Event Template Editor Editor Tab
Use the Editor tab to define values for an event template. When ASAP is processing an event, ASAP will check if there exists an event template based on the service action, order parameter name and order parameter value, or on all the three: service action, order parameter name, and order parameter value. These details are configured in the Details tab. Based on the event name in the Details tab, the configuration in the Return Data Set tab is selected. The event, in the Details tab, is populated with the parameters configured in the Return Data Set tab.
| Field | Use |
Add |
Click to add the default event type, Order Complete Event, to the Event Templates area. |
Remove |
Click to clear an event template from the editor. |
When working with the Editor tab, see the following topics:
