASPUP_ACK
  • asp_active
  • asp_active_acknowledgement
  • asp_down
  • asp_down_acknowledgement
  • asp_identifier
  • asp_inactive
  • asp_inactive_acknowledgement
  • asp_up
  • asp_up_acknowledgement
  • BEAT
  • BEAT_ACK
  • concerned_destination
  • congestion_indications
  • control_word
  • correlation_id
  • DATA
  • DAUD
  • DAVA
  • deregistration_request
  • deregistration_response
  • deregistration_result
  • deregistration_status
  • DEREG_REQ
  • DEREG_RSP
  • destination_available
  • destination_point_code
  • destination_restricted
  • destination_state_audit
  • destination_unavailable
  • destination_user_part_unavailable
  • diagnostic_info
  • DRST
  • DUNA
  • DUPU
  • ERR
  • error
  • error_code
  • heartbeat
  • heartbeat_acknowledgement
  • heartbeat_data
  • info_string
  • local_routing_key_identifier
  • network_appearance
  • notify
  • NTFY
  • originating_point_code
  • originating_point_code_list
  • payload_data
  • protocol_data
  • registration_request
  • registration_response
  • registration_result
  • registration_status
  • REG_REQ
  • REG_RSP
  • routing_context
  • routing_key
  • SCON
  • service_indicators
  • signalling_congestion
  • status
  • traffic_mode_type
  • user_cause
Supported Fields of the RADIUS Protocol
Following is a list of the RADIUS protocol fields that the mipt utility supports:
  • 3GGP_CAMEL_CHARGING_INFO
  • 3GGP_CG_ADDRESS
  • 3GGP_GGSN_ADDRESS
  • 3GGP_IMEISV
  • 3GGP_MS_TIMEZONE
  • 3GGP_SGSN_ADDRESS
  • 3GGP_USER_LOCATION_INFO
  • 3GPP_CAMEL_CHARGING_INFO
  • 3GPP_CG_ADDRESS
  • 3GPP_CG_IPV6_ADDRESS
  • 3GPP_CHARGING_CHARACTERISTICS
  • 3GPP_CHARGING_ID
  • 3GPP_GGSN_ADDRESS
  • 3GPP_GGSN_IPV6_ADDRESS
  • 3GPP_GGSN_MCC_MNC
  • 3GPP_GPRS_QOS_PROFILE
  • 3GPP_IMEISV
  • 3GPP_IMSI
  • 3GPP_IMSI_MCC_MNC
  • 3GPP_IPV6_DNS_SERVER
  • 3GPP_MS_TIMEZONE
  • 3GPP_NSAPI
  • 3GPP_PDP_TYPE
  • 3GPP_QOS_PROFILE
  • 3GPP_RAT_TYPE
  • 3GPP_SELECTION_MODE
  • 3GPP_SESSION_STOP_INDICATOR
  • 3GPP_SGSN_ADDRESS
  • 3GPP_SGSN_IPV6_ADDRESS
  • 3GPP_SGSN_MCC_MNC
  • 3GPP_USER_LOCATION_INFO
  • access_accept
  • access_challenge
  • access_reject
  • access_request
  • accounting_container
  • accounting_response
  • accounting_stop_triggered_by_active_stop_indication
  • acct_authentic
  • acct_delay_time
  • acct_input_gigawords
  • acct_input_octets
  • acct_input_packets
  • acct_link_count
  • acct_output_gigawords
  • acct_output_octets
  • acct_output_packets
  • acct_session_id
  • acct_session_time
  • acct_status_type
  • acct_terminate_cause
  • active_time
  • airlink_priority
  • air_priority
  • allowed_differentiated_services_marking
  • allowed_differentiated_services_marking__class
  • allowed_differentiated_services_marking__max
  • allowed_differentiated_services_marking__reverse_tunnel
  • allowed_persistent_tfts
  • always_on
  • always_ON
  • arap_challenge_response
  • arap_features
  • arap_password
  • arap_security
  • arap_security_data
  • arap_zone_access
  • authenticator
  • bad_frame_count
  • bad_ppp_frame_count
  • beginning_session
  • begin_session
  • bsid
  • BSID
  • callback_id
  • callback_number
  • called_station_id
  • calling_station_id
  • chap_challenge
  • chap_password
  • CISCO_STRING
  • class
  • coa_ack
  • coa_nak
  • coa_request
  • compulsory_tunnel_indicator
  • comp_flag
  • configuration_token
  • connect_info
  • correlation_id
  • dcch_frame_size
  • DFSIZE
  • differentiated_services_class_option
  • disconnectreason
  • disconnect_ack
  • disconnect_nak
  • disconnect_request
  • dns_update_capability
  • dns_update_required
  • eap_message
  • error_cause
  • esn
  • ESN
  • event_timestamp
  • FA_CoA
  • fch_frame_size
  • FDRC
  • FFSIZE
  • filter_id
  • foreign_agent_address
  • forward_dcch_mux_option
  • forward_dcch_rc
  • forward_fch_mux_option
  • forward_fch_rc
  • forward_pdch_rc
  • forward_traffic_type
  • framed_appletalk_link
  • framed_appletalk_network
  • framed_appletalk_zone
  • framed_compression
  • framed_interface_id
  • framed_ipv6_pool
  • framed_ipv6_prefix
  • framed_ipv6_route
  • framed_ipx_network
  • framed_ip_address
  • framed_ip_netmask
  • framed_mtu
  • framed_pool
  • framed_protocol
  • framed_route
  • framed_routing
  • FRC
  • FTYPE
  • F_DCCH_MUX
  • F_FCH_MUX
  • F_PDCH_RC
  • HA_IP_addr
  • home_agent
  • identifier
  • idle_timeout
  • ike_pre_shared_secret_request
  • ip_host
  • ip_port
  • IP_QOS
  • ip_quality_of_service
  • IP_tech
  • ip_technology
  • keyid
  • login_ipv6_host
  • login_ip_host
  • login_lat_group
  • login_lat_node
  • login_lat_port
  • login_lat_service
  • login_service
  • login_tcp_port
  • message_authenticator
  • mip_lifetime
  • mip_lifetime__rrq_lifetime
  • mip_lifetime__used_lifetime
  • mn_aaa_removal_indication
  • mn_ha_shared_key
  • mn_ha_spi
  • MS_PRIMARY_DNS
  • MS_PRIMARY_NBNS
  • MS_SECONDARY_DNS
  • MS_SECONDARY_NBNS
  • nas_identifier
  • nas_ipv6_address
  • nas_ip_address
  • nas_port
  • nas_port_id
  • nas_port_type
  • number_of_active_transitions
  • number_of_hdlc_layer_octets_received
  • number_of_sdbs_originating
  • number_of_sdbs_terminating
  • NumSDB_input
  • NumSDB_output
  • num_active
  • num_bytes_received
  • password_retry
  • PCF
  • port_limit
  • PPAC
  • PPAC__AiC
  • PPAC__available_in_client
  • PPAC__selected_for_session
  • PPAC__SfS
  • PPAQ
  • PPAQ__DQ
  • PPAQ__DT
  • PPAQ__duration_quota
  • PPAQ__duration_threshold
  • PPAQ__pre_paid_server
  • PPAQ__QID
  • PPAQ__quota_identifier
  • PPAQ__update_reason
  • PPAQ__UR
  • PPAQ__volume_quota
  • PPAQ__volume_quota_overflow
  • PPAQ__volume_threshold
  • PPAQ__volume_threshold_overflow
  • PPAQ__VQ
  • PPAQ__VQO
  • PPAQ__VT
  • PPAQ__VTO
  • pre_paid_accounting_capability
  • pre_paid_accounting_quota
  • pre_paid_tariff_switching
  • pre_shared_secret
  • prompt
  • proxy_state
  • PTS
  • PTS__QID
  • PTS__quota_identifier
  • PTS__tariff_switch_interval
  • PTS__time_interval_after_tariff_switch_update
  • PTS__TITSU
  • PTS__TSI
  • PTS__volume_used_after_tariff_switch
  • PTS__volume_used_ats_overflow
  • PTS__VUATS
  • PTS__VUATSO
  • RDRC
  • reason_ind
  • release_indicator
  • remote_address_table_index
  • remote_address_table_index__qualifier
  • remote_address_table_index__table_index
  • remote_ipv4_address
  • remote_ipv4_address_octet_count
  • remote_ipv4_address_octet_count__address
  • remote_ipv4_address_octet_count__forward_octet_count
  • remote_ipv4_address_octet_count__forward_overflow
  • remote_ipv4_address_octet_count__mask
  • remote_ipv4_address_octet_count__reverse_octet_count
  • remote_ipv4_address_octet_count__reverse_overflow
  • remote_ipv4_address_octet_count__table_index
  • remote_ipv4_address__address
  • remote_ipv4_address__mask
  • remote_ipv4_address__qualifier
  • remote_ipv6_address
  • remote_ipv6_address_octet_count
  • remote_ipv6_address_octet_count__address
  • remote_ipv6_address_octet_count__forward_octet_count
  • remote_ipv6_address_octet_count__forward_overflow
  • remote_ipv6_address_octet_count__prefix_length
  • remote_ipv6_address_octet_count__reverse_octet_count
  • remote_ipv6_address_octet_count__reverse_overflow
  • remote_ipv6_address_octet_count__table_index
  • remote_ipv6_address__address
  • remote_ipv6_address__prefix_length
  • remote_ipv6_address__qualifier
  • reply_message
  • request_message_to_the_home_radius_server
  • reverse_dcch_mux_option
  • reverse_dcch_rc
  • reverse_fch_mux_option
  • reverse_fch_rc
  • reverse_tunnel_specification
  • rn_packet_data_inactivity_timer
  • RRC
  • R_DCCH_MUX
  • R_FCH_MUX
  • SDB_input_octets
  • sdb_octet_count_originating
  • sdb_octet_count_terminating
  • SDB_output_octet
  • secret
  • security_level
  • service_option
  • service_option_profile
  • service_reference_id
  • service_type
  • serving_pcf
  • session_cont
  • session_continue
  • session_termination_capability
  • session_timeout
  • sf_access_point_id
  • SF_API
  • SO
  • SR_ID
  • SR_ID__main_si_indicator
  • SR_ID__sr_id
  • state
  • STC
  • s_key
  • s_lifetime
  • termination_action
  • user_ID
  • user_name
  • user_password
  • user_zone
  • vendor_specific
Supported Vendor-Specific Fields of the RADIUS Protocol
Following is a list of vendor-specific fields of the RADIUS protocol that the mipt utility supports:
  • 3GPP_CG_ADDRESS
  • 3GPP_CHARGING_ID
  • 3GPP_GGSN_ADDRESS
  • 3GPP_GGSN_MCC_MNC
  • 3GPP_IMEISV
  • 3GPP_IMSI
  • 3GPP_IMSI_MCC_MNC
  • 3GPP_MS_TIMEZONE
  • 3GPP_NSAPI
  • 3GPP_PDP_TYPE
  • 3GPP_RAT_TYPE
  • 3GPP_SGSN_ADDRESS
  • 3GPP_SGSN_MCC_MNC
  • active_time
  • airlink_priority
  • always_on
  • beginning_session
  • bsid
  • CISCO_STRING
  • correlation_id
  • dcch_frame_size
  • disconnectreason
  • esn
  • fch_frame_size
  • forward_dcch_rc
  • forward_fch_rc
  • forward_pdch_rc
  • home_agent
  • ip_technology
  • keyid
  • mip_lifetime
  • mn_ha_shared_key
  • mn_ha_spi
  • MS_PRIMARY_DNS
  • MS_PRIMARY_NBNS
  • MS_SECONDARY_DNS
  • MS_SECONDARY_NBNS
  • PPAC__AiC
  • PPAC__SfS
  • PPAQ__DQ
  • PPAQ__DT
  • PPAQ__QID
  • PPAQ__UR
  • PPAQ__VQ
  • PPAQ__VQO
  • PPAQ__VT
  • PPAQ__VTO
  • pre_shared_secret
  • PTS__QID
  • PTS__TITSU
  • PTS__TSI
  • PTS__VUATS
  • PTS__VUATSO
  • release_indicator
  • reverse_dcch_rc
  • reverse_fch_rc
  • security_level
  • service_option
  • serving_pcf
  • session_continue
  • SR_ID__sr_id
  • s_key
  • s_lifetime
  • user_zone
Supported Fields of the SMPP Protocol
Following is a list of the SMPP protocol fields that the mipt utility supports:
  • address_range
  • addr_npi
  • addr_ton
  • alert_notification
  • application_id
  • auth_acc
  • auth_acc_resp
  • bind_receiver
  • bind_receiver_resp
  • bind_transceiver
  • bind_transceiver_resp
  • bind_transmitter
  • bind_transmitter_resp
  • cancel_sm
  • cancel_sm_resp
  • command_id
  • command_status
  • data_coding
  • data_sm
  • data_sm_resp
  • deliver_sm
  • deliver_sm_resp
  • destination_addr
  • dest_account
  • dest_addr
  • dest_address
  • dest_addr_npi
  • dest_addr_ton
  • dest_imsi
  • dest_oper_id
  • enquire_link
  • enquire_link_resp
  • error_code
  • esme_addr
  • esme_addr_npi
  • esme_addr_ton
  • esm_class
  • fee_addr
  • fee_addr_npi
  • fee_addr_ton
  • fee_fixed
  • fee_flag
  • fee_ltd_msg_num
  • fee_single
  • fee_type
  • final_date
  • generic_nack
  • interface_version
  • is_time_message
  • message_id
  • message_length
  • message_pid
  • message_state
  • mo_msc_addr
  • mo_msc_addr_npi
  • mo_msc_addr_ton
  • mo_mt_flag
  • mt_msc_addr
  • mt_msc_addr_npi
  • mt_msc_addr_ton
  • notify_mode
  • no_unsuccess
  • number_of_dests
  • operation_result
  • original_group
  • orig_account
  • orig_imsi
  • outbind
  • password
  • priority_flag
  • protocol_id
  • protocol_version
  • query_sm
  • query_sm_resp
  • registered_delivery
  • replace_if_present_flag
  • replace_sm
  • replace_sm_resp
  • schedule_delivery_time
  • schedule_mode
  • send_result
  • sequence_number
  • service_id
  • service_type
  • short_message
  • smsc_addr
  • sm_default_msg_id
  • sm_length
  • sm_result_notify
  • sm_result_notify_resp
  • source_addr
  • source_addr_npi
  • source_addr_ton
  • source_oper_id
  • status_report_request
  • submit_multi
  • submit_multi_resp
  • submit_sm
  • submit_sm_resp
  • system_id
  • system_type
  • unbind
  • unbind_resp
  • unsuccess_sme
  • validity_period
Supported SMPP TLV Fields
Following is a list of the SMPP protocol TLV fields that the mipt utility supports:
  • tlv_additional_status_info_text
  • tlv_billing_identification
  • tlv_callback_num
  • tlv_callback_num_atag
  • tlv_callback_num_pres_ind
  • tlv_delivery_failure_reason
  • tlv_destination_port
  • tlv_dest_addr_np_country
  • tlv_dest_addr_np_information
  • tlv_dest_addr_np_resolution
  • tlv_dest_addr_subunit
  • tlv_dest_bearer_type
  • tlv_dest_network_id
  • tlv_dest_network_type
  • tlv_dest_node_id
  • tlv_dest_subaddress
  • tlv_dest_telematics_id
  • tlv_display_time
  • tlv_dpf_result
  • tlv_its_reply_type
  • tlv_its_session_info
  • tlv_language_indicator
  • tlv_message_payload
  • tlv_message_state
  • tlv_more_messages_to_send
  • tlv_ms_availability_status
  • tlv_ms_msg_wait_facilities
  • tlv_ms_validity
  • tlv_network_error_code
  • tlv_number_of_messages
  • tlv_payload_type
  • tlv_privacy_indicator
  • tlv_qos_time_to_live
  • tlv_receipted_message_id
  • tlv_sar_msg_ref_num
  • tlv_sar_segment_seqnum
  • tlv_sar_total_segments
  • tlv_sc_interface_version
  • tlv_set_dpf
  • tlv_sms_signal
  • tlv_source_addr_subunit
  • tlv_source_bearer_type
  • tlv_source_network_id
  • tlv_source_network_type
  • tlv_source_node_id
  • tlv_source_port
  • tlv_source_subaddress
  • tlv_source_telematics_id
  • tlv_user_message_reference
  • tlv_user_response_code
  • tlv_ussd_service_op
Supported Fields of the SUA Protocol
Following is a list of the SUA protocol fields that the mipt utility supports:
  • ACTIVE
  • ACTIVE_ACK
  • address_indicator
  • address_range
  • asp_active
  • asp_active_ack
  • asp_capabilities
  • asp_down
  • asp_down_ack
  • asp_identifier
  • asp_inactive
  • asp_inactive_ack
  • asp_up
  • asp_up_ack
  • BEAT
  • BEAT_ACK
  • CLDR
  • CLDT
  • COAK
  • CODA
  • CODT
  • COERR
  • COIT
  • congestion_level
  • connectionless_data_response
  • connectionless_data_transfer
  • connection_acknowledge
  • connection_oriented_data_acknowledge
  • connection_oriented_data_transfer
  • connection_oriented_error
  • connection_oriented_inactivity_test
  • connection_refused
  • connection_request
  • CORE
  • COREF
  • correlation_id
  • credit
  • data
  • DAUD
  • DAVA
  • DEREG_REQ
  • DEREG_RSP
  • destination_address
  • destination_reference_number
  • diagnostic_info
  • DOWN
  • DOWN_ACK
  • drn_label
  • DRST
  • DUNA
  • DUPU
  • ERR
  • error
  • error_code
  • global_title
  • heartbeat
  • heartbeat_ack
  • heartbeat_data
  • hostname
  • importance
  • INACTIVE
  • INACTIVE_ACK
  • info_string
  • ipv4_address
  • ipv6_addresses
  • message_priority
  • notify
  • NTFY
  • point_code
  • protocol_class
  • receive_sequence_number
  • REG_REQ
  • REG_RSP
  • RELCO
  • release_complete
  • release_request
  • RELRE
  • RESCO
  • reset_confirm
  • reset_request
  • RESRE
  • routing_context
  • routing_indicator
  • routing_key
  • sccp_cause
  • SCON
  • segmentation
  • sequence_control
  • sequence_number
  • smi
  • source_address
  • source_reference_number
  • ss7_hop_count
  • status
  • SUA Field Name
  • SUA Field Name
  • subsystem_number
  • Supported fields of the SUA Protocol
  • Supported Fields of the SUA Protocol
  • tid_label
  • traffic_mode_type
  • UP
  • UP_ACK
  • user_cause
