2 Testing Calls and Messages Using the slpit Utility
This chapter describes how to use the Oracle Communications Convergent Charging Controller slpit utility.
About the slpit Utility
The slpit utility sends and receives Intelligent Network Application Part (INAP) operations and acts as an interface to the Transaction Capabilities Application Part (TCAP) protocol.
About the SS7 Protocol Suite gives a brief overview of the Signalling System 7 (SS7) protocol suite, of which INAP and TCAP are a part.
The slpit utility processes operations from an input text file rather than a real network. The input text file is called the script file and it is a file that you create. In the script file, you add commands and send and receive operations that define the call sequences that you want to test. See "Creating the slpit Script File" for more information.
The utility parses the responses from the test application and compares them to the responses that the script file expects.
There are two ways to run the slpit utility. In the first way, it replaces the m3uaIf process so that slpit communicates with slee_acs and xmsTrigger but does not send anything over the IP network. This allows you to test the higher layers of a protocol but does not include any processing that would normally happen inside m3uaIf.
The second way to run the slpit utility allows you to test certain functions that happen in the m3uaIf process. To run the utility this way, you must configure two machines. For example, if you configure machines SLC1 and SLC2, you configure SLC1 exactly like a production SLC, with slee_acs and xmsTrigger talking to m3uaIf. You configure SLC2 with only m3uaIf and the slpit utility on it. See "Running slpit in a Separate SLEE" for information about running the slpit utility in this configuration.
See "About the Convergent Charging Controller Testing Utilities" for an overview of the slpit utility.
Running the slpit Utility
The slpit utility is located in the following directory:
/IN/service_packages/TEST_TOOLS/bin
The basic command for running the slpit utility specifies a service and the name of the script input file. Additional command line options allow you to request validation of the script file, define a global variable, specify the debug output, specify output options, and perform various other actions.
Command Syntax
To run the slpit utility, use one of the following commands:
slpit -k [<option>...] [<script>] slpit -V slpit -h
The only command-line option that is typically required to run slpit is -k, which allows you to specify a service key other than the arbitrary default of 101. The following example shows the simplest command to run slpit with a script file:
slpit -k 1 <script file>
You can alternatively provide the script on the command line rather than in a file by using the following syntax where <script> is your script code:
slpit -k 1 < <script>
When you are trying to correct syntax errors in a script, the -c option is useful because it causes slpit to exit immediately after parsing, without running any calls:
slpit -c <script file>
Command-Line Options
The slpit utility takes the following command-line options:
- -a
Act as an application instead of the default interface. For more information, see "Running slpit in a Separate SLEE".
- -c
Validate the script file and exit.
- -C <CSV_file>
Writes the following values to the specified comma-separated values (CSV) file every ten seconds: the time, calls per second (CPS), and outstanding call count.
- -D <name>=<value>
Predefines a global variable with the specified name and value, where <name> is the name of the variable and <value> can be an integer or a double quoted string. Defining a global variable could be useful for making a change to the script easier in the future. For example, you could define the destination phone number and then refer to it in the call definition using the variable. Then, in the future, when you want to define a new call with a different number, you would only need to change the number in one place.
- -d <level>
Sets the level of debug output. Valid levels are 0 to 5, with 0 indicating no output and 5 indicating the maximum output.
- -g
Makes the utility more tolerant of errors, causing it to continue, if possible, rather than abort.
- -h
Prints version and build information, like the -V option, plus a summary of the usage information.
- -i <interval>
Report call summary information at the interval specified, which is a number of seconds.
- -I <name>
Adds the value of <name> as a suffix to the interface name. This option is required if you run more than one instance of slpit simultaneously in the same SLEE.
- -k <key>
Initiates calls with the specified service key value rather than 101, which is the default. The service key values are defined in the /IN/service_packages/SLEE/etc/SLEE.cfg file.
- -M <interval>
Used with the -m option to write average timing information per primitive to the CSV file at the interval specified by <interval>. If the specified interval is 0, the average timing information will be written when the script completes. This parameter works only if the slpit script expects a response because the average durations cannot be calculated otherwise.
- -m <directory>
Enables logging of timestamps per TCAP primitive for messages sent and received. The utility writes the information by call type to a comma-separated values (CSV) file in the specified directory.
- -N
Instructs slpit not to add itself as an interface to the SLEE as the SLEE has added it already.
- -n
Makes slpit ignore any received TCAP_CANCEL messages.
- -O <flags>
Enables the specified output flags. See "Output Options" for more information.
- -o <level>
Sets the level of normal output. Valid levels are 0 to 5, with 0 indicating no output and 5 indicating the maximum level. The default is 3, which produces a reasonable amount of output that is not excessive.
- -p <protocol>
Sets the preferred TCAP protocol to use when there is a conflict between the INAP/CAP and MAP tag values, as there is some overlap. Valid values are
map,is41, andinap. The default isinap. - -R
Recreates the main dialog, if it no longer exists, using the last received originating reference as a correlation ID. This is required for the CAP3 GPRS message sequence. This option does not work if the -a option is also submitted.
- -T
Enables the use of the SLEE Timer interface for delays between sending new requests, or between responses to inbound requests. Without this option, delays are handled by polling. Use of this option is not recommended. The Timer interface is not ideal for this purpose.
- -v
Enables verbose output, setting the output level to the maximum. This is equivalent to setting the -o option to 5.
- -vv or -v -v
Sets the debug output level to the maximum.
- -V
Prints version and build information and then exits.
Output Options
In addition to the overall output level that is controlled by the -o option, you can enable the following more specific output features with the -O option. Most of these options are enabled automatically at various numeric output levels.
- calldefntrace
Displays a brief summary of the call definition at each step in the call processing, including an indication of the current step. Automatically enabled at overall output level 4.
- callrate
Displays the average call rate achieved before the slpit utility terminates. It calculates the call rate by dividing the total run time by the number of calls started.
- callsummary
Prints a table summarizing the number of calls run, the number of successful calls, and the number of partially and totally failed calls. Call types that have at least one aborted call are marked with four asterisks (****); call types with failed calls are marked with a single asterisk (*).
- fullcallsummary
Prints a more detailed call summary table than the one produced by the callsummary option. The information is the same as produced by the callsummary option, but the format of the table produced by callsummary is more concise.
- triptiming
Records and displays round-trip message times for each call.
- sleecheck
Checks for changes in the count of free resource objects in the SLEE at the end of the run. If there are any changes, displays a table of the free counts. The resources can be calls, dialogs, events, and application instances. The rows for resource types that showed a positive delta are marked with a single asterisk (*); those with a negative delta, which indicates a potential memory leak, are marked with four asterisks (****). A positive delta in free resource counts indicates that running one or more calls caused resources to be freed. This is not uncommon with Advanced Control Services (ACS), which is prompted to free a SLEE management event when the first call event arrives.
- parsedebug
Enables the extremely verbose debug output for the GNU Bison parser. This option is not automatically enabled at any output level because it is useful primarily when debugging the parser.
When running the slpit utility in a separate SLEE, you must specify the -a and -k command-line options. The -k option must specify the SLEE service key that is assigned to the m3uaIf process in the /IN/service_packages/SLEE/etc/SLEE.cfg file on the machine where the m3uaIf process is running.
Exit Codes
Table 2-1 describes the exit codes that the slpit utility uses to indicate whether the run was successful. The slpit utility writes the exit code to stdout (standard output), which you can redirect to a file if you wish.
slpit -k [<option>...] [<script>] > <outfile>
Table 2-1 slpit Exit Codes
| Exit Code | Description |
0 |
Processing completed successfully |
1 |
General or usage error, which usually indicates that the command-line options were not valid. |
2 |
Script parsing error. Either slpit could not read the script file or it encountered a syntax error in the script. The utility displays diagnostics on stderr (standard error output). |
4 |
The initial connection to the SLEE failed, most likely because no SLEE is running. |
5 |
A SLEE entity that slpit required could not be contacted. This can occur when slpit is directed to use the Timer interface for running timers but the interface could not be found. |
6 |
Call creation failed. From most likely to least likely, the possible reasons include: the service key for the call being created is not configured; a resource for a SLEE dialog or for call instances has been exhausted; the SLEE for the service configured on the service key never started or has been stopped. |
10 |
At least one call instance failed. There were no errors that prevented slpit from running to completion, but at least one call instance ended in the FAILED state. |
11 |
At least one call instance aborted. There were no errors that prevented slpit from running to completion, but at least one call instance ended in the ABORTED state. |
Managing Script File Processing
The script file is an input file in which you define the call instances that you want the slpit utility to process. Call instances are defined with a set of commands and INAP operations that you specify in sets of send and receive messages. The following example shows the beginning of a call instance definition:
define call assisting_ip_pa {
SERVICE_NUMBER ?= "555801"
send {
initialdp
calledpartynumber SERVICE_NUMBER
callingpartynumber "40002000"
callingpartyscategory 10
locationnumber "40002000"
eventtypebcsm analyzedinformation
receive {
establishtemporaryconnection
address "1234"
You start call processing by including a startcall command; for example:
startcall assisting_ip_pa using once
The slpit utility can reference the call types that you define in the script file only after the script file has been parsed. Starting a call creates a call distribution but the distribution does not start creating new call instances until script processing completes.
When you run the slpit utility, it processes all distributions and calls in the script file before stopping.
In general, each call that slpit runs produces one call instance and one or two dialogs in the SLEE. The first dialog is called the main dialog. The second dialog, which will exist only for parts of some calls, is referred to as the assisting dialog.
The first message sent for a call must be an InitialDP or an appropriate TC_BEGIN message. Alternatively, the first action in a call can be a receive message with a cs1InitiateCallAttempt or a cap4InitiateCallAttempt operation.
Sending an AssistRequestInstructions message creates a second dialog on the same call instance to simulate the dialog between the intelligent peripheral and the service control point (SCP).
When slpit runs in the same SLEE as the application, the correlation ID for each dialog is not required to match. Normally, the TCAP interface would resolve the correlation ID to create the second dialog on the correct call instance.
Receiving a DisconnectForwardConnection operation is not a special case. The shutdown of the assisting dialog must be explicitly stated.
The slpit utility does little validation to ensure valid call flow. It primarily ensures that the dialog is handled correctly. For example, you do not get a warning if you forget to send an ApplyChargingReport message at the end of a monitored call, but you do get a warning if you do not explicitly terminate a dialog.
Using Distributions
The slpit utility creates a distribution with a list of call types and other parameters that control the launching of calls, which is known as the call rate, and the terminating condition of the distribution, which is generally the number of calls launched. A distribution processes the call types in a round-robin fashion until the completion condition is met. The slpit utility allows you to create the following types of distributions:
A uniform distribution has an interval and a total call count. The interval specifies the number of seconds that are to elapse before launching each call until the total number of calls is reached. The practical minimum interval is greater than a microsecond but less than a millisecond. The following
startcallline, for example, would run the call every 0.5 seconds for a total of 10 times:startcall using uniform 0.5 10
A Poisson distribution has a lambda value and a total call count. The lambda value represents the average interval between calls rather than the exact interval.
The
oncedistribution launches one of each specified call type immediately.A
oncedistribution will run through the contents of the given call type once and report a result ofSUCCESS,FAILEDorABORT.
The type of distribution is determined by the type of testing that you are performing. You specify the distribution type in the script file using the startcall command, for example:
startcall <id> using <distribution>
So for a script in which you wanted to run only one call that was started with define call 982 {, you would have to start the call with a line like the following:
startcall 982 using once
Using TCAP Primitives
All TCAP messages are primitives although some primitives are not messages. That is, some primitives are transferred only inside the local machine. A TCAP primitive contains zero or more TCAP components and can be one of the types described in Table 2-2.
Table 2-2 Types of TCAP Primitives
| Primitive Type | Description |
Unidirectional |
A single standalone instruction. It is both the start and end of a dialog. |
Begin |
Begins a dialog with other primitives coming after it. |
Continue |
A subsequent primitive sent on an existing dialog with other primitives coming after it. |
End |
The last primitive, which closes its dialog. |
Abort |
Closes the dialog, possibly due to an error. |
Cancel |
Closes the dialog when the invoke timer expires without receiving a response. This is an example of a primitive that is not a message. |
Receiving Expected Operations
Each received message corresponds to a single TCAP primitive and can contain one or more INAP operations.
The received message must contain the expected INAP operations in the order specified in the receive message section of the call definition. See "Call Definition Commands and Messages" for more information about defining calls.
Operations can come in one primitive but also can sometimes come in separate primitives, depending on the application or the service.
If the received operation types do not match the expected operation types, the slpit utility aborts the call. If the parameters received for each operation do not match the expected parameters, slpit reports the result of the call as FAILED but continues to process the remaining operations in the call definition. See "About Expressions and Comparators" for more information about parameter values.
Receive operations can time out, which prevents slpit from waiting for call completion when the call has been lost. The global default for timeout is 15 seconds.
When a timeout occurs, you can run a sequence of messages to finish the call. The default action is to abort the call, which closes any open dialogs. Aborting the call is not likely to be the most desirable behavior, however, because it does not cause a TCAP ABORT message to be sent to the application when it is running in the same SLEE. Therefore, if you expect a timeout, you should override the default with a more appropriate action.
Managing Dialogs
The send message includes options that allow you to specify a particular dialog on which to send and also to end a SLEE dialog. You can also use the abort primitive to abort a dialog and use other messages to send an error to ACS.
Specifying a Particular Dialog
To send operations specifically on either the main or assisting dialog, specify the dialog in the send primitive. For example, the following send primitive sends the operations on the assisting dialog:
send assisting {
<operations>
To send on the main dialog, specify main instead of assisting. If you do not specify a dialog, the main dialog is assumed.
Ending a SLEE Dialog
The easiest way to end a SLEE dialog is to include the end option in the last send message in the dialog, as shown in the following example:
send end {
When a call completes, whether it is successful or aborted, the slpit utility automatically closes any open dialogs. If the slpit utility runs in the same SLEE as the application, the application receives only an indication that the dialog is closed and might not handle it in the same way that it does the shutdown of a real TCAP dialog. Therefore, if a call ends with a status of Failed or Okay, and it has dialogs open, the slpit utility displays a warning message. If a call was aborted, you can assume it might have an open dialog.
The slpit utility terminates a dialog when the application sends or receives a terminating event. When the slpit utility ends a dialog, it writes a line of output that indicates the number of messages that are still in the queue. Usually, you can ignore these messages because only internal SLEE messages will be left.
Completing Calls
Each call instance finishes in one of the following states:
Aborted
Processing of the call was interrupted because something was sufficiently wrong that the call could not or should not continue. For example, an attempt was made to send an event when a dialog was no longer available, or a run-time error occurred.
Failed
The call was not completely successful but the errors were not sufficient to interrupt the call. The most likely cause is a discrepancy between the received and expected parameters for an operation. The call is failed but allowed to continue because the difference might not be significant.
Okay
The call completed without errors.
A call can finish for the following reasons:
The call process reaches the end of the call definition; the final call state will be either Failed, or Okay depending on whether there were errors in the run.
A
finish callcommand is run: The call run is immediately finished either with its current state or the override state that is specified in thefinish callcommand. -
The slpit utility encounters a serious error: The utility aborts the call immediately.
Cancelling slpit
You can run multiple calls with slpit, either by specifically defining each call in the script input or by using the uniform or Poisson distribution models.
By default, the slpit utility does not stop generating calls if any call aborts or fails. You can change this behavior by using the cancel after command. You can place this command anywhere outside a call definition in a slpit script. The command has the following forms, each of which is self explanatory:
cancel after none cancel after abort cancel after failure cancel after abort or failure
See "The Call Sequence" for more information about these commands.
You can also allow the slpit utility to continue after an abort or failure until a specified limit is reached.
You can use the following form of the cancel command to cancel a run after a specified number of failures or aborts occurs.
cancel after <number> [abort|failure]
If the number of specified aborts or failures occurs for the call, this command causes the slpit utility to stop call processing and exit. The program accepts either abort or aborts. It also accepts either failure or failures.
The following command specifies a time limit, in seconds, on the number of failed or aborted calls that the slpit utility can receive before it cancels call processing and exits:
cancel after <number> [aborts|failures]in <number> seconds
The program accepts either second or seconds.
Sending an Error
You can send an error to ACS or the application that you are testing by using either the tcapReject message or the error message. See "tcapreject" and "error" for more information.
The slpit utility processes a script file that consists of a few commands and a set of INAP send and receive operations, which define the progress of one or more call instances.
Syntax
The following syntax conventions are used to describe the commands and operations that appear in the script file.
Square brackets indicate that the enclosed items are optional. For example, the
correlationalidparameter in the following operation is optional.establishtemporaryconnection address <digits> [correlationid <digits>]
A pipe separates one or more choices. For example, in the following
finish calloperation, you can optionally specify a final state ofaborted,failed, orokay.finish call [aborted|failed|okay]
An ellipsis indicates that an item can be repeated one or more times. In the following example,
partmust occur at least once but the ellipsis indicates that it can be repeated one or more times.[variableparts <part> [<part>...]]
Angle brackets indicate a placeholder that you replace with a specific value. The placeholder typically specifies the value's atomic token or basic data type such as
<integer>,<string>, or<bcd>.
The slpit utility supports the following three styles of comments, which can appear anywhere in the script file:
Two forward slashes indicate C++ style comments that can extend to the end of a line. The following line illustrates a full line comment:
//This is a full line comment calledpartynumber "049393520" // This is an in-line comment
A pound character indicates shell-style comments that can extend to the end of a line.
Text enclosed by asterisks and then forward slashes indicate C-style comments that can extend multiple lines between the beginning and ending delimiters.
Commands
You can include the following commands in the script file in addition to the messages and operations that define a call:
- include <file>
Includes the named file in the slpit script, enabling you to include a call sequence that is defined in a separate file. The value of
<file> includes the directory path to the file's location. - define call <ID> { <call sequence> }
Defines a set of call sequence messages and operations. The
<ID> is an identifier you assign to the call and use to reference the call in other commands. See "The Call Sequence" for more information about<call sequence>. - startcall <ID> [ <ID>...] using <distribution> [<seed>] maxconcurrent <limit>] \ [after <wait_seconds>]
Defines the call types, the number of calls, and the call rate at which to start generating calls. You can start multiple call types and call rates by including multiple
startcallcommands in the script file.For all distribution types, you can specify a random seed, which is a number that will be used to initialize the call rate. If not specified, the current clock time is used.
For all distribution types, you can also specify a maximum concurrent number of calls to hold open. This overrides any calls-per-second (CPS) rate and causes a lower CPS rate to be used. This is useful for specifying the maximum load that can be supported for the test system.
For all distribution types, you can specify that the block of calls are to be run after a wait time of a specified number of seconds. This is useful for specifying a stepped call rate, in which you define one
startcallfor each step, with each one timed to begin after the preceding one has finished.After the keyword
using, you can use the following forms of the command:uniform <delay> <count> once poisson <delay> <count> poisson <delay> <ramp> <count>
The
<delay>,<count>, and<ramp>values must be defined as a number with a decimal point.The
<delay>parameter is the average interval between calls. You can alternatively express this value as calls per second and you can do so by using thecpskeyword. For example10.0 cpsis equivalent to a<delay>value of0.1.The first form of the
poissoncommand generates calls at random with the average interval between calls specified by the<delay>parameter.The second form of the
poissoncommand ramps up from zero calls per second to 1/<delay>calls per second, taking about<ramp>seconds to reach the maximum call rate. It then flattens off at that rate.
The basic format of a call definition looks like this:
define call <ID> {
<call sequence>
Each call type is identified by an ID that can be either a number or a name that starts with a letter and contains only letters, digits, and underscores.
The <call sequence> consists of a set of call definition messages that describe the progress of a call.
The Call Sequence
The call sequence consists of one or more of the following call definition messages:
send [end] [assisting|main] { <message details> ... }
receive [assisting|main] { <reponse details> ... }
allow receive abort assisting
[send] abort [assisting|main|open]
wait <delay>
<ID> = <expression>
<ID> ?= <expression>
waitforcalls <delay> seconds|calls
default timeout none
default timeout <expression> [ { <new call sequence> } ]
close [assisting|main|open]
cancel after [none|abort|fail] [or [abort|fail] ]
send
The slpit send message sends an event containing one or more operations, as determined by the message details, which you can modify through the use of various flags.
The end flag causes the messages to be sent as the final event on the dialog. You can use the assisting or main flag to override the dialog on which the message is sent. See "Managing Script File Processing" for more information.
receive
The slpit utility expects to receive an event containing one or more operations as determined by the response details in a receive message, including CS1InitiateAttempt and CAP4InitiateCallAttempt operations. You can use either the assisting or the main flag to override the dialog on which the message is expected to arrive.
allow receive abort
An allow receive abort message indicates that the slpit utility should expect an abort to arrive from TCAP on the specified dialog at some time in the future. This is different from receive in that the slpit utility does not stop and wait for the abort, but continues processing.
abort
An abort message causes the slpit utility to send a TCAP abort on the specified dialog or dialogs (the default is the main dialog). Specifying open dialogs causes the slpit utility to abort any dialogs still open for the call.
wait
The wait message causes the slpit utility to pause its processing of the call for a specified delay or until it is interrupted by a received event. You can specify the delay as an integer value representing microseconds or as a floating point value representing seconds. In other words, if the value contains a decimal point, the unit value is seconds. If it does not contain a decimal point, the unit value is microseconds. The following example illustrates the format of the message:
wait <delay>
<ID> = <expression>
The slpit utility uses the <ID> = <expression> definition to evaluate an expression and assign its value to a named variable. You can always assign an expression to ID using <ID> = <expression> but <ID> ?= <expression> only assigns an expression to ID if ID has not been already defined in the script.
<ID> = <expression> <ID> ?= <expression>
waitforcalls
The waitforcallsmessage causes the slpit utility to pause its processing for a specified number of seconds or until the specified number of new calls started by TCAP_BEGIN requests have finished. You specify the number of seconds to wait or the number of calls to process. The following example illustrates the format of the message:
wait <delay> seconds|calls
finish call
The finish call message finishes the call. You can specify a final state of aborted,failed, or okay to override the established state. For example, finish call okay causes a failed call to be recorded as successful.
default timeout
The default timeout message specifies the default timeout that the slpit utility uses when waiting for a message. If you specify the {<new call sequence>} section, slpit will run the new call sequence when the timeout occurs rather than the lines that follow in the main call definition. If you specify none, it turns off the timeout altogether.
default timeout <expression> [ {<new call sequence>} ]
close
The close message closes the SLEE dialog by way of a DIALOG CLOSED event on the given dialog. If you use the open option, the slpit utility closes all open dialogs.
cancel
The cancel after message forces the slpit utility to exit any call immediately when the call fails or is aborted. This feature is most useful when running multiple calls in one slpit run, as when using the uniform and Poisson call distribution models.
This message has the following four formats:
cancel after noneThis format prevents the slpit utility from exiting the run on the abort or failure of the call.
cancel after abortThis format causes the slpit utility to stop processing or generating calls and exit if the call aborts. You can substitute the word
abortsforabort. -
cancel after failThis format causes the slpit utility to stop call processing and exit if the call fails. You can substitute the words
failure,failures, andfailsforfail. -
cancel after abort or failThis format causes the slpit utility to stop processing or generating calls and exit if the call aborts or fails. You can substitute words as described in the other formats of the
cancelmessage.
You can use multiple cancel messages like this in the same call definition to handle calls that might not fail before a certain command, but could fail after another command.
You can also define a global cancellation strategy outside of a call definition. See "Cancelling slpit" for more information.
An expression generates a value that you can use, for example, as the parameter value for a send operation. The simplest form of an expression is a constant value. For example, "5551234" appearing in a slpit script is usually an expression that generates a digit string. More complex expressions are supported:
Expressions that use the value of a variable by name.
Expressions that use limited integer arithmetic: subtraction, addition, and multiplication. Integer arithmetic expressions may also contain parentheses for grouping.
For example:
callConnectedElapsedTime(talktime - 20) * 10
You can also specify ranges of numbers as an expression, including the Nature of Address of the generated numbers, which defaults to 3, if not specified. The syntax looks like this:
CLI = RANGE [ (<integer: NoA>) ] "<start of range>" "<end of range>" SEQUENTIAL|RANDOM [DISTINCT|MULTIPLE]
For example,
CLI = RANGE(4) "49900010001" "49900020001" SEQUENTIAL
or
CLI = RANGE "49900010001" "49900020001" RANDOM
Use the DISTINCT or MULTIPLE option with RANGE for initialdp callingpartynumber messages only.
MULTIPLEmeans a calling party can have multiple calls in progress. -
DISTINCTmeans a calling party can have only one call in progress at a time.
See "initialdp" for more information.
You can obtain values from a text file, such as one for vouchers. For example, the following expression will take a line from vouchers.txt and use that value wherever VOUCHERNUM is used:
VOUCHERNUM=FROM_FILE "vouchers.txt"
If you want to randomly use rows from vouchers.txt, you need to randomize the file before you pass it to the slpit utility. Not having enough rows in your file to match the number of calls causes the slpit utility to produce an error and stop after the numbers run out.
You can obtain INAP numbers from a text file. For example, the APARTY expression will take a line from the APARTY_INAP.txt file and use the value wherever APARTY is used:
APARTY = FROM_INAP_FILE "APARTY_INAP.txt"
If sufficient rows are not available in your file to match the number of calls, the slpit utility produces an error and stops once the numbers have run out. For example:
(5) 111121 screening 1 presind 2 numberplan 3 innorni 0
section of the slpit:
define call deciseconds_camel {
BPARTY = FROM_INAP_FILE "BPARTY_INAP.txt"
send {
initialdp
appContext "0,4,0,0,1,0,50,1"
calledpartynumber BPARTY
callingpartynumber APARTY
locationNumber "111144"
A comparator is a pattern for checking received values such as the parameters in received operations. There are three comparators:
any -
[=] <expression> -
<comparator> -> <ID>
The any comparator matches any value.
The simplest comparator is an expression that tests for equality. You can optionally precede the expression with = to make the equality test explicit. Because the simplest expression is a constant value, comparators usually test for equality with a simple constant value. It might also be useful to compare to the value of a variable.
The last comparator generates a match or a mismatch based on the result of the comparator, which can be any other comparator. It stores the value being checked in the variable named by <ID>. This allows you to store a received parameter value for later use.
In the syntax description, <integer comparator> indicates that you can include any comparator at that point, but the comparison should be for an integer, so the expression or expressions underlying the comparison should generate integers. The same thing applies for other comparator types like <number comparator>.
<number>: [(<noa>)] <digits> [screening <integer>] [presind <integer>] [numberplan <integer>] [innorni <integer>]
For outgoing numbers, the following default values are substituted for any field not specified:
noa=3 screening=0 presind=1 numberplan=1 innorni=0
For incoming numbers, any value is allowed for fields that have not been specified except <digits>.
Call Messages
Call messages are divided into send message operations and receive message operations.
This chapter does not explain the semantics of INAP, MAP, or CAP operations, except where the mapping from the parameters in the script to those in the actual operations is not obvious. Please refer to the relevant standards documentation for the descriptions and procedures for particular operations. See the following standards documents for more information:
Intelligent Network (IN); Intelligent Network Capability Set 1 (CS1); Core Intelligent Network Application Protocol (INAP); Part 1: Protocol specification. European Telecommunication Standard, ETS 300-374-1, September 1994.
3rd Generation Partnership Project; Technical Specification Group Core Network; Customized Applications for Mobile network Enhanced Logic (CAMEL) Phase 4; CAMEL Application Part (CAP) specification (Release 5). 3GPP 29.978 5.4.0 (2003-06).
Digital cellular telecommunications system (Phase 2+); Mobile Application Part (MAP) specification (GSM 09.02 version 7.5.0 Release 1998). ETSI TS 100 974 V7.5.0 (2000-07).
In the syntax descriptions in this section, <integer expression> indicates that an expression should appear at that point and the expression should produce an integer. Likewise for the syntax <number expression>. The syntax <integer comparator> indicates that you can include any comparator at that point, but the comparison should be for an integer, so the expression or expressions underlying the comparison should generate integers. Likewise for the syntax <number comparator>. See "About Expressions and Comparators" for more information.
Send Message Operations
You can use the following operations in the send message
portion of a call definition.
activityTestResult
This operation is available for use with CAMEL Phase 1. It is the returned result for activityTest. This operation has no parameters.
activityTestResult
alertServiceCentre [<parameters>]
You can use this operation for MAP handling. It sends alerts between MSC and HLR and it has the following parameters in any order:
Table 2-3 alertServiceCenter Parameters
| Parameter | Value |
msisdn |
<number expression> |
serviceCentreAddress |
alertServiceCenterWithoutResult [<parameters>]
You can use this operation for MAP handling. It sends alerts between MSC and HLR and it has the following parameter in any order:
Table 2-4 alertServiceCenterWithoutResult Parameters
| Parameter | Value |
msisdn |
anyTimeInterrogation [<parameters>]
This operation queries for information between GSM SCF and HLR. It has the following parameters:
Table 2-5 anyTimeInterrogation Parameters
| Parameter | Value | Min. | Max |
requestedInfo |
(locationInformation | subscriberState) |
NA |
NA |
imsi |
<bcd> |
NA |
NA |
msisdn |
<bcd> |
NA |
NA |
qmScf |
<bcd> |
NA |
NA |
sccp_orig_pc |
<integer> |
0 |
65535 |
sccp_orig_ssn |
<integer> |
0 |
255 |
sccp_orig_tt |
<integer> |
0 |
255 |
sccp_orig_np |
<integer> |
NA |
NA |
sccp_orig_noa |
<integer> |
0 |
127 |
sccp_orig_rti |
<integer> |
0 |
1 |
sccp_orig_digits |
<digits> |
0 |
15 |
sccp_dest_pc |
<integer> |
0 |
65535 |
sccp_dest_ssn |
<integer> |
0 |
255 |
sccp_dest_tt |
<integer> |
0 |
255 |
sccp_dest_np |
<integer> |
0 |
15 |
sccp_dest_noa |
<integer> |
0 |
127 |
sccp_dest_rti |
<integer> |
0 |
1 |
sccp_dest_digits |
<digits> |
NA |
NA |
Table 2-6 lists the valid combinations of the fields that make up a global title:
Table 2-6 Fields that make up a global title
| Global Title Type | Fields |
1 |
noa, digits |
2 |
tt, digits |
3 |
tt, np, digits |
4 |
tt, np, noa, digits |
For global title types 3 and 4, the encoding is always binary coded decimal (BCD) that is 1 when there is an odd number of digits and 2 when there is an even number of digits.
applychargingreport
This operation provides feedback from the service switching function (SSF) to the service control function (SCF). It has the following format:
applychargingreport
thresholdtime <integer>
endofcallindicator <integer>
[freecallindicator <integer>]
The following format is available for use with INAP CAMEL extensions:
applychargingreport
receivingSide <number>
(timeNoTariffSwitch <number> |
timeSinceTariffSwitch <number> |
timeSinceTariffSwitch <number> tariffSwitchInterval <number> )
[ callActive <number> ]
[ callReleaseAtTcpExpiry <number> ]applychargingreportGprs
This operation provides a report from the GPRS SCF to the GSM SSF. It has the following format:
applyChargingReportGprs
( gprsvolumeifnotariffswitch <integer> |
gprsvolumesincelasttariffswitch <integer> [ gprstariffswitchinterval <integer> ] |
gprstimeifnotariffswitch <integer> |
gprstimesincelasttariffswitch <integer> [ gprstariffswitchinterval <integer> ] )
<qos-list>
gprsActive <integer>
[ gprsPdPid <integer> ]
[ <ChargingRollover> ]
The <qos-list> section is one or more of the following
in any order:
gprsrequestedqos <gprs-info> gprsnegotiatedqos <gprs-info> gprssubscribedqos <gprs-info>
The <gprs-info> data is the same as defined in
intialDpGprs. See "InitialDpGprs" for more information.
The <ChargingRollover> section is optional,
consisting of either:
<TransferredVolumeRollOver> | <ElapsedTimeRollOver
The <TransferredVolumeRollOver> parameter consists of
a choice of:
gprsrovolumeifnotariffswitch <integer> |
<ro-VolumeIfTariffSwitch>
Where <ro-VolumeIfTariffSwitch> consists of a sequence
of:
gprsrovolumesincelasttariffswitch <integer> (optional) gprsrovolumetariffswitchinterval <integer> (optional)
The <ElapsedTimeRollOver> consists of a choice
of:
gprsrotimeifnotariffswitch <integer> |
<ro-TimeIfTariffSwitch>
Where <ro-TimeIfTariffSwitch> consists of a sequence
of:
gprsrotimesincelasttariffswitch <integer> (optional)
gprsrotimetariffswitchinterval <integer> (optional)applyChargingReportAckGprs
assistrequestinstructions
This operation is used by the SSF to report a specific charging event to the
SCF in response to the ApplyCharging operation. It has the following
format:
assistrequestinstructions [correlationid <digits>]
The message generated by this operation causes the event that contains it to be sent automatically as the first event on a new assisting dialog.
Although you can include the correlationid parameter in the script, it is ignored and overwritten with the value from the most recently received EstablishTemporaryConnection operation.
callinformationreport
This operation sends specific call information to the SCF as requested by a
previous callinformationrequest operation. This operation has the
following format:
callinformationreport [<parameters>]
A callinformationreport operation should have one or more
of the following parameters, appearing in any order, matching the information requested
in the relevant callinformationrequest operation:
callattemptelapsedtime <integer expression> callstoptime <digits> callconnectedelapsedtime <integer expression> calledaddress <number expression> releasecause <cause expression>
The callattemptelapsedtime parameter is measured in seconds
while the callconnectedelapsedtime parameter is measured in
deciseconds. The callstoptime parameter is a string in the format:
YYMMDDHHMMSS.
cap4InitiateCallAttemptResult
This operation sends a response to a cap4InitiateCallAtempt
request and has the following format:
cap4InitiateCallAttemptResult [<parameters>]
A cap4IniateCallAttemptResult operation can have one or more
of the following parameters, appearing in any order:
offeredCamel4Functionalities <integer expression> supportedCamelPhases <integer expression> releaseCallArgExtensionAllowed
The offeredCamel4Functionalities and
supportedCamelPhases parameters are 16-bit string values.
collecteduserinformation
This operation has the following format:
collecteduserinformation digits <digits>
This is not a distinct operation. It represents the result form of the INAP
operation, promptAndCollectUserOperation. The digits
parameter corresponds to the digitsResponse tag in the result.
entityReleasedGprs
Use this operation when the GPRS session is detached or a PDP context is disconnected and the related event is not equipped for reporting. This operation has the following format:
entityReleasedGprs gprsReleaseCause <integer> [ gprsPdPid <integer> ]
entityReleasedAckGprs
This operation has no parameters. It is the returned result for
entityReleasedGprs.
error
An error operation has the following format:
error <name> [ invokeId <invoke-ID> ]
An error operation generates a U-ERROR component in the
outgoing message. The name parameter determines the error code used.
The following values are valid:
cancelled cancelfailed etcfailed impropercallerresponse missingcustomerrecord missingparameter parameteroutofrange requestedinfoerror systemfailure taskrefused unavailableresource unexpectedcomponentsequence unexpecteddatavalue unexpectedparameter unknownlegid
Some errors would typically have additional error codes, but the slpit utility supports only the ones listed here.
The <invoke-ID> value is from the last received
INVOKE component, unless you specifically define it with the invokeId
parameter.
eventreportbcsm
This operation notifies the SCF of a call-related event that was requested by the SCF in a previous RequestReportBCSMEvent operation. Examples of call-related events are busy and no answer. This operation has the following format:
eventreportbcsm [<event>...]
The event parameter has the following format:
eventtypebcsm <type> [misccallinfo <misccallinfo> | monitormode <mode>] [legid <legid> | ( <integer> )] [eventspecificinfo <info>]
The <mode> parameter has one of the following
values:
interrupted notifyAndContinue transparent
The <legid> parameter has one of the following
values:
[sendingsideid] <legtype> [receivingsideid] <legtype>
The <legtype> parameter has one of the following
values:
ltleg1 ltleg2
Event-specific information includes the following:
busycause <cause> releasecause <cause> failurecause <cause> calledpartynumber <number>
eventReportGprs
This operation notifies the GSM SCF of a GPRS session or PDP context related events:
eventReportGprs gprsEventType <number> [ gprsPdPid <integer> ]
eventReportAckGprs
eventReportSms
This operation notifies the GSM service control function (gsmSCF) of a previously requested short message related event. This message has no parameters.
informServiceCentre
This operation is required for SMS gateway procedures between MSC and HLR. This message has the following format:
informServiceCentre [<parameters>]
The parameters consist of the following values:
storedMSISDN <number expression>
initialdp
This operation is used after a trigger detection point (TDP) to issue a request for service. This message has the following format:
initialdp [<parameters>]
An initialdp message can have any of the following
parameters, specified in any order:
calledpartynumber <number expression> originalcalledpartynumber <number expression> callingpartynumber <number expression> redirectingpartynumber <number expression> locationnumber <number expression> additionalcallingpartynumber <number expression> callingpartyscategory <categoryvalue or number> callingpartyspin <digits> origredirreason <integer> redirindicator <integer> eventtypebcsm <type> appcontext <string> extension <integer> <type> <integer> <digits> <integer> extension <integer> <type> <integer> <digits> idp_sccp_orig_pc <integer> // 0 - 65535 idp_sccp_orig_ssn <integer> // 0 - 255 idp_sccp_orig_tt <integer> // 0 - 255 idp_sccp_orig_np <integer> // 0 - 15 idp_sccp_orig_noa <integer> // 0 - 127 idp_sccp_orig_rti <integer> // 0 or 1 idp_sccp_orig_digits <digits> idp_sccp_dest_pc <integer> // 0 - 65535 idp_sccp_dest_ssn <integer> // 0 - 255 idp_sccp_dest_tt <integer> // 0 - 255 idp_sccp_dest_np <integer> // 0 - 15 idp_sccp_dest_noa <integer> // 0 - 127 idp_sccp_dest_rti <integer> // 0 or 1 idp_sccp_dest_digits <digits>
Use the
messages only. See "initialdp".
The following parameter is available for UCP handling:
AspID <string>
The following parameters are available for use with INAP CAMEL extensions:
iMSI <bcd> countryCode <digits> networkCode <digits> locationAreaCode <integer> [ cellID <integer> ] [ bearerCapCodingStandard <number> bearerCapITC <number> [ bearerCapTransferMode <number> bearerCapITR <number> bearerCapUIProtol <number> ]] hlCharacteristicsId <number> calledPartyBCDNumber [ ( <integer> ) ] "number" [ numberPlan <integer> ] vlrNumber [ ( <integer> ) ] "number" [ numberPlan <integer> ] ageoflocationinfo <digits> subscriberstate <digits> locationnumberlocationinfo [ ( <integer> ) ] "number" [ numberPlan <integer> ] extBearerService <hex digits> extTeleService <hex digits> callreference <string> [ callForwardingSSPending ] iMEI <bcd> [ Eutrancgimcc <digits> Eutrancgiimnc <digits> Eutrancgi <integer> ] [Taidmcc <digits> Taidmnc <digits> Taid <integer> ]
The countryCode and networkCode values can
be only three digits long.
The Eutrancgimcc, Eutrancgimnc,
Taidmcc, and Taidmnc values can be only three
digits long.
Bearer capability fields are optional and are divided in two stages as shown
above. If the second stage is not present, the following default values are assigned:
bearerCapTransferMode = BC_TM_CIRCUIT (0x0),
bearerCapITR = BC_ITR_64_KBIT_S (0x10) and
bearerCapUIProtol = BC_UIL1_NOT_PRESENT (0xff)
The following values are available for Bearer Capability fields:
Table 2-7 bearerCapcodingStandard Bearer Capability Values
| Constants | Value |
| BC_CS_ITU_T | 0x00 |
| BC_CS_ISO_IEC | 0x01 |
| BC_CS_NATIONAL | 0x02 |
| BC_CS_NETWORK | 0x03 |
Table 2-8 bearerCapITC Bearer Capability Values
| Constants | Value |
| BC_ITC_SPEECH | 0x00 |
| BC_ITC_UDI | 0x08 |
| BC_ITC_RDI | 0x09 |
| BC_ITC_3_1_KHZ_AUDIO | 0x10 |
| BC_ITC_UDI_TA | 0x11 |
| BC_ITC_7_KHZ_AUDIO | 0x11 |
| BC_ITC_VIDEO | 0x18 |
Table 2-9 bearerCapTransferMode Bearer Capability Values
| Constants | Value |
| BC_TM_CIRCUIT | 0x0 |
| BC_TM_PACKET | 0x2 |
Table 2-10 bearerCapITR Bearer Capability Values
| Constants | Value |
| BC_UIL1_ITU_V110_I460_X30 | 0x01 |
| BC_UIL1_G711_U_LAW | 0x02 |
| BC_UIL1_G711_A_LAW | 0x03 |
| BC_UIL1_G721_32_KBIT_S | 0x04 |
| BC_UIL1_H221_H242 | 0x05 |
| BC_UIL1_H223_H245 | 0x06 |
| BC_UIL1_NON_ITU_SRA | 0x07 |
| BC_UIL1_ITU_V120 | 0x08 |
| BC_UIL1_X31_HDLC | 0x09 |
| BC_UIL1_NOT_PRESENT | 0xff |
Table 2-11 bearerCapUIProtol Bearer Capability Values
| Constants | Value |
InitialDpGprs
When a trigger is detected at a detection point in the general GPRS state machines, this operation requests instructions from the GSM SCF. This message has the following format:
initialDpGprs gprsEventType <integer> gprsMsisdn <number expression> gprsImsi <number expression> gprsOriginatingReferenceNumber <number expression> [ gprsEndUserAddress <PdpTypeOrganisation> <PdpTypeNumber> [ <address byte> ] ] [ gprsrequestedqos <qos-info> ] [ gprssubscribedqos <qos-info> ] [ gprsnegotiatedqos <qos-info> ] [ gprsaccesspointname <string> ] [ gprschargingid <integer> ] [ gprslocationinformation gprsmobilecountrycode <bcd> gprsmobilenetworkcode <bcd> gprsmobilelocationareacOde <bcd> gprscellidentity <integer> gprspdpinitiationtype <integer> ] [ gprsggsnaddress <integer> [ <integer> ] ] [ sgsnNumber <number expression> ]
The <qos-info> variable can have one of the following
parameter values, all of which are integers:
Table 2-12 InitialDpGprs
| Parameter | Min | Max |
gprsqosprioritylevel |
0 |
255 |
gprsqosdeloferrsdu |
0 |
7 |
gprsqosdelorder |
0 |
3 |
gprsqostrafficclass |
0 |
7 |
gprsqosmaxsdusize |
0 |
255 |
gprsqosmaxbrforuplink |
0 |
255 |
gprsqosmaxbrfordownlink |
0 |
255 |
gprsqossduerrratio |
0 |
15 |
gprsqosresidualber |
0 |
15 |
gprsqostrafhlingpri |
0 |
3 |
gprsqostransferdelay |
0 |
63 |
gprsqosguabrforuplink |
0 |
255 |
gprsqosguabrfordownlink |
0 |
255 |
InitialDpSms
After it detects a TDP-R, the SMS SSF uses this operation to request instructions from the GSM SCF to complete the short-message submission to the SMSC or the short message delivery to the served subscriber. This message has the following format:
initialDpSms [<parameters>]
An initialDpSms message can have the following parameters
in any order:
callingPartyNumber <number expression> destinationSubscriberNumber <number expression> idp_sccp_orig_pc <integer> // 0 - 65535 idp_sccp_orig_ssn <integer> // 0 - 255 idp_sccp_orig_tt <integer> // 0 - 255 idp_sccp_orig_np <integer> // 0 - 15 idp_sccp_orig_noa <integer> // 0 - 127 idp_sccp_orig_rti <integer> // 0 or 1 idp_sccp_orig_digits <digits> idp_sccp_dest_pc <integer> // 0 - 65535 idp_sccp_dest_ssn <integer> // 0 - 255 idp_sccp_dest_tt <integer> // 0 - 255 idp_sccp_dest_np <integer> // 0 - 15 idp_sccp_dest_noa <integer> // 0 - 127 idp_sccp_dest_rti <integer> // 0 or 1 idp_sccp_dest_digits <digits> vlrNumber [ ( <integer> ) ] "number" [ numberPlan <integer> ] countryCode <digits> networkCode <digits> locationAreaCode <integer> [ cellID <integer> ] mscAddr <digits> smscAddr <digits>
mergeCallSegmentResult
This message has the following format with no parameters:
moForwardSm
This service forwards mobile-originated short messages between the serving mobile switching center (MSC) or the SGSN and the SMS internetworking MSC. This message has the following format:
moForwardSm [<parameters>]
For MAP version 3, this is a mobile-originated Forward-SM message, which is
distinct from the mtForwardSm message. For MAP versions 1 and 2, this
operation is a Forward-SM and it can originate or terminate from a mobile device,
depending on the type of PDU in the SM-RP-UI.
A Forward-SM message has the following parameters in any order:
MapVersion <integer> SegmentedBegin SegmentedBody imsiOA <number expression> //optional, only valid for MAP version 3 privateExtension <comma separated object ID string> <integer ASN.1 tag> <hex value> // optional, only valid for MAP version 3 countryCode <digits> networkCode <digits> locationAreaCode <integer> cellID <integer> // optional, valid for MAP versions 2 and 3
The countryCode, networkCode,
locationAreaCode, and cellID parameters are used
to construct the global cell ID. The countryCode and
networkCode values can be only three digits long.
The SM_RP_DA field can be service center (MO) on an IMSI
(MT):
imsi <number expression> (optional for MAP v2/v3 segmented body) lmsi <number expression> (optional) ServiceCentreAddressDA <number expression>
In a MAP version 2 or 3 segmented MT message, the imsi
parameter is omitted in segments after the initial segment. If it is omitted, the MT
message is encoded with the noSM_RP_DA parameter set.
The SM_RP_OA field can be an MSISDN (MO) or a service center (MT):
msisdn <number expression> ServiceCentreAddressOA <number expression> (optional for MAP v2/v3 segmented body)
In a MAP version 2 or 3 segmented MT message, the originating service center
is omitted in segments subsequent to the initial segment. If it is omitted, the MT
message is encoded with the noSM_RP_OA parameter set.
Depending on the MAP version, the SM_RP_UI field can contain one of the following PDUs:
Table 2-13 PDUs
| PDU | MAP Version | Comment |
SMS-SUBMIT |
1, 2, and 3 |
NA |
SMS-DELIVER |
1 and 2 |
In MT-ForwardSM for version 3 |
SMS-STATUS-REPORT |
2 |
In MT-ForwardSM for version 3) |
The type of PDU is determined by the message type indicator, TP-MTI:
TP_MTI <number>
For an SMS-SUBMIT PDU, with TP-MTI=1, the following parameters are available:
TP_VPF <number>
replyPath
requestStatusReport
TP_MR <number>
TP_DA [ToN] <string> | TP_DA <number expression>
TP_DCS <number>
TP_VP { <1 or 7 octets (numbers)> }
userDataHeader { <number> <number> ... }
userDataText <string>Note:
For TP_DA, alphabetic characters (non-telephony digits) are allowed only if ToN = 5 (alphanumeric).
For an SMS-DELIVER (TP-MTI=0), the following parameters are available:
moreMessages <0-1>
replyPath
TP_OA [ToN] <string>
TP_DCS <number>
For TP_OA, alphabetic characters (non-telephony digits) are allowed only if ToN=5 (alphanumeric).
For an SMS-STATUS-REPORT (TP-MTI=2), the following parameters are available:
moreMessages <0-1>
TP_MR <number>
TP_RA [ToN] <string>
TP_DCS <number>
For TP_RA, alphabetic characters (non-telephony digits) are allowed only if ToN=5 (alphanumeric).
Table 2-14 Min and Max for Parameters
| Parameter | Value | Min | Max |
sccp_orig_pc |
<integer> |
0 |
65535 |
sccp_orig_ssn |
<integer> |
0 |
255 |
sccp_orig_tt |
<integer> |
0 |
255 |
sccp_orig_np |
<integer> |
0 |
15 |
sccp_orig_noa |
<integer> |
0 |
127 |
sccp_orig_rti |
<integer> |
0 |
1 |
sccp_orig_digits |
<digits> |
0 |
15 |
sccp_dest_pc |
<integer> |
0 |
65535 |
sccp_dest_ssn |
<integer> |
0 |
255 |
sccp_dest_tt |
<integer> |
0 |
255 |
sccp_dest_np |
<integer> |
0 |
15 |
sccp_dest_noa |
<integer> |
0 |
127 |
sccp_dest_rti |
<integer> |
0 |
1 |
sccp_dest_digits |
<digits> |
0 |
15 |
There must be exactly one each of imsi,
lmsi, ServiceCentreAddressDA, and
noSM_RP_DA. There must be exactly one of msisdn,
ServiceCentreAddressOA, noSM_RP_OA, and
imsiOA. You can use the imsiOA parameter only for
MAP3.
If the SegmentedBegin parameter is present, the only other
parameters allowed are MapVersion and IMSI. The result
is that a TCAP_BEGIN message is sent with the appropriate application context but with
no component (the User Information part of the TCAP_BEGIN message contains a MAP-OPEN
with an optional IMSI in it.) If the IMSI parameter is
present in the SegmentedBegin, the RP-DA in the ForwardSM should be a
LMSI, but this is not enforced by the slpit utility.
If the SegmentedBody parameter is present, a normal
moForwardSM operation is sent (in a Continue) but
with no application context. You must always pair SegmentedBegin and
SegmentedBody operations with appropriate MAP versions and a
receive{}message between them.
The following segmentation scenarios are valid.
IMSIandLMSIparameters in segmented message:Table 2-15 IMSI and LMSI Parameters Segmentation Scenario
Primitive MAP-OPEN ForwardSM RP-DA Segment TCAP_BEGIN
imsi
N/A
Begin
TCAP_CONTINUE
N/A
lmsi
Body #1
TCAP_CONTINUE
N/A
noSM-RP-DA
Body #2
IMSIonly in a segmented message:Table 2-16 IMSI-only Parameters Segmentation Scenario
empty
N/A
Begin
TCAP_CONTINUE
N/A
Imsi
Body #1
TCAP_CONTINUE
N/A
noSM-RP-DA
Body #2
IMSIandLMSIin a non-segmented message:Table 2-17 IMSI and LMSI Non-Segmentation Scenario
imsi
imsi
N/A
IMSIonly in a non-segmented message:Table 2-18 IMSI-only Non-Segmentation Scenario
empty
imsi
N/A
You may specify either the userDataheader or the
userDatatext or both. You must specify the header byte by byte, and
in decimal or hex (with 0x as a prefix) – for example,
userDataHeader {0x17 0x34}. The header is
automatically prefixed with a one-byte length field.
The userDatatext parameter will be added to the packet
after the userDataheader parameter in either GSM 7-bit (default) or
Unicode UCS2/UTF16 (big endian, meaning the most significant bytes in multi-byte data
types are stored first) or binary, depending on the value of the data coding scheme
TP_DCS.
The slpit utility does not support compressed user data.
You can specify TP_VF (validity period format) and TP_VP (validity period). See GSM 03.40 v7.5.0 sections 9.2.3.3 and 9.2.3.12 for encoding details. For example:
tp_vf 0
VPF of 0, or not specified, means no validity period format.
tp_vf 1
Enhanced format (new to MAP version 3) tp_vp {0x42 0x80 0x00 0x00 0x00 0x00 0x00}. Relative; 128 (0x80) seconds and single-shot=true.
tp_vf 2
Relative format tp_vf { 128 }, where 128 is decimal and means 645 minutes.
tp_vpf 3
Absolute format tp_vp { 0x40 0x50 0x32 0x61 0x10 0x20 0x00}. 2004-05-23 16:01:02 GMT.
mtForwardSM
This operation is a MAP version 3 mobile-terminated
Forward-SM and is available for use with MAP. It forwards mobile
terminated short messages between the gateway mobile switching center (MSC) and the
servicing MSC or the SGSN.
mtForwardSm [<parameters>]
An mtForwardSm operation should have the following
MapVersion <integer> // only 3 is valid SegmentedBegin SegmentedBody
The SM_RP_DA field must be an IMSI number for
MT-ForwardSM if the message is not getting segmented. If the
message is segmented, the SM_RP_DA can be a LMSI, in which case the
segmentedBegin should contain the IMSI:
imsi <number expression> // optional in the SegmentedBegin lmsi <number expression> // optional in the SegmentedBody
In a segmented MT-ForwardSM operation, the IMSI is omitted
in segments following the initial segment. If it is omitted, the operation is encoded
The SM_RP_OA field must be a service center for MT-ForwardSM:
ServiceCentreAddressOA <number expression> (optional)
In a segmented MT-ForwardSM operation, the originating
service center is omitted in segments following the initial segment. If it is omitted,
the operation is encoded with the noSM_RP_OA parameter set.
The SM_RP_UI field must contain an SMS-DELIVER or an
SMS-STATUS-REPORT for MT-ForwardSM. For more
information, see "moForwardSm".
sccp_orig_pc <integer> // 0 - 65535 sccp_orig_ssn <integer> // 0 - 255 sccp_orig_tt <integer> // 0 - 255 sccp_orig_np <integer> // 0 - 15 sccp_orig_noa <integer> // 0 - 127 sccp_orig_rti <integer> // 0 or 1 sccp_orig_digits <digits> sccp_dest_pc <integer> // 0 - 65535 sccp_dest_ssn <integer> // 0 - 255 sccp_dest_tt <integer> // 0 - 255 sccp_dest_np <integer> // 0 - 15 sccp_dest_noa <integer> // 0 - 127 sccp_dest_rti <integer> // 0 or 1 sccp_dest_digits <digits>
If SegmentedBegin is present, the only other parameters
allowed are MapVersion and IMSI. This results in a
TCAP_BEGIN being sent with the appropriate application context but
no component (the User Information part of the TC_BEGIN contains a
MAP-OPEN with an optional IMSI in it). If the IMSI is present in
ForwardSM should be a LMSI, but this is not enforced by the
slpit utility.
If SegmentedBody is present, a normal
moForwardSM is sent in a CONTINUE but with no
application context. You are responsible for always pairing
SegmentedBegin and SegmentedBody operations, with
matching MapVersions and a receive{} message between
them.
See the segmentation scenarios in the "moForwardSm" section for more information.
You may specify either the userData header or the text or
both. You must specify the header byte by byte in decimal or hex (with a 0x prefix) –
for example, userData { 0x02 0x17 0x34}. The first number in the user
data header should be the length, in bytes, of the remainder of the user data header. In
this case, 0x02 indicates that there are two more bytes to follow in
the header.
Any user data text will be copied after the user data header, with bit padding inserted to align to a septet boundary.
readyForSM
This operation is available for MAP handling. It is used between the message switching center (MSC) and the VLR and between the VLR and the HLR. If a subscriber has available memory, the MSC initiates this service and the VLR indicates this condition to the HLR. If a subscriber, whose message waiting flag is active in the VLR, has radio contact in the MSC, the VLR initiates this service.Likewise, if a subscriber has available memory, the SGSN initiates this service to indicate this to the HLR. Also, if a subscriber whose message waiting flag is active in the SGSN has radio contact in the GPRS, the SGSN initiates this service.
readyForSM [<parameters>]
A readyForSM operation should have the following
parameters, appearing in any order.
imsi <bcd> alertReason <alertReason> | <number>
The <alertReason> value can be one of the
following:
ms_Present memoryAvailable
reportSMDeliveryStatus
This operation is available for MAP handling. It is used by the message switching center (MSC) to set the message waiting data into the HLR or to inform the SLR of a successful short message (SM) transfer after polling.
reportSMDeliveryStatus [<parameters>]
A reportSMDeliveryStatus operation should have the
following parameters, appearing in any order.
msisdn <number expression> serviceCentreAddress <number expression> smDeliveryOutcome <smDeliveryOutcome> | <number>
The <smDeliveryOutcome> value can be one of the
following:
memoryCapacityExceeded absentSubscriber successfulTransfer
sendRoutingInfoForSm
This operation is for MAP handling and has the following format.
sendRoutingInfoForSm [<parameters>]
A sendRoutingInfoForSm operation should have the following
MapVersion <number> msisdn <number expression> AttemptDelivery <0-1> ServiceCentreAddress <number expression> (optional parameters) MessageTypeIndicator <number> OriginatingSmeAddr <number expression> GprsSupport <0-1> sccp_orig_pc <integer> // 0 - 65535 sccp_orig_ssn <integer> // 0 - 255 sccp_orig_tt <integer> // 0 - 255 sccp_orig_np <integer> // 0 - 15 sccp_orig_noa <integer> // 0 - 127 sccp_orig_rti <integer> // 0 or 1 sccp_orig_digits <digits> sccp_dest_pc <integer> // 0 - 65535 sccp_dest_ssn <integer> // 0 - 255 sccp_dest_tt <integer> // 0 - 255 sccp_dest_np <integer> // 0 - 15 sccp_dest_noa <integer> // 0 - 127 sccp_dest_rti <integer> // 0 or 1 sccp_dest_digits <digits>
sendRoutingInformation
This operation is available for MAP handling and has the following format:
sendRoutingInformation [<parameters>]
A sendRoutingInformation operation should have the following
interrogationType <0-1> gmscAddress <number expression> msisdn <number expression> (optional parameters) sccp_orig_pc <integer> // 0 - 65535 sccp_orig_ssn <integer> // 0 - 255 sccp_orig_tt <integer> // 0 - 255 sccp_orig_np <integer> // 0 - 15 sccp_orig_noa <integer> // 0 - 127 sccp_orig_rti <integer> // 0 or 1 sccp_orig_digits <digits> sccp_dest_pc <integer> // 0 - 65535 sccp_dest_ssn <integer> // 0 - 255 sccp_dest_tt <integer> // 0 - 255 sccp_dest_np <integer> // 0 - 15 sccp_dest_noa <integer> // 0 - 127 sccp_dest_rti <integer> // 0 or 1 sccp_dest_digits <digits>
An interrogationType value of 0 indicates a basic call; a
value of 1 indicates a forwarding call.
smsNotification
This operation is available for IS-41 support. Your application can expect to receive one of these from an MSC when a SME comes back online after sleeping through a direct delivery attempt.
smsNotification [<parameters>]
An smsNotification operation can have the following
parameters.
smsnot_MIN <bcd-string> // 10 digit number smsnot_ESN <integer> <integer> // 0..2ˆ8, 0..2ˆ24
smsNotificationResult
The response to an smsNotification operation does not
contain any parameters.
locationRequest
This operation is available for IS-41 support and has the following format:
locationRequest [<parameters>]
A locationRequest operation has the following
parameters:
locreq_BID <integer> <integer> <integer> <integer> // 0..2ˆ16, 0..2ˆ8, 0..2ˆ24, 0..2ˆ8 locreq_DIGITS <integer> <integer> <bcd-string> locreq_MSCID <integer> <integer> // 0..2ˆ16, 0..2ˆ8 locreq_SYSTEMMYTYPECODE <integer> sccp_orig_pc <integer> // 0 - 65535 sccp_orig_ssn <integer> // 0 - 255 sccp_orig_tt <integer> // 0 - 255 sccp_orig_np <integer> // 0 - 15 sccp_orig_noa <integer> // 0 - 127 sccp_orig_rti <integer> // 0 or 1 sccp_orig_digits <digits> sccp_dest_pc <integer> // 0 - 65535 sccp_dest_ssn <integer> // 0 - 255 sccp_dest_tt <integer> // 0 - 255 sccp_dest_np <integer> // 0 - 15 sccp_dest_noa <integer> // 0 - 127 sccp_dest_rti <integer> // 0 or 1 sccp_dest_digits <digits>
The locreq_BID (Billing ID) parameters are: Market
ID, Switch Number, ID Number, and
Segment Counter. The locreq_DIGITS parameters are:
Type of Digits, Nature of Number, and BCD
Digits. The locreq_MSCID parameters are: Market
ID, and Switch Number.
The locreq_SYSTEMMYTYPECODE parameter sets
VENDOR_IDENTIFIER_, which is the only content of
locreq_SYSTEMMYTYPECODE.
You can use the following values for VENDOR_IDENTIFIER:
VENDOR_IDENTIFIER_NotUsed = 0, VENDOR_IDENTIFIER_EDS = 1, VENDOR_IDENTIFIER_Astronet = 2, VENDOR_IDENTIFIER_LucentTechnologies = 3, VENDOR_IDENTIFIER_Ericsson = 4, VENDOR_IDENTIFIER_GTE = 5, VENDOR_IDENTIFIER_Motorola = 6, VENDOR_IDENTIFIER_NEC = 7, VENDOR_IDENTIFIER_NORTEL = 8, VENDOR_IDENTIFIER_NovAtel = 9, VENDOR_IDENTIFIER_Plexsys = 10, VENDOR_IDENTIFIER_DigitalEquipmentCorp = 11, VENDOR_IDENTIFIER_INET = 12, VENDOR_IDENTIFIER_Bellcore = 13, VENDOR_IDENTIFIER_AlcatelSEL = 14, VENDOR_IDENTIFIER_Tandem = 15, VENDOR_IDENTIFIER_QUALCOMM = 16, VENDOR_IDENTIFIER_Aldiscon = 17, VENDOR_IDENTIFIER_Celcore = 18, VENDOR_IDENTIFIER_TELOS = 19, VENDOR_IDENTIFIER_Stanilite = 20, VENDOR_IDENTIFIER_CoralSystems = 21, VENDOR_IDENTIFIER_SynacomTechnology = 22, VENDOR_IDENTIFIER_DSC = 23, VENDOR_IDENTIFIER_MCI = 24, VENDOR_IDENTIFIER_NewNet = 25, VENDOR_IDENTIFIER_SemaGroupTelecoms = 26, VENDOR_IDENTIFIER_LGInformationAndCommunications = 27, VENDOR_IDENTIFIER_CBIS = 28, VENDOR_IDENTIFIER_Siemens = 29
locationRequestResult
This is the response to a locationRequest operation.
locationRequestResult [<parameters>]
A locationRequestResult operation has the following
parameters:
smsreq_ESN <integer> <integer> // 0..2ˆ8, 0..2ˆ24 smsreq_MIN <integer> // must be 10 digits smsreq_MSCID <integer> <integer> // 0..2ˆ16, 0..2ˆ8
The MSCID, ESN and MIN
parameters are mandatory in the response. However, if the ESN is
unknown, it is set to "0 0"; if the MIN is unknown it is set to
"0000000000".
smsRequest
This operation is available for IS-41 support. Your applications should never receive one of these. It is included only to assist in testing scenarios in which the service control point, acting as an SMSC, receives an unexpected operation.
smsRequest [<parameters>]
A smsRequest operation can have the following
parameters.
smsreq_MIN <bcd-string> // 10 digit number smsreq_IMSI <number expression> smsreq_MDN <integer> <integer> <bcd-string> smsreq_ESN <integer> <integer> // 0..2ˆ8, 0..2ˆ24 smsreq_notificationIndicator <integer> // 0..255 smsreq_teleserviceIdentifier <integer> // 0..65535 sccp_orig_pc <integer> // 0 - 65535 sccp_orig_ssn <integer> // 0 - 255 sccp_orig_tt <integer> // 0 - 255 sccp_orig_np <integer> // 0 - 15 sccp_orig_noa <integer> // 0 - 127 sccp_orig_rti <integer> // 0 or 1 sccp_orig_digits <digits> sccp_dest_pc <integer> // 0 - 65535 sccp_dest_ssn <integer> // 0 - 255 sccp_dest_tt <integer> // 0 - 255 sccp_dest_np <integer> // 0 - 15 sccp_dest_noa <integer> // 0 - 127 sccp_dest_rti <integer> // 0 or 1 sccp_dest_digits <digits>
The smsreq_MDN parameters are: Type of
Digits.
smsRequestResult
This is the response to an smsRequest operation.
smsRequestResult [<parameters>]
An smsRequest operation can be an Ack or a
Nack. Acks contain an address, and can also return
ESN data. Nacks may specify a value for the
accessDeniedReason parameter.
smsreq_ESN <integer> <integer> // 0..2ˆ8, 0..2ˆ24 smsreq_address <integer> <integer> <bcd-string> // NoN, NPI, digits smsreq_accessDeniedReason <integer> // 0..255
smsDeliveryPointToPoint
This operation is available for IS-41 support. You can use this to deliver a short message over IS-41.
smsDeliveryPointToPoint [<parameters>]
The slpit utility supports three text-based teleservices, CDMA 4098,
CDMA 4101, and TDMA 32513 and two use cases for the text message. The first is
human-readable text with an optional header. The text is encoded as 7-bit ASCII for CDMA
or IRA for TDMA. (The actual encoding step is independent of the
smdpp_userDataEncoding parameter.) You may not specify both text
and header for a TDMA message.
The CDMA text plus header has the following format:
tag length encoding num_fields header padding-1 text padding-2
The text and header fields can have the following values:
Table 2-19 smsDeliveryPointToPoint values
| Field | Value |
tag |
0x01 |
length |
The number of octets after this one. |
encoding |
The first five bits of the
num_fields |
The number of characters (7 or 8-bit) after this octet. |
header |
Zero or more octets of GSM user-data-header. This is
taken directly from the |
padding-1 |
Padding required to make the header end on a septet boundary. This is only done if the encoding is 2 (7-bit ASCII, default) or 3 (IA5). |
text |
Encoded message text. This will always be 7-bit ASCII. |
padding-2 |
Padding required to make this whole block end on an octet boundary. |
The TDMA text has the following format:
length type padding text
The fields can have the following values:
Table 2-20 TDMA values
| Field | Value |
length |
The number of octets following this one. |
type |
The first 5 bits of
padding |
3 bits of padding, so that text starts on an octet boundary. |
text |
Text as something resembling IRA, with each character 7 bits wide but stored in an octet with the high bit off. |
With the second use case for text messaging, you cannot use the
human-readable text parameter (smdpp_userDataText); you must put the
raw bytes of the message into the header (smdpp_userDataHeader). The
header and text are packed into the message for the different use cases as follows:
The CDMA header only has the following format:
tag length encoding num_fields data padding
These fields have the following values:
Table 2-21 CDMA header values
| Field | Value |
tag |
NA |
length |
NA |
encoding |
NA |
num_fields |
NA |
data |
The octets specified in
padding |
Empty bits required to bring the block to an octet boundary. |
The TDMA header has the following format:
length type padding data
Table 2-22 TDMA header values
| Field | Value |
length |
NA |
type |
NA |
padding |
NA |
data |
The octets specified in the smdpp_userDataHeader |
Note that the translation of text from the human-readable input form to ASCII or IRA is not perfect. When in doubt, try using the header to set the raw data.
A smsDeliveryPointToPoint may have the following
parameters.
Table 2-23 smsDeliveryPointToPoint Parameters
| Parameter | Type | Value |
smdpp_teleservice |
<integer> |
4098, 4100, 32513 |
smdpp_MIN |
<bcd-string> |
10 digit |
smdpp_ESN |
<integer>< integer> |
0..28, 0..224 |
smdpp_origAddr |
<integer>< integer><bcd-string> |
NoN, NPI, digits |
smdpp_origOrigAddr |
NoN, NPI, digits |
smdpp_destAddr |
NoN, NPI, digits |
smdpp_origDestAddr |
NoN, NPI, digits |
smdpp_messageCount |
<integer> |
0..28 |
smdpp_notInd |
<integer> |
0..28 |
smdpp_chargeInd |
<integer> |
0..28 |
smdpp_userDataEncoding |
<number> |
NA |
{<number>...} |
NA |
smdpp_userDataText |
<string> |
NA |
CDMA |
{ <parameters> } |
NA |
TDMA |
{ <parameters> } |
NA |
The smdpp_teleservice parameter is mandatory, and must be
set according to IS-41-D before the TDMA or CDMA sections can be used. For more
information about these parameters, please consult TIA/EIA-41-D-1997 (IS-41), 3GPP2
C.S0015-A (CDMA) and TIA/EIA-136-710-C (TDMA).
Each teleservice may place a particular restriction on the data specified. These restrictions aren't generally enforced by the slpit utility, because you might want to send bad data. The following are common restrictions:
CDMA 4098
No userdata header present.
CDMA 4100
Encoding type is 0.
TDMA 32513
The following lists show the common encoding values:
CDMA
Table 2-24 CDMA values
Value Name Width 0
octet-unspecified
8
1
Extended protocol message
NA
2
7-bit ASCII (default)
7
3
IA5
7
4
UNICODE
16
5
Shift JIS
8 / 16
6
Korean
8 / 16
7
Latin/Hebrew
8
8
Latin
8
TDMA
Table 2-25 TDMA values
Value Name Width 1
IRA
7
2
User specific
8
3
Latin
8
5
Latin/Hebrew
8
If you are using the CDMA teleservices, you can specify the following parameters in the CDMA subsection:
Table 2-26 CDMA parameters
smdpp_messageId |
<integer><integer><boolean> |
0..24, 0..216, true/false |
smdpp_validityPeriod |
<integer> |
See 4.5.6.1 of 3GPP2 CS 15-A |
<string> |
YYMMDDhhmmss |
smdpp_deferredDeliveryTime |
<integer> |
<string> |
YYMMDDhhmmss |
smdpp_priorityInd |
<integer> |
0..3 |
smdpp_privacyInd |
<integer> |
0..3 |
smdpp_languageInd |
<integer> |
0..255 |
smdpp_alertOnDelivery |
<integer> |
0..3 |
smdpp_DAKRequested |
<boolean> |
true/false |
smdpp_MAKRequested |
<boolean> |
true/false |
smdpp_RAKRequested |
<boolean> |
true/false |
If you are using the TDMA teleservice, you can specify the following parameters in the TDMA subsection:
Table 2-27 TDMA parameters
smdpp_messageTypeInd |
<integer> |
0..23 |
smdpp_messageRef |
<integer> |
0..213 |
smdpp_privacyInd |
<integer> |
0..23 |
smdpp_urgencyInd |
<integer> |
0..22 |
<boolean> |
true/false |
<boolean> |
true/false |
smdpp_messageUpdating |
<boolean> |
true/false |
smdpp_vp_absolute |
<integer> |
0..1 |
smdpp_vp_relativeTimerValue |
<integer> |
0..255 |
smdpp_vp_absoluteSeconds |
<integer> |
0..232 |
smdpp_vp_absoluteTZOffsetDirection |
<integer> |
0..1 |
smdpp_vp_absoluteTZOffsetMinutes |
<integer> |
0..720 |
smdpp_vp_absoluteTZOffsetDSI |
<integer |
0..1 |
smsDeliveryPointToPointResult
This is the response to an smsDeliveryPointToPoint
operation.
smsDeliveryPointToPointResult [<parameters>]
An smsDeliveryPointToPoint operation may be an
Ack or a Nack. Nacks contain an
SMS_CauseCode parameter, specified as follows:
smdpp_causeCode <integer> // 0..2ˆ8
slpitLegResult
This operation is available for INAP level 2 (CS-2) handling.
slpitLegResult
specializedresourcereport
tcapreject
tcapreject
problemtype <type>
generalproblem <problem>
A tcapreject operation will have the slpit utility
send a TCAP_REJECT primitive on the main dialog. The problem type and
ID are taken from the parameters. The mandatory parameter is
problemtype which must be an integer from the following list:
Table 2-28 Integer List
| Integer | Value |
-1 |
none |
0 |
general |
1 |
invoke |
2 |
return_result |
3 |
return_error |
The generalproblem parameter is also an integer, from 0 to
255. The reject source is set to TCAP_REJECT_LOCAL.
unstructuredSS
This operation is available for MAP handling. It sends a
MAP2_ProcessUnstructuredSSRequest. The only language available is the
default GSM alphabet because that is the only language that TC_PROTOS
currently supports.
unstructuredSS [<parameters>]
An unstructuredSS operation can have the following
msisdn <number expression> msisdnReference <number expression> originatingReference <number expression> destinationReference <number expression> ussd <string> iMEI <bcd> countryCode <digits> networkCode <digits> locationAreaCode <integer> cellID <integer> sccp_orig_pc <integer> // 0 - 65535 sccp_orig_ssn <integer> // 0 - 255 sccp_orig_tt <integer> // 0 - 255 sccp_orig_np <integer> // 0 - 15 sccp_orig_noa <integer> // 0 - 127 sccp_orig_rti <integer> // 0 or 1 sccp_orig_digits <digits> sccp_dest_pc <integer> // 0 - 65535 sccp_dest_ssn <integer> // 0 - 255 sccp_dest_tt <integer> // 0 - 255 sccp_dest_np <integer> // 0 - 15 sccp_dest_noa <integer> // 0 - 127 sccp_dest_rti <integer> // 0 or 1 sccp_dest_digits <digits>
The countryCode and networkCode can be
A MapOpen is inserted into the TCAP primitive's
UserInformation area. The msidnReference is used
to populate the msisdnReference in the MapOpen. The
destinationReference populates the
destinationReference in the MapOpen. The
originatingReference is used to populate
originationReference in the MapOpen The
msisdn is used to populate the msisdn parameter in
the UnstructuredSSRequest.
[empty]
The slpit utility can also send empty TCAP primitives. You can
accomplish this by leaving the body of the send message blank as shown
in the following example:
send
Receive Message Operations
The following operations are available in the receive message portion of a call definition.
abort
The format of this operation is:
abort
Use this operation to receive aborts that you expect. The Calls Aborted count is not updated, but the Calls Succeeded count is updated. When you use this operation, the script expects an abort so the test is successful in that it received one and continues. This is especially useful when running multiple calls because a standard abort would cause slpit to stop processing.
activityTest
This operation is available for use with CAMEL Phase 1. It is used to check continued existence of a relationship between SCF and SSF. This operation has no parameters.
activityTest
This operation is available for handling MAP. It is used for time information enquiries between GSM SCF and HLR. It has the following format and parameters:
[ locationInformation
[ age <integer comparator> ]
[ geographical <number comparator> ]
[ vrl <number comparitor> ]
[ location <number comparator> ]
[ cell <number comparator> ]
You can define the parameters to the locationInformation part of this operation in any order.
applycharging
applycharging
thresholdtime <integer comparator>
[warningtime <integer comparator>]
The following format is available for handling CAMEL:
applyCharging
maxDuration <integer>
[ release <integer> tone <integer> ]
[ tariff <integer> ]applyChargingGprs
This operation is available for GPRS handling and it takes one of the following two forms:
applyChargingGprs
gprsTransferredVolume <integer>
applyChargingGprs
gprsElapsedTime <integer>
[ gprsPdPid <integer> ]callinformationrequest
This operation requests the SSF to record information about a call and use the CallInformationReport operation to report it to the SCF. This operation has the following format:
callinformationrequest <requested fields>
A callinformationrequest operation must have at least one of the following labels requesting particular information. They may appear in any order:
callattemptelapsedtime callstoptime callconnectedelapsedtime calledaddress releasecause
These are effectively flags and do not have any associated values.
This operation requests the SSF to initiate a CAP4 call attempt and returns the result in a cap4InitiateCallAttemptResult message. It has the following format:
cap4InitiateCallAttempt [<parameters>]
A cap4InitiateCallAttempt operation may have any of the following parameters, in any order:
callingpartnumber <number comparator> callreference <number comparator> callsegmentid <integer> destroutingaddr <number comparator> gsmscf <number comparator> legid <integer> suppresstcsi
collectinformation
This operation requests the SSF to perform the call processing actions that collect destination information from a calling party. This operation has the following format, with no parameters.
collectinformation
connect
This operation requests the SSF to route a call to its destination. It has the following format:
connect [<parameters>]
The connect operation can have any of the following parameters in any order:
originalcalledpartnumber <number comparator>
callingpartynumber <number comparator>
redirectingpartynumber <number comparator>
redircount <integer> redirreason <integer>
callingpartyscategory <integer> | callingpartyscategory <category>
genericnumbers numberqualifier <qualifier> <number comparator>
...numberqualifier <qualifier> <number comparator>
You must include the destroutingaddr parameter. The <category> parameter is one of:
unknowncategory operatorfrench operatorenglish operatorgerman operatorrussian operatorspanish ordinarycallingsubscriber callingsubscriberwithpriority datacall testcall payphone
The <qualifier> parameter is either an integer value or one of the following:
additionalCalledNumber additionalConnectedNumber additionalCallingNumber additionalOriginalCalledNumber additionalRedirectingNumber additionalRedirectionNumber
connectGprs
This operation is available for GPRS handling. When establishing a PDP context, it modifies the Access Point Name. This operation has the following format:
connectGprs gprsAccessPointName <string> [ gprsPdPid <integer> ]
connecttoresource
On receipt from the GSM SCF, this operation connects the IP to the incoming call. This operation has the following format:
connecttoresource [ legid <integer> ] [ address <digits> ]
If no address is specified, the received operation must have none indicated for its resourceAddress tag. If an address is specified, it must match the address in the ipRoutingAddress tag.
continue
This operation requests the SSF to proceed with call processing at the detection point (DP) where it previously suspended call processing to wait for instructions from the SCF. This operation has the following format and no parameters:
continue
continueGprs
This operation is available for GPRS handling. It requests the GPRS SSF to proceed with the GPRS session or context processing at the detection point (DP) where it previously suspended processing to wait for instructions from the GSM SCF. It has the following format:
continueGprs [ gprsPdPid <integer> ]
The release cause must be between 0 and 255 inclusive.
continueSms
This operation requests the SMS SSF to proceed with processing at the detection point (DP) where it previously suspended processing to wait for instructions from the GSM SCF. It is available for CAMEL handling and it has no parameters.
continueSms
continuewithargument
This operation requests the GSM SSF to proceed with call processing at the detection point (DP) at which it previously suspended call processing to wait for instructions from the GSM service control function. It also provides additional service-related information to the called party or the calling party while call processing proceeds.Parameters that are provided in the operation replace the corresponding signalling parameters in the call control function (CCF) and are used in subsequent call processing. Parameters that are not replaced by the operation retain their value in the CCF for subsequent call processing. This operation is available for INAP level 2 (CS-2) handling and has the following format:
continuewithargument [<parameters>]
The continuewithargument operation can have the following parameters:
legId <integer> cap4CallSegmentId cap4LegId <integer>
Use either the legId parameter or use the cap4CallSegmentId and the cap4LegId parameters. For CAP4 protocols, use the cap4CallSegmentId and the cap4LegId parameters. The legId parameter is not valid for CAP4 protocols.
cs1InitiateCallAttempt
This operation requests the SSF to initiate a CS1 call attempt. Although it can produce errors, it has no returned result. It has the following format:
cs1IniateCallAttempt [<parameters>]
A cs1InitiateCallAttempt operation can have any of the following parameters, in any order:
callingpartynumber ,number comparator. callingpartyscategory <integer> | callingpartyscategory <category> destroutingaddr <number comparator>
disconnectforwardconnection
This operation is used in two cases: 1) To disconnect a connection to a specialized resource function (SRF) and 2) to clear a connection to an assisting SSF. In the first case, it disconnects a forward connection from the SSF. In the second case, it disconnects the temporary connection between the initiating SSF and the assisting SSF and between the assisting SSF and its associated SRF. The operation has the following format with no parameters:
disconnectforwardconnectionwithargument
disconnectforwardconnectionwithargument partytodisconnect legid <integer>
The partytodisconnect parameter with the legid variant is the only supported parameter for this operation.
disconnectleg
This operation is available for INAP level 2 (CS-2) handling. It requests the GSM SSF to release a leg associated with the call. Other legs are retained.
disconnectleg reason <cause comparator> [legid <legid> | ( <integer> )]
Please see the description of "releasecall" for the possible values for the reason parameter. See the description of "eventreportbcsm" for a description of the possible values for legid.
establishtemporaryconnection
This operation creates a connection to a resource for a limited period of time to play an announcement or collect information and so on. It has the following format and parameter:
establishtemporaryconnection address <digits>
The address parameter, which is a string in double quotes, is mandatory.
furnishcharginginformation
This operation requests the SSF to generate or register a call record or to include some information in the default call record.This operation has no parameters:
Increasing the output level causes the parameters of the received operation to be written out even though the slpit utility does not check them.
mergecallsegments
This operation is available for INAP level 2 (CS-2) handling. It has the following format and mandatory parameters
mergecallsegments sourcecallsegment <integer> targetcallsegment <integer>
moForwardSmResult
This operation is available for MAP handling. It has no parameters:
moForardSmResult
mtForwardSmResult
mtForwardSmResult
playannouncement
This operation is used for in-band interaction with an analog user or for interaction with an Integrated Services Digital Network (ISDN) user. It has the following format and parameters:
playannouncement
[connectedparty <integer>]
annid <integer comparator> [, <integer comparator>...]
[variableparts <parts>]
If you include the variableparts parameter, you must include one or more of the part value specifiers:
price <integer> <integer> digits <digits> time <integer> <integer> date <integer> <integer> <integer> integer <integer>
These correspond to the obvious sub-tags in the variableparts parameter of the outgoing operation. The price specifier should have two integer parameters giving dollars (or big currency unit) and cents (or little currency unit) respectively. You specify the time value in hours and minutes and the date value as day of the month, month number (1-12), and year (0-99).
prearrangedend
This operation has no parameters. It expects the other side of the dialog to send the fake TCAP primitive TCAP_PRE_END.
prearrangedend
promptandcollectuserinformation
This operation interacts with a user to collect information. It has the following format and parameters:
[minnumberofdigits <integer>]
maxnumberofdigits <integer>
[<digit parameter>...]
[variableparts <part> [<part>...]]
You can use the following specifiers for digit parameter in any order:
endofreplydigit <digits> canceldigit <digits> startdigit <digits> interdigittimeout <integer> firstdigittimeout <integer>
If you include the variableparts parameter, you must specify one or more of the following part value specifiers. See the description of "playannouncement" for more information.
readyForSMResult
readyForSMResult
releasecall
This operation causes the SCF to terminate an existing call at any phase for all parties. It has the following format and one parameter:
releasecall reason <cause comparator>
You can specify an integer for the reason parameter or one of the following names:
unalloc_num norm_call_clr user_busy no_user_resp no_answer call_rejected num_changed out_of_order inval_num_fmt normal temp_failure
releaseGprs
This operation causes the GSM service control function (SCF) to terminate an existing GPRS Session or PDP context at any phase. It is available for GPRS handling and it has the following format:
releaseGprs gprsReleaseCause <integer> [ gprsPdPid <integer> ]
releaseSms
This operation causes the GSM (SCF) to terminate a short message submission attempt or short message delivery attempt and is allowed only within a control relationship. It is available for CAMEL handling and has the following parameter:
releaseSms reason <integer comparitor>
reportSMSDeliveryStatusResult
This operation is available for MAP handling:
reportSMDeliveryStatusResult [<parameters>]
A reportSMSDeliveryStatusResult operation must have the following parameter:
requestreportbcsmevent
This operation causes the SSF to monitor for call-related BCSM events such as busy or no-answer and notify the SCF when one is detected. This operation has the following format:
requestreportbcsmevent [<event>...]
A requestreportbcsmevent must have one or more event descriptions:
eventtypebcsm <type> [monitormode <mode>] [legid <legid> | ( <integer> )] [dbspecificcriteria <criteria>]
The value off legid must be one of the following:
The value of criteria must be one of the following:
numberofdigits <integer comparator> applicationtimer <integer comparator>
For example:
eventTypeBCSM oNoAnswer (2) dpspecificcriteria applicationTimer 20
requestReportGprsEvent
Causes the GSM SCF to request the GPRS SSF to monitor for a GPRS session event or a PDP context event, such as establish or detach, and to notify the GSM SCF when one is detected.You can request monitoring of more than one event in a single operation but each one will be reported in a separate EventReportGPRS operation.This operation has the following format:
RequestReportGprsEvent gprsEventType <number> [ gprsPdPid <integer> ]
requestReportSmsEvent
Causes the GSM service control function to request the SMS SSF to monitor for a short message related event such as failure, delivery, or submission, and to notify the GSM SCF when it detects one. You can request monitoring of more than one event with a single operation but each event will be reported in a separate EventReportSMS operation. This operation is available for CAMEL handling and has the following format.
eventTypeSms [ smsFailure | smsSubmitted ]
resettimer
This operation causes the SCF to refresh the tSSF application timer to avoid the tSSF time-out at the service SSF. This operation supports only one parameter, timervalue. You cannot specify the timer ID and it is not checked in the received operation. It defaults to tSSF.
resettimer timervalue <integer>
returnError
The operation has the following format:
returnError|tcapError [invokeID <integer>] errorCode <integer>
The returnError operation and the tcapError parameter operation are synonymous. If you specify invokeID, it must match the response. Otherwise, the returned invokeID is not checked. In the slpit script, calls start with an invokeID of 0 and the value is increased by 1 for each subsequent call.
sendcharginginformation
This operation instructs the SSF on the charging information to be sent. No parameters are supported for this operation and the received content is not validated.
sendRoutingInfoForSmResult
This operation is available for MAP handling and has the following format and parameters:
sendRoutingInfoForSmResult [ imsi <number comparitor> ] [ nnn <number comparitor>]
sendRoutingInformationResult
sendRoutingInformationResult [ imsi <number comparitor> ]
[ nnn <number comparitor> ]splitleg
This operation causes the GSM SCF to request the GSM SSF to separate one party from the source call segment and place it in a new target call segment. This operation is available for INAP level 2 (CS-2) handling and has the following format and parameters.
splitleg legtobesplit <integer> newcallsegment <integer>
tcapError
This operation has the following format and parameters:
The returnError parameter and tcapError parameter are synonymous. If you specify invokeID, it must match the response. Otherwise, the returned invokeID is not checked. In the slpit script, calls start with an invokeID of 0 and the value is increased by 1 for each subsequent call.
unstructuredSSResult
This operation is available for MAP handling and has the following format and parameters.
unstructuredSSResult ussdString <string>
The ussdString parameter is the expected parameter in an unstructuredSSResult operation. If you do not specify it, no check is performed. If a check is performed, the string must match the returned string, or the call will be counted in the failed call statistics.
Example Scripts
This section illustrates the call definition statements in a slpit script file for two sample calls: a standard point A to point B call and a call that plays an announcement.
A Standard Call
The statements in this example define a standard point A to point B call with one subsequent reservation in which the called party hangs up. This is not a CAMEL call.
define call atb_two_periods {
DN ?= "39421234567"
CLI ?= "3099440000"
send {
initialdp
calledpartynumber DN
callingpartynumber CLI
callingpartyscategory 10
locationnumber CLI
eventtypebcsm analyzedinformation
receive {
applycharging
thresholdtime any -> threshold
warningtime threshold - 10
eventtypebcsm omidcall (2)
eventtypebcsm oCalledPartyBusy (2)
eventtypebcsm oNoanswer (2)
eventtypebcsm oabandon (1)
eventtypebcsm RouteselectFailure
eventtypebcsm oDisconnect (2)
eventtypebcsm oDisconnect (1)
callattemptElapsedTime
callstopTime
callConnectedElapsedTime
calledaddress
releaseCause
connect
destroutingaddr DN
talktime = threshold
wait 1.0
send {
eventreportbcsm
receive {
applyCharging
RequestReportBCsMEvent
continue
talktime = talktime + threshold
wait 1.0
send {
eventreportbcsm
eventtypebcsm odisconnect (2)
applychargingreport
thresholdtime 20
endofcallindicator 1
callattemptelapsedtime 10
callstoptime "001002000000"
callConnectedElapsedTime (talktime - 20) * 10
calledaddress DN
releasecause 31
receive {
releasecall
reason 31
startcall atb_two_periods using onceA Call that Plays an Announcement
The statements in this example define a simple call that requests assistance and plays an announcement.
define call assisting_ip_pa {
SERVICE_NUMBER ?= "555801"
send {
initialdp
calledpartynumber SERVICE_NUMBER
callingpartynumber "40002000"
locationnumber "40002000"
receive {
address "1234"
send {
receive {
playannouncement
annid any
// Might receive the abort any time after sending the SRR.
allow abort assisting
send {
receive {
disconnectForwardConnection
releasecall
reason normal
// The abort might not have arrived yet.
abort open
