4 Testing Messaging with the SMSC Test Tool
This chapter describes how to configure and use the Oracle Communications Convergent Charging Controller smsc test tool.
About the smsc Test Tool
The smsc test tool emulates various parts of the short message service (SMS) messaging environment, including a Short Message Service Center (SMSC), Visitor Mobile Switching Center (VMSC), and Home Location register (HLR). You use the utility to test the sending and receiving of SMS messages. See "Overview of the smsc Test Tool" for an overview of smsc.
The smsc test tool attaches to the SLEE as a TCAP interface and handles both MAP and IS-41 incoming short message requests. It can simulate an SMSC by sending an MO ForwardSM operation, an HLR by sending an SendRoutingInfoForSM operation, or an MSC by sending an MT ForwardSM operation at MAP levels 1-3. The responses to each method are defined in a configuration file. Selection of functionality is automatic, depending on which type of operation the test tool receives.
Running the smsc Test Tool
The smsc test tool is located in the following directory:
/IN/service_packages/TEST_TOOLS/bin/smsc
The smsc test tool runs as a SLEE interface when you start the SLEE; therefore, starting the SLEE starts smsc. You must have configured the smsc test tool and configured the SLEE for smsc before smsc will run. See "Configuring SLEE for smsc" for information about configuring the SLEE.
The smsc test tool redirects its output to a log file. The log file is written to the /IN/service_packages/TEST_TOOLS/tmp/smsc.log file.
Before starting the SLEE, set the following environment variables for smsc:
  • ESERV_CONFIG_FILE
    Optional. Set to the location of the eserv.config file, which contains the XMS configuration. Defaults to /IN/service_packages/etc/eserv.config.
  • SMSC_CONFIG_FILE
    Set to the location of the smsc.cfg file, which defines the SMSC responses to incoming messages. The following example illustrates a setting of the SMSC_CONFIG_FILE environment variable:
    SMSC_CONFIG_FILE=/IN/service_packages/TEST_TOOLS/etc/smsc.cfg
    export SMSC_CONFIG_FILE
  • DEBUG
    Set to fred_smsc to obtain useful information about what smsc is doing.
    If this variable is set to all, every SLEE program writes out debugging information, which is usually not desirable due to the volume of information, most of which is not meaningful for smsc.
To configure the Service Logic Execution Environment (SLEE) for SMSC, you must include the following parameters in the slee.cfg file:
  • SERVICEKEY=INTEGER 42 SMSCINT
  • INTERFACE=Timer timerIF /IN/service_packages/SLEE/bin EVENT
  • INTERFACE=SMSCINT smsc </path/to/the_smsc> EVENT
The following example highlights these parameters in an excerpt from the slee.cfg file.
# Standard SLEE definitions...
# (MAXAPPLICATIONS, MAXDIALOGS, etc)
WATCHDOG=/IN/service_packages/SLEE/bin/ watchdog
WATCHDOGCYCLETIME=3000
SERVICEKEY=INTEGER 101 xmsIf
SERVICE=ACS 1 slee_acs ACS
INTERFACE=xmsIf xmsTrigger.sh /IN/service_packages/XMS/bin EVENT
APPLICATION=slee_acs slee_acs /IN/service_packages/ACS/bin 1 1
Other parameters listed here, which are important to running SLEE, are described in Service Logic Execution Environment Technical Guide.
Configuring the smsc Test Tool
Configuring the smsc test tool consists of adding configuration parameters to the smsc.cfg file, which is in the /IN/service_packages/TEST_TOOLS/etc directory by default. You can specify a different location for the file by setting the SMSC_CONFIG environment variable.
You add parameters to the smsc.cfg file based on the testing that you want to do. Configuring the smsc test tool can include the following tasks:
Configuring General Parameters
The following parameters apply to the smsc test tool rather than a particular protocol.
Set the following parameters in the smsc.cfg file to specify a sleep time and a request delay range.
Protocol
Deprecated.
The Protocol parameter formerly specified the protocol ("map" or "is41") to be used. However, the smsc test tool currently determines the protocol based on the incoming message.
requestDelayRangeStart
The requestDelayRangeStart and requestDelayRangeEnd parameters specify a range in seconds by which responses are delayed. The delay is randomly selected from within the specified range.
Specifies the start of the delay range.
Specifies the end of the delay range.
sleepTime
Specifies the sleep time between event polls when idle.
Configuring for CAP3 GPRS
You can use the SMSC test tool to perform one CAP3 GPRS operation, ActivityTestGPRS.
Use the following parameters in the smsc.cfg file to perform an ActivityTestGPRS operation for the CAP3 GPRS protocol. This operation tests whether a relationship exists between the gsmSCF and gprsSSF. If so, the gprsSSF replies.
CAP3DestinationReferenceRange
Optional. Specifies an array of Destination Reference patterns and associated behaviors.
CAP3DestinationReferenceRange = [
         pattern = ""
         responses = [
                  reply = true | false
                  delay = <seconds>
You set the following values in the CAP3DestinationReferenceRange parameter.
  • delay
    Mandatory for an entry in the responses array of CAP3DestinationReferenceRange. Specifies in seconds the length of time to delay the response.
  • pattern
    Mandatory for entry in the CAP3DestinationReferenceRange array. Specifies a regular expression as understood by the UNIX grep command.
  • reply
    Mandatory for entry in the CAP3DestinationReferenceRange array. Specifies whether to reply to an ActivityTestGPRS operation sent by the gsmSCF.
  • responses
    Mandatory for an entry in the CAP3DestinationReferenceRange array. Specifies an array of responses, each of which specifies a reply of true or false and a delay in seconds.
Configuring for MAP
To use the MAP protocol, set the appropriate parameters in the smsc.cfg file.
AbortRequest
Deprecated. Setting AbortRequest to true is equivalent to Action = ABORT.
Action
Specifies the action to take when a message is received. These values override IgnoreRequest, AbortRequest, or FailResponse.
altAction
Used instead of Action for the percentage of time specified by altPercentage.
altPercentage
Specifies the percentage of time to use altAction instead of Action
FailOpid
The error code to put in a TCAP ReturnError.
FailCause
The value that specifies the cause in a ReturnError message when the error code is 32 (sm-DeliveryFailure).
FailResponse
Deprecated. Setting FailResponse to true is equivalent to Action = "NACK".
fallbackVersion
Specifies the value when Action is MAP_FALLBACK. This is the MAP version to put in the TCAP ABORT message when MAP fallback is requested.
While this chapter and the smsc.cfg file refer to MAP version 3, its official name is MAP phase 2+.
IgnoreRequest
Deprecated. Setting IgnoreRequest to true is equivalent to Action = "IGNORE".
MapVersion
Specifies the MAP version to support. SMC or SMSC requests that use a higher version are aborted (TCAP_ABORT) and smsc requests a fallback to this version, regardless of the value of the Action parameter.
moreMessages
If true, the smsc test tool sends the MAP result in a TCAP_CONTINUE message, leaving the TCAP dialog open. If false, the smsc test tool sends the MAP result in a TCAP_END message, ending the TCAP dialog.
RECEIVED_SMS_STATUS_REPORT
Specifies the Action and FailOpid to use when processing messages that contain an SMS Status Report.
SEND_USSD_MAP_ERROR_VALUE
The error code to put in a TCAP ReturnError message for a MAP UNSTRUCTURED_SS_NOTIFY or PROCESS_UNSTRUCTURED_SS operation.
SEND_USSD_PROCESS_UNSTRUCTURED_SS_RESPONSE
Specifies the action to take on receipt of a MAP_PROCESS_UNSTRUCTURED_SS operation.
SEND_USSD_SS_NOTIFY_RESPONSE
Specifies the action to take on receipt of a MAP UNSTRUCTURED_SS_NOTIFY operation.
TCAP_ABORT_cause
Specifies the cause (p-abortCause) to put in a TCAP ABORT message.
Example MAP Configuration
The following example illustrates the smsc configuration parameters for MAP in the smsc.cfg file:
# smsc.cfg
SMSC = {    ...    MAP = {        moreMessages = False        MapVersion = 3        IgnoreRequest = False        AbortRequest = False        FailResponse = False        Action = "ACKNOWLEDGE_REQUEST"        TCAP_ABORT_cause = 0        altAction = "ACKNOWLEDGE_REQUEST"        altPercentage = 0        FailOpid = 32        FailCause = 32        fallbackVersion = 1        SEND_USSD_SS_NOTIFY_RESPONSE = 1        SEND_USSD_PROCESS_UNSTRUCTURED_SS_RESPONSE = 1        SEND_USSD_MAP_ERROR_VALUE = 1        RECEIVED_SMS_STATUS_REPORT = {            Action = "ACKNOWLEDGE_REQUEST"            altAction = "ACKNOWLEDGE_REQUEST"            altPercentage = 0            FailOpid = 32            FailCause = 32        }
Configuring for MAP as HLR
When Protocol is set to MAP, you can also configure SMSC to respond as an HLR when it receives a SendRoutingInfoForSM message.
You can enable both SMS and HLR capabilities at the same time.
Use the following parameters to configure SMSC as an HLR.
Action
Specifies the action to take upon receipt of a lookup request. This action supersede the IgnoreRequest, AbortRequest, and FailResponse parameters.
Address
These are the digits of the MSC number to put in SEND_ROUTING_INFORMATION_FOR_SM results.
AddressNature
This is the nature address of the MSC number to put in SEND_ROUTING_INFORMATION_FOR_SM results.
AddressPlan
This is the indicator of the numbering plan for the MSC number to put in SEND_ROUTING_INFORMATION_FOR_SM results.
canSendEmptyImsi
Controls what happens if the value of the IMSI parameter is an empty string (" "). If the value of canSendEmptyImsi is true, the IMSI is sent as an empty string. If the value of canSendEmptyImsi is false, the IMSI is constructed of the imsiPrefix value followed by the MSISDN.
Denied
Deprecated. A value of true is equivalent to Action = "NACK".
Enabled
Deprecated. When true, enables the HLR functions and smsc responds to those messages. A value of false is equivalent to Action = "IGNORE".
Error
Deprecated. When true, smsc responds to HLR messages with an error code.
ErrorCause
The cause of failure to include in the NACK response, if appropriate to the operation ID.
ErrorOpid
Deprecated. The error code to put in a TCAP ReturnError message.
FailOpid
FailOpid overrides the deprecated ErrorOpid parameter.
fallbackVersion
If the action is FALLBACK_REQUEST, this value is the version specified in TCAP_ABORT, assuming that the logic for MapVersion does not apply.
GPRSNodeIndicator
The LocationInfoWithLMSI.gprsNodeIndicator value to put in a MAP2 SEND_ROUTING _INFORMATION_FOR_SM result.
hlrAltAction
Specifies the alternative action to take upon receipt of a lookup request. The hlrAltAction parameter is used instead of the Action parameter for the percentage of time specified by hlrAltPercentage.
hlrAltPercentage
Specifies as a percentage the number of times that smsc uses hlrAltAction instead of Action.
HLRSequence
Optional. This parameter is an array that enables you to configure a different responses for the MAP plugin when using HLR functionality for Status Reports and Submit messages. See "SMSC Sequence for MAP as HLR" for more information.
IMSI
The International Mobile Subscriber Identifier (IMSI) to put in the SEND_ROUTING_INFORMATION result or SEND_ROUTING_INFORMATION_FOR_SM result.
imsiPrefix
Specifies the prefix to turn the MSISDN into an IMSI, when the IMSI parameter is empty.
ISC
MAP 3 only. Specifies whether to follow every ReturnError or ReturnResult message with an INFORM_SERVICE_CENTER operation.
ISCMwStatus
If non-zero, ISCMwStatus is included as the mw-Status field of the MAP INFORM_SERVICE_CENTER operation. Only the following six least-significant bits are valid:
You can apply the logical OR operation to these bits. For example, applying a logical OR operation to 0x20 (01 0000) and 0x04 (00 0100) results in 0x24 (01 0100), which means address not included and memory not reachable for GPRS.
ISCSeparate
Specifies whether to send the INFORM_SERVICE_CENTER in a separate TCAP message from the TCAP ReturnError message.
ISCStoredMsisdnNoa, ISCStoredMsisdnNpi, ISCStoredMsisdn
If present, is included as the storedMSISDN field of the ISC operation.
LMSI
Specifies the LMSI to put in the SEND_ROUTING_INFORMATION_FOR_SM results.
MapVersion
Specifies the MAP version to use. If the incoming MAP version is higher, SMSC sends a TCAP ABORT message to fall back to this version, regardless of the version specified.
SGSN
Specifies the digits of the SGSN number to put in SEND_ROUTING_INFORMATION_FOR_SM results.
SGSNNature
Specifies the nature address of the Service GPRS Support Node (SGSN) number to put in SEND_ROUTING_INFORMATION_FOR_SM results.On behalf of mobile subscribers, SGSN manages access to network resources and enacts the packet scheduling policy. It also initiates the Packet Data Protocol (PDP) context with the gateway GPRS support node (GGSN).
SGSNPlan
Specifies the indicator of the numbering plan of the SGSN number to put in SEND_ROUTING_INFORMATION_FOR_SM results.
Example MAP as HLR Configuration
The following example illustrates the smsc configuration parameters for MAP when smsc acts as an HLR:
# smsc.cfg
SMSC = {
    MAP = {
# This section describes how the SMSC handles SEND-ROUTING-INFORMATION
# and SEND_ROUTING-INFORMATION-FOR-SM requests.
        HLR = {
            Enabled = True
            Denied = False
            MapVersion = 1
            ErrorOpid = 1 # unknownSubscriber
            FailOpid = 1 # unknownSubscriber
            ISC = False
            ISCSeparate = False
            ISCStoredMsisdnNoa = 1
            ISCStoredMsisdnNpi = 1
            ISCStoredMsisdn = "12345678"
            ISCMwStatus
            IMSI = "0123456789ABCDEF"
            canSendEmptyImsi = False
            GPRSNodeIndicator
            imsiPrefix = "123"
            AddressNature = 1
            AddressPlan = 1
            Address = "12345678"
            SGSNNature = 1
            SGSNPlan = 1
            SGSN = "12345678"
            LMSI = "12345678"
When Protocol is set to MAP, you can add an HLRSequence parameter to configure different responses for the MAP plugin when using HLR functionality for Status Reports and Submit messages. HLRSequence is an array where each array element represents a response to a SEND_ROUTING_INFORMATION or SEND_ROUTING_INFORMATION_FOR_SM request.
Each parameter available for HLR configuration is also available for HLRSequence.
The following rules apply to use of the HLRSequence parameter:
  • If HLRSequence has one response, it is used for all responses.
  • If HLRSequence has more than one response, the first request will be handled according to the first array element, the second request will be handled according to the second array element, and so on. When the smsc test tool reaches the end of the array, it loops back to the beginning of the array.
  • If HLRSequence is absent or is present but has no responses, HLR is used for all responses.
The following example illustrates the use of the HLRSequence parameter:
SMSC = {
    MAP = {
        # This section describes how the SMSC should handle
        # SEND-ROUTING-INFORMATION and SEND_ROUTING-INFORMATION-FOR-SM requests.
        HLR = {
        hlrAltAction = "ACKNOWLEDGE_REQUEST"
        hlrAltPercentage = 0
        HLRSequence = [
            # Each of these sections has the same format as the SMSC.MAP.HLR
            # section above.
Map SendUSSDNotification
The SEND_USSD_SS_NOTIFY_RESPONSE and SEND_USSD_MAP_ERROR_VALUE parameters configure the response to the Advanced Control Services (ACS) for a MAP-UNSTRUCURED-SS-NOTIFY message.
To send a valid response, which is the default, set SEND_USSD_SS__NOTIFY_RESPONSE to 1:
SEND_USSD_SS_NOTIFY_RESPONSE=1
To send a MAP ERROR response, set SEND_USSD_SS_NOTIFY_RESPONSE to 0:
SEND_USSD_SS_NOTIFY_RESPONSE=0
Use SEND_USSD_MAP_ERROR_VALUE=value to set the error code value (1 - 44) as defined in Map2Types.h.
Set SEND_USSD_SS_NOTIFY_RESPONSE to 2 to indicate that no response is returned:
SEND_USSD_SS_NOTIFY_RESPONSE=2
The following example illustrates the SEND_USSD_SS_NOTIFY_RESPONSE and SEND_USSD_MAP_ERROR_VALUE parameters:
AP = {
    SEND_USSD_MAP_ERROR_VALUE=1
XMS tcapInterfaceName
The tcapInterfaceName parameter specifies the name of the interface that XMS uses to communicate with the SMSC. The parameter value is the same name that is specified as the SMSC interface by the INTERFACE parameter in the SLEE.cfg file.
The following example illustrates the tcapInterfaceName parameter in the smsc.cfg file:
XMS = {
xmsTrigger = {
    plugins = [
    # MAP plugin
        lib = "xmsiMap.so"
        SSN = 8
        prefix = "485"
        pluginId = 1
        config = {
            contextKey = 1234
            tcapInterfaceName = "SMSCINT"
            GT = "5114406267"
            PC = 55
            SSN = 8
Configuring for IS-41
When the Protocol parameter in the smsc.cfg file is set to IS-41, smsc accepts SMSDeliveryPointToPoint requests and responds to them based on the following IS-41 parameters.
Use the following parameters to configure smsc for the IS-41 protocol.
ACK
Deprecated in favor of Action.
If the value is true, respond with a positive value for SMSDeliveryPointToPointResult, but one without an SMS_CauseCode value.
Action
Specifies the action to take upon receipt of a message, which supersedes the ACK, NACK, TCAP_ABORT, and Ignore items. You can also use the strings "ack", "nack", "abort", and "ignore".
altAction
altPercentage
Specifies the percentage of time to use altAction instead of Action.
defaultDestPC
The point code to put in the SCCP Called Party Address of TCAP messages containing IS-41 operations.
defaultDestSSN
The subsystem number to put in the SCCP Called Party Address of TCAP messages containing IS-41 operations.
Ignore
Deprecated in favor of Action. You can also use the string "ignore".
If the value is true, ignore the request as if it was not received.
NACK
If the value is true, respond with a negative value for SMSDeliveryPointToPointResult by including an SMS_CauseCode value.
NACK_StatusCode
The action to put in the status code when the action is FAIL_REQUEST.
The parameters in this section have the same meaning as their counterparts in the IS41 section. They apply, however, only to the action that the smsc test tool takes upon receiving a RECEIVED_SMS_STATUS_REPORT message. You can include the following parameters in the RECEIVED_SMS_STATUS_REPORT section:
  • Action
  • altAction
  • altPercentage
  • NackStatusCode
  • TCAP_ABORT
  • TCAP_Notice_cause
  • TCAP_U_ERROR_code
If any of these parameters is not present, the value from its counterpart IS-41 parameter is used instead.
For example:
 IS41 = {
            altPercentage = 0
            TCAP_NOTICE_cause = 0
            TCAP_U_ERROR_code = 0
            NACK_StatusCode = 3
TCAP_ABORT
Deprecated in favor of Action. You can also use the string "abort".
If the value is true, respond by sending a TCAP_ABORT and closing the dialog.
TCAP_ABORT_cause
If TCAP_ABORT is true, the value of TCAP_ABORT_cause is the numeric code for the cause of the abort.
TCAP_NOTICE_cause
The cause to put in a TCAP_NOTICE message.
TCAP_U_ERROR
TCAP_U_ERROR_code
Configuring for IS-41 as HLR
When Protocol is set to IS41, you can configure smsc to respond when it is sent an SMSRequest.
SMS and HLR functionality is independent of each other.
The smsc response is based on the following parameters:
AccessDenied
Deprecated. When true, this parameter is equivalent to Action = "NACK". which responds to the request with a ReturnResult and a cause value that indicates failure.
AccessDeniedReason
Specifies the reason access was denied when the action is FAIL_REQUEST.
Action
Specifies the action to take upon receipt of a message. The Action parameter supersedes the Enabled and AccessDenied items.
Enabled
Deprecated. Enables HLR capabilities when true. When false, is equivalent to Action = "IGNORE".
esnManufacturerCode
The manufacturer code of the mobile device's Electronic Serial Number (ESN). This is returned in the SMSRequestResult message if an ESN was not present in the SMSRequest message.
esnSerialNumber
The mobile device's Electronic Serial Number (ESN), which is returned in the SMSRequestResult message if an ESN was not present in the SMSRequest message.
hlrAltAction
Specifies the alternative action to take upon receipt of a lookup request. The hlrAltAction parameter is used instead of the Action parameter the percentage of time specified by hlrAltPercentage.
hlrPercentage
Specifies the percentage of time to use the hlrAltAction parameter instead of the Action parameter.
HLRSequence
Optional. This parameter is an array that enables you to configure a different responses for the MAP plugin when using HLR functionality for Status Reports and Submit messages. See "SMSC Sequence for MAP as IS-41" for more information.
mobileIdentificationNumber
The mobile identification number (MIN), which is returned in the SMSRequestResult message if the MDN was present in the SMSRequest message.
NatureOfNumber
Specifies whether the routing address is national or international.
NumberPlan
Specifies the number plan portion of the routing address, which is the address of the MSC at which the mobile device currently can be reached.
returnMIN
Specifies whether to include the MIN in the SMSRequestResult message.
RoutingAddress
The global address of the MSC at which the mobile device currently can be reached.
TCAP_ABORT_cause
TCAP_NOTICE_cause
When Protocol is set to IS41, you can add an HLRSequence parameter to configure different responses for the MAP plugin when using HLR functionality for Status Reports and Submit messages. HLRSequence is an array where each array element represents a response.
  • If HLRSequence has more than one response, the first request will be handled according to the first array element, the second request will be handled according to the second array element, and so on. When the smsc test tool reaches the end of the array, it loops back to the beginning of the array..
The following example illustrates the use of the HLRSequence parameter for MAP as IS-41:
# smsc.cfg
SMSC = {
    Protocol = "IS41"
    IS41 = {
        Action = "ACK"
        HLRSequence = [
                Action = 0
                NatureOfNumber = "international"
                RoutingAddress = "6449393400"
                Action = "NACK"
                AccessDeniedReason = 2
Specifying AccessDeniedReason Values
Use the values in Table 4-1 to specify values for the AccessDeniedReason parameter.
Table 4-1 AccessDeniedReason Values
Value Meaning
0
NotUsed
1
Denied
2
Postponed
3
Unavailable
4
Invalid
tcapInterfaceServiceKey for XMS
The tcapInterfaceServiceKey parameter specifies the service key that XMS uses to communicate with the smsc test tool. This service key must match the SERVICEKEY parameter for the SMSC interface in the SLEE.cfg file.
The following example shows the tcapInterfaceServiceKey parameter in the smsc.cfg file:
# eserv.config
XMS = {
xmsTrigger = {
plugins = [
# IS41 plugin
lib = "libxmsiIS41.so"
pluginId = 1
config = {
TDMA = {
xmsPointCode = 200
tcapInterfaceServiceKey = 42
CDMA = {
xmsPointCode = 201
SMS CauseCode Mapping
Use the values in Table 4-2 to specify the SMS CauseCode values.
Table 4-2 SMS CauseCode Values
Numeric Value String Value
0
AddressVacant
1
AddressTranslationFailure
2
NetworkResourceShortage
3
NetworkFailure
4
InvalidTeleserviceID
5
OtherNetworkProblem
6-31
Reserved, treated as OtherNetworkProblem
32
NoPageResponse
33
DestinationBusy
34
NoAcknowledgement
35
DestinationResourceShortage
36
SMSDeliveryPostponed
37
DestinationOutOfService
38
DestinationNoLongerAtThisAddress
39
OtherTerminalProblem
40-47
Reserved, treated as OtherTerminalProblem
48-63
Reserved, treated as SMSDeliveryPostponed
64
RadioInterfaceResourceShortage
65
RadioInterfaceIncompatibility
66
OtherRadioInterfaceProblem
67-95
Reserved, treated as OtherRadioInterfaceProblem
96
EncodingProblem
97
SMSOriginationDenied
98
SMSTerminationDenied
99
SupplementaryServiceNotSupported
100
SMSNotSupported
101
Reserved
102
MissingExpectedParameter
103
MissingMandatoryParameter
104
UnrecognizedParameterValue
105
UnexpectedParameter Value
106
UserDataSizeError
107
OtherGeneralProblems
