Details Tab
Use the Details tab to define a selection criteria for selecting an event template in case of an ASAP event.
| Field | Use |
Use recommended name |
Click to enable the Event Template Name Suffix field. In the Event Template Name Suffix field, you can specify a suffix to the event template name. You can see the suffix being added in the grayed out Event Template Name field. The event template name in this case will be E_Vendor-Technology_SoftwareLoad_EventTemplateNameSuffix. |
Event Type |
Select an event type from the list. Note: You can apply event templates to just the four event types like Order Startup event, Order Complete event, Order Timeout event, and Order Fail event. |
Event Template Name |
If the Use recommended name check box is deselected, you can specify a name to the event template. |
Order Parameter Name |
(Optional) Specify a name to the order parameter. This name is used together with the order parameter value. |
Order Parameter Value |
(Optional) Specify a value to the order parameter. This value is used together with the order parameter name. |
Select |
(Optional) Click to select a service action that is applicable for only matching Order Fail event type events. The matching is against the service action name in the Order Fail event type events. Note: Only Order Fail event type events include a service action name that identifies the service action that was executed when the failure occurred. |
Open |
Click to open the service action entity in the Service Action editor. |
Clear |
Click to clear the service action displayed in the Service Action field. |
Event Template Desc |
Specify a description to the event template. |
Related Topics
