Activation Project Editor Cartridge Layout Tab
Use the Cartridge Layout tab to generate a framework model for a network or service cartridge project.
For Activation Network cartridge projects, this tab enables you to generate a framework model, which creates a service action, atomic action and an action processor for any combination of action and entity and creates the appropriate association for the three elements in a 1:1:1 relationship.
For Activation Service cartridge projects, this tab enables you to generate service actions. You can create a service model that is appropriate for a specific customer.
Field | Use |
Add |
Click to add action names and description in the cartridge project. For example, ADD, MOD, DEL, or QUERY. |
Remove |
Click to clear action names and description from the cartridge project. |
Add |
Click to add entities, which are related to actions, and their description in the cartridge project. For example, SUBSCRIBER, GSM-SUBSCRIBER, ROUTE, TRUNK, or LINE. |
Remove |
Click to clear entities from the cartridge project. |
Generate Cartridge |
Click to generate a framework model for a network or service cartridge project. The framework model is based on a combination of actions and entities. See "Generating Framework Models" for more information about framework models. |
